2009 Proxy Cars
Posted 13 September 2008 - 09:05 AM
My two are:
Ninco Gallaway Corvette 66mm
Ninco JGTC Supra 64.5mm
Maybe others can add any cars they fond too wide to save anyone buying an ubsuitable car.
Posted 14 September 2008 - 12:40 AM
Posted 14 September 2008 - 08:06 PM
Posted 15 September 2008 - 06:00 AM
kalbfellp, on Sep 14 2008, 12:40 AM, said:
Sorry Phil, but going by this rule
Posted 15 September 2008 - 07:23 AM
Posted 15 September 2008 - 11:33 AM
Has every one else measured there entries,I am led to believe that the Slot It Mclaren is also too wide?
Edited by kalbfellp, 15 September 2008 - 11:35 AM.
Posted 15 September 2008 - 12:29 PM
Phil,
you could do that, and yes the Mclaren is also to wide (by about the same amount), thats why with so many of the cars being to wide (out of the box) maybe it would be easier to raise the limit by 1mm?
I would hate to see someone enter one of these cars, only to have them deemed illegal half way through the proxy.
but as it stands, there are 4 cars from the list (maybe 5 with the Zonda) that can't be entered.
Just my 2cents worth.
Edited by espsix, 15 September 2008 - 12:32 PM.
Posted 15 September 2008 - 12:42 PM
4 x Aus National Champion...
Premier Raceway Build
Gallery Raceway Build.
Heany Park Raceway Build
#9
Posted 15 September 2008 - 01:11 PM
#10
Posted 15 September 2008 - 01:31 PM
espsix, on Sep 15 2008, 01:11 PM, said:
its in the notes:
Some concern has been raised about some models being wider than the maximum even though they are on the list. If that’s the case then the model is outside the rules. The width rule outweighs the list. It has been suggested the maximum width should be set to 65mm to take into account manufacturing variations but this is a manufacturing issue not a proxy rule issue so the 64mm maximum is fixed. If I made it 65mm then someone would ask about a car that was 65.5mm wide.
Particular attention will be placed on front and rear track widths. Likewise particular attention will be placed on the 1.6mm (1/16 inch) ground clearance all round including gears. You have been warned.
#11
Posted 15 September 2008 - 01:42 PM
#12
Posted 15 September 2008 - 01:50 PM
aastes, on Sep 15 2008, 02:01 PM, said:
Ok I don’t have a problem because my car is an angle winder but those that are looking at using a side winder may have to do some research as most sidewinder gears are 19mm and the largest tyre I have found is about 21mm leaving you with just approximately 1mm clearance.
#13
Posted 15 September 2008 - 01:52 PM
Sorry for asking dumb questions, but i'd like to make sure my cars don't have any legality issues!
Posted 15 September 2008 - 02:45 PM
Sorry aastes and everyone concerned, didnt relize this issue had been raised in another thread
#15
Posted 15 September 2008 - 03:10 PM
Stig: Go and remeasure YOUR Supra because my Ninco Supra is just under 64mm! Maybe your has been bent out or are you measuring with a Plasic ruler?
#16
Posted 15 September 2008 - 06:31 PM
espsix, on Sep 15 2008, 02:52 PM, said:
Does this mean you'll be going by track width, not body width?
1.4.8 Wheels/tyres should not run outside the cars bodywork .i.e. if you see wheels and or tyres when viewed from above then they are illegal and must be made narrower
#17
Posted 15 September 2008 - 06:33 PM
Hot water and inward pressure??
#18
Posted 15 September 2008 - 09:34 PM
Posted 15 September 2008 - 11:52 PM
