Pimp My Ride...dupr 2008 Style
16 replies to this topic
#1 sidecar steve
    Shed dweller
  • 814 posts
Posted 03 April 2008 - 09:26 AM
SIDECAR STEVE: HQ Premier Monaro
Tyres:
My car runs MJK Tyres. Please just clean them with a damp rag and lightly scour with one of those green pad thingys.
Braids:
My braids might need a clean with something like metho.
Oiling:
Please lightly oil the armature, rear wheel bearings and the pinion/contrate with a light oil not grease (Maybe at the end of each round)
Body attachment:
If you need to take the body off, when you put it back on tighten the screws to just nipped up position then back off 1/2 a turn.
Under no circumstances touch the screws holding the motor pod in place
Edited by sidecar steve, 03 April 2008 - 06:14 PM.
cheers!
Steve
#2 espsix
  • 1484 posts
Posted 03 April 2008 - 10:11 AM
ESPSIX : FORD Capri
Tyres:
My car runs MJK Tyres. Please just clean them with a damp rag or lightly scour with one of those green pad thingys only!
Braids:
My braids might need a clean with something like metho, or Windex.
Oiling:
Please lightly oil the rear wheel bearings and the front axle mount holes, plus the armature shaft if needed.
Body attachment:
If you need to take the body off, when you put it back on tighten the screws to just nipped up position then back off 1 full turn.
I think once everyone fills out one of these, they should be printed up and kept with the cars?
#3 Antony
  • 340 posts
Posted 03 April 2008 - 12:31 PM
ANTONY : Toyota Celica
Tyres:
My car runs Ortmann Tyres. Please just clean them with a damp rag, do not scour with one of those green pad thingys, they are unlikely to last as it is!
Braids:
Oiling:
Body attachment:
If you need to take the body off, please put it back on quickly there is a lot of toxic lead in there, oh and do that screw back off thing too please.
#4 imugford
  • 524 posts
Posted 03 April 2008 - 03:48 PM
IMUGFORD : Valiant Charger
Its a Valiant... doesn't need oil or water...
#5 BMR
    wheres the tape measure ?
  • 2186 posts
Posted 03 April 2008 - 04:00 PM
BMR: Torana
Tyres MJK wipe with a wet rag will do thanks No CRC or WD40
If the spare tyres need to go on please glue them on as they are not an ideal fit on the rims I had to use. Thanks heaps for the extra time that may take , I think they will last the distance at least up to the time its my turn to host a round and I can get sticky fingers doing the tyres then if they need replacing. I will gladly do other cars if they need new tyres glued on .
Braids A wipe as you would normally do with dirty braids . There is a spare flag and braid with the car please take the body off to remove the flag as there is a retaining screw in the top of the flag
Oiling don't get too liberal with the oil a drop on the axle and armature every 100 laps or so should be plenty thanks
Body attachment reset it as it is (slightly loose about 2 - 3 mm play between body and chassis all around thanks)
Driver feed him raw meat and top up the red bull in his drink bottle at the begining of each round , tell him his Mum loves him and she said to remind him to tighten his shoelaces thanks :nice:
#6 Sports Racer
  • 1677 posts
Posted 03 April 2008 - 06:33 PM
Sports Racer : Holden/Vauxall/Opel/ Calibra
Tyres:
Black. Clean with a top quality chamois dipped in Evian mineral water. Please don't use South Australian tap water!!!
Braids:
Lightly buffed by Nubian slave girls (virgins of course and not related to each other, though this might prove difficult in Tasmania).
Oiling:
Please lightly oil the rear wheel bearings and the front axle mount holes, plus the armature shaft if needed. Use only Castrol R thinned with the sweat of the slave girls
Body attachment:
If you need to take the body off please don't post pictures all over the internet, my driver is a bit shy and tends to try to destroy the world when he gets upset.
If these instructions cannot be adhered to then you can explain it to the Missus. She's the one who must be obeyed.
Paul
May the Downforce be with you
#7 sidecar steve
    Shed dweller
  • 814 posts
Posted 04 April 2008 - 08:37 AM
Hi all. Humour is cool, encouraged in fact but please keep this thread for it's intended purpose. Off topic stuff will either be moved to "Trash Talk" or deleted.
cheers!
