Wiring Rally Loops
123 replies to this topic
#1 imugford
  • 525 posts
Posted 09 December 2007 - 06:13 PM
Hi all - just wondering if anyone runs a working single lane loop that doubles back on itself with automatic current switching
Ian
#2 gazza
    2010 / 2011 SCX Classic Rally Proxy World Champion
  • 4375 posts
Posted 09 December 2007 - 06:38 PM
This is from Archer Raceway (Oldslotracer) http://www.oldslotracer.com/index.html
Here's a sketch of the reversing loop, and a wiring diagram for those that understand it (I don't)
It's a solenoid triggered by the dead strip at the top of the hill, and reset by a toggle switch when
you get back to the bottom. I suppose it would work with a loop at the bottom as well, but I just
wanted a timed run
#3 imugford
  • 525 posts
Posted 09 December 2007 - 07:04 PM
thanks gazza
#4 Rev Rev
  • 7 posts
Posted 01 February 2008 - 01:46 PM
If you can explain it, I will build it.
I've dreamed of having one of these in the track that is currently underconstruction. If anyone can translate Electronics into English I am listening, and eager to see it in action on my track.
#5 Johno
  • 297 posts
Posted 01 February 2008 - 02:36 PM
Yeah I agree
Or even if anyone has some photos of it in action
The drawing of the loop looks easy enough but the rest is a bit :)
#6 phoeno29
  • 2177 posts
Posted 02 February 2008 - 09:35 AM
if someone makes a few of these up and has them as such a point where as you just attach tothe table, add wire 1 to left tape, wire 2 to right tape etc, I would buy one as I have plans.......
#7 mtpanorama
    Slot Car Racer
  • 499 posts
Posted 02 February 2008 - 02:00 PM
Don't know what sort of explanation you guys are after but I will give it a go.
The contacts on the relay or solenoid as it is called in the diagram is connected to the wires that give power to the track, with the relay off the car travels towards the loop. As the car goes over the dead spot the relay is switched on and locks on through another contact, the power to the track is reversed allowing the car to travel away from the loop. The toggle switch (a push button momentary off switch would probably be better) is used to cut the locking circuit to the relay turning it off so the power is back to normal.
I don't think it could be made as a stand alone item as it basically already is, you just need a relay, a switch and the track to connect it to, but I could be wrong.
Hope this helps
#8 Count
  • 248 posts
Posted 02 February 2008 - 06:06 PM
here's a video I found on the 'net of said rally loop
Edited by Count, 03 February 2008 - 12:25 AM.
Pretzel Logic Raceway
Ask not what MDF can do to you, rather ask what you can do to MDF!
#9 Johno
  • 297 posts
Posted 28 February 2008 - 07:29 PM
I had a go at wiring all of this up.
I bought this relay SY4009 from Jaycar
And wired it up using the above diagram. It all seems to work...the car goes towards the loop, around and hits the dead spot, I can hear the relay click and see the connection switch but then when the car leaves the dead spot the relay switches back immediately and doesnt stay on.
The reverse part definately works as I can leave a car on the dead spot and another car will run back the other way but obviously that is no good.
The only thing I can think of is the switch part which runs between the dead spot and the coil. I have figured it to be a simple SPST momentary switch....perhaps it is something different.
So the question is have I bought the wrong relay or is there something else I need to do to get the relay to lock on when activated?
So close......grrrr
Edited by Johno, 28 February 2008 - 07:36 PM.
#10 Johno
  • 297 posts
Posted 29 February 2008 - 07:30 AM
Hmm reading about relays on Wikipedia I may need a Latching relay that when the current is switched off, the relay remains in its last state.
Im guessing the one I bought doesn't do this. Might have to go pester the blokes at Jaycar again :lol:
#11 mtpanorama
    Slot Car Racer
  • 499 posts
Posted 29 February 2008 - 08:51 PM
So close......grrrr
Sounds like you might have forgot part of the circuit, have you wired the relay up to a set of contacts on the relay so when the relay operates it will hold itself on like the forth set of contacts on the circuit diagram above.
#12 pmc356
  • 305 posts
Posted 29 February 2008 - 10:29 PM
Not sure but looked up the relay they have used and it sounds like an odd one (KHAU-17D11-12)
Relay
However got confused by more information
Info
Hmm not sure if that helps after all <_< perhaps ask the guys at Jaycar
Paul
#13 Johno
  • 297 posts
Posted 01 March 2008 - 04:46 AM
I think I have it sorted. I have got the wrong type of switch for the reset mechanism. I must have bought a momentary on switch not an off.
With the switch wired in the relay is turning off straight away but I removed the switch from the circuit and the relay turned on and stayed on until I untwisted the two wires breaking that circuit.
So I will drop into Jaycar this arvo and get a different switch
Thx for the help MtP and everyone
Edited by Johno, 01 March 2008 - 04:50 AM.
#14 Johno
  • 297 posts
Posted 01 March 2008 - 06:22 PM
Well I picked up a normally closed switch and soldered it into my test loop and it all works.
Ive taken a cpl of photos but I doubt they will be of any use. As you can see my wiring and solder work leaves ALOT to be desired.
Luckily its not permanent
Easy
#15 gazza
  • 4375 posts
Posted 02 March 2008 - 04:21 PM
Have you got a part number for the correct switch?
#16 Johno
  • 297 posts
Posted 02 March 2008 - 10:07 PM
I think it is SP-0717 from Jaycar
But any SPST switch momentary switch that is NC (normally closed) is fine.
That was the only one they had that was NC though. All the rest where NO
#17 Matticus
    Capable of getting even the simplest tasks horribly wrong.
  • 299 posts
Posted 03 March 2008 - 11:25 AM
So how does it know when the car has rejoined the single lane rather than the loop? Also how is the polarity switched for the rails? I'd presume there is one of these at both ends, and as the car switches one open it closes the other in preaparation for the return leg?
Some days we are the flies; some days we are the windscreens.
Avusring Gallery | Avusring Track Thread
#18 Johno
  • 297 posts
Posted 03 March 2008 - 03:36 PM
Thats what the switch is for matt.
As the car trips the relay it changes the polarity and runs back down the hill to the finish line. Once done you click the button on the switch and it resets back to uphill again. I guess you could have 2 loops at each end if you wanted to run continual laps and not time trials
#19 mtpanorama
    Slot Car Racer
  • 499 posts
Posted 04 March 2008 - 03:19 PM
Good to see you got it going.
#20 Johno
  • 297 posts
Posted 06 March 2008 - 10:25 PM
Sadly I have hit a new hiccup in my hill climb.
I wired the track up this evening and on testing the car drives up the hill goes around the loop, over the dead spot but then it fails to trigger the relay.
I put the car back bit and try again and the same thing, the car drives straight over the dead spot without triggering the relay :lol:
So then I get the car and push it along the track and over the dead spot and click the relay activates. I push it along again and click the relay works.
So I know the dead spot works and triggers the relay, just not while im running a lap.
No idea if it is a speed thing or something else but it is a bit annoying.
