Chilla's New Track
19 replies to this topic
#1 chilla
  • 416 posts
Posted 28 December 2008 - 06:42 PM
My latest interpretation of Catalunya. I'm a dedicated rug racer and I've been doing variations of this track for about ten years. This one suits the space available and is adaptable to digital (I tried it yesterday). It also winds up and hides under the roof of the carport, an important consideration for a townhouse dweller.
It's made from an old table tennis table and an extra bit of 12mm chipboard. The two halves of the table tennis table are turned sideways to give a length (with the bit of extra chipboard) of 4 metres and a width of 1.35 metres. I used 70x40 structural pine for the frame.
It's hauled up by two cheap ($35) boat trailer winches. I've used chains to hold it up.
It works quite well. PM me if you want a detailed description of how it all works.
Charles
#2 bathurstbones
  • 378 posts
Posted 28 December 2008 - 08:01 PM
That looks good chilla, best send a description of the winch system to skulldrifter....He's asking about that stuff.
"You Maniacs!.... You blew it up!.. Ah, damn you!...God damn you all to hell! "
#3 SlotsNZ
  • 3228 posts
Posted 29 December 2008 - 06:26 AM
I'd really like an underneath pic or two.... too please.
Appears you're using maybe 3 of those cheap workmate enches, hoisintingoff one, with an end edge sitting overhung , btweenthe thw wood surfaces, while the hidden half of the top forms a say150 x 500mm flat support for one table section.
I'm curious about longitudinal supports for the 3 tables. I presume you've just tacked on some 74x40 end to end with a couple of diagonal braces?
Edited by SlotsNZ, 29 December 2008 - 06:26 AM.
#4 chilla
  • 416 posts
Posted 29 December 2008 - 08:50 AM
I'll get a shot of the underside when I haul it back up. It's quite simple, just two side rails and three cross pieces with the sheets screwed on. I was going to use single piece side rails but couldn't get the four metre long bits of wood home in the car. So they're made up of a pair of two metre lengths bolted to another two metre length.
It's a bit flimsy but I wanted to keep the weight to a minimum. It doesn't matter if it warps or sags a bit, I won't be using it for anything other than as a base for set track layouts.
And, yup, at the moment, I'm using $20 workbenches from Bunnings. Later on, I plan to make some folding legs with castor wheels so I can move it about. PhilR uses folding saw horses bolted to his portable track pieces and I think I'll do something like that if I can work out how to attach the castors.
Here's a shot of one of the winches. They're attached to the rafters and require a small step ladder to operate.
There are four lengths of chain, one at each corner, to secure the table to the rafters when it's up and to help lower it all down. The chains at one end are long enough to hook up when the table is down. To lower the table, I wind the winch at the long chain end up enough to unhook it from the storage position (leaving the other end attached to the chains) then lower it enough to allow the table to swing freely, then reattach the chains and release the cable tension a bit. Then I lift the other end slightly to unhook the chains and lower that end straight onto the support, leaving a bit of tension on the cable. Then it's just a matter of lowering the other end onto the support. I leave the cables connected with a bit of tension for added security, they don't get in the way.
It's a slightly complicated process to get it up and down but it's fairly quick and keeps the mechanism simple. I'll post some pics when I've finished playing ;)
It's a bit over complicated but, for aesthetic reasons, I wanted to hide everything as much as possible.
Charles
#5 chilla
  • 416 posts
Posted 29 December 2008 - 10:14 AM
A peek underneath
Rough as a bear's wassaname but it works.
The long chain end. What happens is that the chains and cable form a triangle so that everything is free to move about but also stable as it's going up or down (the cable at this end is attached the way it is so that it aligns with the rafters).
Charles
#6 skulldrifter
  • 46 posts
Posted 30 December 2008 - 11:33 PM
My slot car heaven will be based off this track!
Skulldrifter.
Some say he was born in the back of an AE86. Some say he even has negative camber on his feet. All we know is he's the Skulldrifter!
#7 chilla
  • 416 posts
Posted 31 December 2008 - 09:57 AM
Ta :mosh: ;)
The track list is:
19X full straights
6X1/2 half straights
1X1/4 straight
8XR1 curves (22.5 deg)
24 R2 curves
This is it in Slotman (by far my favourite track design software)
Charles
#8 chilla
  • 416 posts
Posted 08 January 2009 - 11:14 AM
Some pics of it all packed away.
First step in lifting Barcelonish. Hook up long chains and remove the work horse support. This end is now supported on the chains and free to move about a bit.
