Whats The Best Glue When Laying Magnabraid
Posted 05 February 2009 - 07:24 PM
please tell me what is the best brand (full name) to use.
i have read to put it into a sauce bottle to make it easier to squirt along the recess. sounds like good advice.
i want to lay the braid this week end.
thanks in advance.
steve
Posted 05 February 2009 - 07:46 PM
I used the 3M double sided tape, it work's fine just as long as you don't stretch the braid when laying around corner's because it can retract and pull away...speaking from experience
The contact adhesive is and was the most common glue for laying braid but i think any brand would work well just try your local cabinet maker,as for a sauce bottle i think maybe a bit messy, maybe try a small hobby brush to apply (3mm) less mess.
If you end up using the contact adhesive make sure you let it cure until it's tacky ( i work with this stuff everyday) bit on the nose.
I have also heard that a water based liquid nail's has been used, i think it was Rob (Snake Valley Raceway).
Edited by Davnic74, 05 February 2009 - 07:52 PM.
4 x Aus National Champion...
Premier Raceway Build
Gallery Raceway Build.
Heany Park Raceway Build
Posted 05 February 2009 - 08:11 PM
Davnic74, on Feb 5 2009, 07:46 PM, said:
Yep spot on Dave, thats what I used. Worked well but also messy need to be meticulous in clean up. Also Daves comment about stretching the braid applies here otherwise around bends it will lift.
Rob
Posted 05 February 2009 - 08:17 PM
thanks in advance.
steve
As I need to know as well............
Steve
ANYTHING THAT HAPPENS BEFORE OR AFTER
IS JUST WAITING RACING IS LIFE STEVE MCQUEEN
Posted 05 February 2009 - 08:26 PM
Edited by Davnic74, 05 February 2009 - 08:30 PM.
Posted 05 February 2009 - 08:29 PM
Steve
To many brand's and all are very close in quality, check your local hardware store,.
The brand i use at work is called Anchor weld 101 available from most tile and laminex supplier's.
Posted 06 February 2009 - 12:06 PM
Your track is (hopefully) going to get a bigger workout than most so it'll need to stand up to all sorts of treatment.
I'd suggest building a small test piece and testing the braid against all sorts of pulling, pushing and, most importantly, solvents.
And, even if I had a 'cross-the-heart-and-hope-to-die' endorsement of any method, I'd still test it first.
Charles
Posted 06 February 2009 - 01:32 PM
i like the idea of brushing on the glue, but i have 6 lanes to do, wouldnt the brush get all gooey when the glue starts to set. (within 10 minutes)
dont worry charles, i wont rush into it. i havent come this far to stuff $500 of braid.
steve
#9
Posted 06 February 2009 - 02:22 PM
steve
The best and easiest method is the tape...3M vhb I used this on my latest track,it is quick and easy and works well.
The only downside is the cost.
I would use it again.
#10
Posted 06 February 2009 - 11:29 PM
#11
Posted 07 February 2009 - 04:13 AM
