Chassis Reinforcement...
6 replies to this topic
#1 BigDog
  • 30 posts
Posted 02 April 2009 - 02:02 AM
DUPR rules at Steve's site said:
"... 1.2.11.3 Metal rod bracing may be used between the rear of the motor and the rear axle/chassis on one piece (GROUP 1 – see below) chassis ONLY. ..."
Sorry for being blunt, but reading the 09 DUPR rules I found myself wondering which side is the "rear" of the motor: would it be the opposite side where the pinion is, or not?
The remaining items are very clear: congrats to those who wrote them up. Posted Image
Hope to have an entry in next year's DUPR!
Cheerio lads! :)
BigDog
#2 chenglaw
    Retro Racing Nut
  • 634 posts
Posted 02 April 2009 - 03:49 AM
That would be the side of the motor facing (nearest) the rear axle in the case of a sidewinder or anglewinder mounted motor. In the case of an inline mounted rear-driven motor, it would be the end from which the pinion gear drives the rear axle crown gear. :)
Lim
I do not lose races
It's just that they are won by someone else
Malaysia Slotracing Group
Law's Slotcar Home
#3 aastes
  • 735 posts
Posted 02 April 2009 - 08:26 AM
correct - its from the rear of the motor backwards no matter what angle the motor is located within the chassis
bracing location in red
#4 rick1776
  • 2605 posts
Posted 02 April 2009 - 09:33 AM
Nice picture aastes. Very clear and informative.
#5 BigDog
  • 30 posts
Posted 02 April 2009 - 10:16 AM
Thank you both, chenglaw and aastes,
Now I fully understand what that rule means. Must say that the diagrams helped a lot! :)
Now to the second part of my investigation: do most of you guys in the DUPR reinforce your chassis' this way...?
Cheerio lads! :)
BigDog
Edited by BigDog, 02 April 2009 - 10:17 AM.
#6 aastes
  • 735 posts
Posted 02 April 2009 - 10:21 AM
Now to the second pat of my investigation: do most of you reinforce your chassis' this way...?
Cheerio lads! :)
BigDog
There is the well known problem of the 'Ninco Hop'. When running no mag downforce Nincos hop under hard accelaration. Just a simple bracing ( I actually just use paperclip type wire) which forms a sort of box section and the hop goes away. Power gets put down smoother and gears dont get crunched. No much of a problem with sidewinders (which Ninco dont make) but can be bad with anglewinders
#7 chenglaw
    Retro Racing Nut
  • 634 posts
Posted 02 April 2009 - 01:13 PM
Yup, I braced my Ninco Mosler with a piece of pcb epoxied to the chassis even though I didn't experience any "hop" with the car - you can never be too careful! And in any case, it added weight to where I needed it. :)
Lim
I do not lose races
Law's Slotcar Home