Next step, lift the other end ot the ceiling and secure it in place with the short chains.
Then lift the other end and secure it to the ceiling with the top links of the chains (the excess chain is simply laid on the track)
All done...
Roll up the blinds and everything's back to normal and only those in the know know.
Next step is to paint the underside grey and work out a better system for the legs (needs wheels).
Charles
#9 chilla
  • 416 posts
Posted 01 April 2009 - 04:48 PM
This is probably my best interpretation of the track I've been building for, er, a very long time indeed.
In this version, I've even decided to incorporate scenery, as you can see if you look closely.
I'm a dyed-in-the-wool rug racer and, with Ember and Wacker coming clean, I decided it was time to post a pic on Member's Tracks.
The lane lengths are 14.57 and 14.08 metres and it sits on a 4.2 by 1.4 metre board made from an old table tennis table with an extra bit.
It's the biggest I can manage. We live in a townhouse and the track lives in the carport. It's hoisted up to the ceiling with two boat winches when it's not in use.
I've sprayed all the curves with Plastidip and some have also been 'roughed up' with 60 grit abrasive paper.
Dunno about lap times, I can't be bothered setting up the timing (UR3 and webcam ZoneTrigger).
Like it says down below, if you're gonna be in town and in need of a fix, gimme a PM.
Edited by chilla, 01 April 2009 - 05:12 PM.
Charles
#10 oldslot
  • 1773 posts
Posted 01 April 2009 - 06:29 PM
I think you need some lights on the scenery
#11 chilla
  • 416 posts
Posted 01 April 2009 - 06:41 PM
Heh, heh...
Believe me, there is scenery there...
Hint, think Gallipoli...
Charles
#12 Ember
    Diorama queen alert
  • 4153 posts
Posted 01 April 2009 - 07:08 PM
:P My job here is done. When you say Rug Racer say it with pride! It's where most of them started afterall.
I promise I'll post piccies of my track when it gets put back together on its permanent table.
#13 chilla
  • 416 posts
Posted 01 April 2009 - 07:26 PM
S'funny, Embs, but I really do like the toy aspect of it all.
As you say, it's the way it all started.
There really is something quite special about a layout made completely of Scaley bits, doncha think...?
Charles
#14 Ember
    Diorama queen alert
  • 4153 posts
Posted 01 April 2009 - 09:08 PM
There's no small amount of retaining/reliving childhood. Or in my case, getting revenge on my brothers who would never let my drive the slot cars, I only ever dot to drive the train.
Funny thing is, my brother visited just after X'Mas with his 2 young sons (when my Scaley collection was still in its infancy of 2 sets and 5 cars). His kids had serious difficulty dragging him away from the track. And when he did leave there was a serious puddle of drool left on the bungalow floor (at least I hope that damp patch was drool)
Yes I wan't to build a routed track some day. A heavy duty hill climb could well be planned for the back of the scaley table at a future date (will probably make more sense when you see the table). But until that time SCALEY ROOOLS
#15 chilla
  • 416 posts
Posted 01 April 2009 - 09:31 PM
Yep, been there, done that.
And I'd encourage you to go for it. Just don't spend too much first up until you're convinced that it's the way to go.
I still have routed and scenery dreams but reality always seems to rear its ugly head. Thing is, I just don't have the room (or money).
But...
If you possibly can, scratch the itch...
...and go for it.
Charles
#16 turboman93
  • 279 posts
Posted 02 April 2009 - 08:24 AM
Man, and I was in Canberra yesterday. Just didn't have time, controller, or cars. :)
"Experience is what you get just after you needed it." - Stephen Wright
#17 waytofast
  • 231 posts
Posted 03 April 2009 - 08:01 AM
hey charles, your scenery skills are as good as mine.
#18 chilla
  • 416 posts
Posted 03 April 2009 - 10:11 AM
You're too modest Steve. A store-bought tree and a bit of Velcro is no match for elephant turds :nice: :lol: :D
Edited by chilla, 03 April 2009 - 10:11 AM.
Charles
#19 chilla
  • 416 posts
Posted 03 April 2009 - 09:45 PM
View Postturboman93, on Apr 2 2009, 09:24 AM, said:
Man, and I was in Canberra yesterday. Just didn't have time, controller, or cars. :nice:
All you need is the time...
Charles
#20 bathurstbones
  • 378 posts
Posted 03 April 2009 - 10:42 PM
That lone pine looks so......alone....
Never did like those tracks that are all cluttered with scenery though so be carefull and don't over do things, old mate ! :nice:
