Bridges
Started by slots, Apr 24 2009 09:44 PM
6 replies to this topic
Posted 24 April 2009 - 09:44 PM
Hi all. Something I don't remember seeing in a topic (which doesn't mean much with my memory
) is how low do you make a routed bridge? Do you make it high enough to just clear your highest car or do you go higher? What is the most common height?
Posted 24 April 2009 - 09:52 PM
I made mine 12 cm - I wanted to make sure I could clear my Fly truck and also fit my hand under to fetch a car if needed, plus you also need to think about visibility...
Posted 24 April 2009 - 11:08 PM
I know you're not likely to get one on your track or anything, but the Landrover Cop vehicle tops the 95mm mark. Don't know if the racing trucks sit any higher than that.
Posted 25 April 2009 - 07:41 AM
One other consideration is the fact you need to fish out any car lost under there, how easy will it be if its too low?
Rob
Rob
Posted 25 April 2009 - 08:36 AM
110 TO 120 MM CLEARANCE.
Posted 25 April 2009 - 10:38 AM
So about 120 mm will even get a truck under it? Looks like the height to use then.
Posted 25 April 2009 - 10:57 AM
Mine is 12cm just nice for the Trucks and get cars out from under there