Steve
#8 MCGREGOR168
    Certified Idiot
  • 250 posts
Posted 04 April 2008 - 11:14 AM
Mcgregor168 Capri NSR rears.
Whatever
Regards John
WANT THAT ONE! AND THAT ONE!
#9 smallnails
    Shake and Bake Bayyyybeeeee!!!!
  • 2477 posts
Posted 04 April 2008 - 11:28 AM
SMALLNAILS!!!!!! CAMARO
TYRES: wet rag with WD40 and proceed to rub rear tyres down.........please continue until you can see no more ferrodore grit or you are reasonably sure they are clean! Give them a quick true (10 secs) on some Ultra fine wet and dry in you have some please!
BRAIDS: Spray some WD40 directly onto braids for a quick soak and then wipe off.......you will find any dirt/gunk will come straight out...........please dry braids with same rag(dont want complaints!!!!)
Please leave body fairly loose all the way around with the same even rock motion available on both sides.
Thanks!
OIL the all axle bearings lightly and only armature after next round.
Edited by smallnails, 07 April 2008 - 11:31 AM.
Posted Image Posted Image Posted Image
#10 hellrazor
  • 29 posts
Posted 06 April 2008 - 08:53 AM
Hellrazor: Renault 5
Tyres: NSR Ultragrips. I have no idea what's the best way to clean them. Whoever will be racing my car will have much more experience at this than me, so just use your best judgement and I'm sure they'll be fine.
Braids and Oiling: Same as above. Use your best judgement guys.
Body mount: The car has instructions written on it. The body is pin mounted. Use three pins only. 2 long in the back, one upfront.
Thanks, for taking care of the little frenchy and hope you'll have a blast driving it :lol:
Jan
P.S. Can someone post a picture of the nubian slaves Paul's requesting for his set-up?
#11 Eno the Wonderdog
    Woof Woof and erm.. Bark
  • 6723 posts
Posted 06 April 2008 - 04:21 PM
The Wonderdog : Opel "Jumbo" Commodore
I've got MJK's on the thing so just rub any grit off with your thumb - works for me. Please don't spit on it them though and definately do not usenot use CRC, WD40, ASIO, FBI, CIA or any other rubbish additive stuff.
I've lots of braids in the box so change them if they need it - they are reversable so check that first if it's getting manky or clean 'em - whatever. Please don't mess with teh springy guide return doover.. it's full of super secret secret weaponry and is an arse to get back together.
A spot of oil is good - I use a very thin one. Will trust your judgement as to when and where.
I think I had the screws done up then undid them by a half a turn to make the car slightly less predictable - do it - it's fun!
Please forward the Nubian Slaves to my place.. I need the lawn mown.
#12 oswald900
  • 396 posts
Posted 14 April 2008 - 05:25 PM
Tyres:
My car runs NSR Tyres. Please just clean them with Shellite if available if not a light rub of water
Braids:
My braids might need a clean with something .
Oiling:
Please lightly oil the armature, rear wheel bearings and the pinion(Maybe at the end of each round)
Body attachment:
If you need to take the body off, when you put it back on tighten the screws to just nipped up position then back off 1 1/2 a turn.
#13 MOPARDEVIL
    Mopar or No Car
  • 1035 posts
Posted 17 May 2008 - 08:40 AM
Im pretty easy with anything but some wd40 on my rear tyres would be great. They are NSR's. As for the rest of the car just the regular maintence would be great.
Greg
Greg
#14 Vinno
  • 3775 posts
Posted 17 May 2008 - 08:46 AM
View Postoswald900, on Apr 14 2008, 05:25 PM, said:
Tyres:
Braids:
Oiling:
Body attachment:
I don't have shellite but WD seems popular amongst the others and keeps the rubber alive. Your call.
#15 manimmal
    I'm Rad
  • 1153 posts
Posted 17 May 2008 - 09:53 AM
Manimmal
If not already looked after, mine would likely be about ready for a lube.
and a better chassis
and more power
and a new wing
and more stability
#16 kalbfellp
  • 7183 posts
Posted 17 May 2008 - 07:26 PM
Just what my NSR's need. Thanks.
#17 Devious Dave
    Volvo Driver
  • 380 posts
Posted 18 May 2008 - 02:18 PM
Devious Dave.....Audi 90
Check that braids are flat and tyres are clean. Just a damp cloth or spit (extra good if you've just had pizza). ;)
