Pit Lane Building Plans Plans
7 replies to this topic
#1 kpphotos
  • 43 posts
Posted 17 June 2009 - 01:00 PM
Hi
I have done alot of searching for plans for buildings such as grandstands, pits and control towers.
This is my version which I combined from various places. At the moment the pit building can hold 8 cars. However I can get 10 cars if I use the area under the tower. I guess I was wondering if it would look out place having the cars under the tower with no real access to the tower (I'm guessing no). Or I provide access for one car and a small access to the tower.
Any ideas would be great. Once I have the plans sorted I'll post them, just need to find out how to do pdf's on this site.
Ps tech prob with loading the image will post it once I figure it out
http://i350.photobucket.com/albums/q414/ph...pg?t=1245207049
Edited by kpphotos, 17 June 2009 - 01:05 PM.
#2 SlotsNZ
  • 3225 posts
Posted 30 June 2009 - 11:29 AM
This may help someone
I was fortunate to acquire last year 3 assorted kitset buildings made by a small USA company called "one thirty second", original website was scalebuildings.com (it's defunct), through a dealer in europe. Cost a fortune with postage, but they looked pretty neat.
When I got them, I saw how they were designed with little lugs and slots, as per first picture below, and were approximately 3mm thick (1/18th)
I figured I could replicate them in 3mm MDF.
Very easy, cut with a jig saw, leaving some "meat" around the lugs which I sanded back to square against pencil guidelines I had drawn, drilled opposing panels for the little holes for them to go into, checking that the panels lined up, and used same small file to enlarge the drill hole till the lugs fitted in.
Made a replica - took almost exactly one hour excluding stair case which I didn't copy.
Here they are alongside each other.
But I realised the 2 storey building obscured the back inside straight at 2 driver stations, so I used the same technique to create a single level 4 bay pits from scratch.
Part finished, ready to wire for lights. I used the Carrera papaer building pictures, and just stretched the picture in a paint programe for printing so that the garage doors fitted the size of the pit bay doors and length of pit bay. I just glued on with PVA.
In place, getting close. The pits have 12V LEDs with integral resistor glued into the ceiling, the wires pass down the inside of the front well behind the overlap beside the doors. I just held them all in place with hot glue. Crude, effective, will never be seen.
In place
By night
#3 Rene
    Slot car modifier
  • 642 posts
Posted 30 June 2009 - 02:11 PM
Wow, that looks great! especially at night! good stuff!
An unmodified car is like a blank sheet of paper, aching to be drawn on.
Ren's 3 lane routed track with analogue pits and 2 car sudden death.
#4 kpphotos
  • 43 posts
Posted 02 July 2009 - 12:15 AM
Hi
They look good, well here are a few images of the track I have been working on.
http://s350.photobucket.com/albums/q414/ph...t=_MG_2980w.jpg
http://s350.photobucket.com/albums/q414/ph...t=_MG_3017w.jpg
I'm going to start on the pit buildings. Still not sure about doing the tower though, any comments would be great.
PS Sorry you have to go the website I keep getting a dynamic error
#5 knoath
  • 3306 posts
Posted 02 July 2009 - 07:28 AM
Hey kpphotos, you might be better off rotating your track 180 deg.
Put the straight along the back of the table and all the corners at the front... it'll make retrieving stray cars a lot easier.
Having said that, the design looks good and I hope you're planning a lot of scenery!
Good luck with the buildings.
Dick
Edited by knoath, 02 July 2009 - 07:30 AM.
Dick
SCMR build thread
Woodbrook Valley build thread
#6 kpphotos
  • 43 posts
Posted 02 July 2009 - 03:58 PM
I didn't think of turning it around 180 but then I have to make a start straight. I'll just make it a rule once you come off it's game over.
How did you get the image on the site?? I always seem to have a problem.
#7 GMM
  • 13 posts
Posted 03 July 2009 - 03:50 AM
Hi, if you check our website (below), you'll see that we're starting to re-introduce and add to a range of resin buildings for trackside. We have a Toilet Block and Marshalls' Hut so far with a Scrutineers' Bay coming soon.
GMM
check our website on ffmodels.webs.com
#8 jab
  • 110 posts
Posted 06 October 2009 - 02:22 PM
I had a lot of people ask about my pit building, I never had any plans but I did a quick drawing and some pics of it in sections
I am starting a new one soon so I will take pics of it and do a step by step if anyone is interested?
anyway here are the pics I have of the old building. I hope it helps someone
Posted Image Posted Image
