Show Us Your Set Up For The Rally Proxy
25 replies to this topic
#1 hmcsat
  • 299 posts
Posted 18 October 2007 - 10:37 PM
Perhaps a little over engineering but it was fun getting it to work. It now runs smooth as silk and accelerates out of corners like a rocket!
How it will actually fair is anyones guess.
All Slot It running gear with Cartrix TX4 motor.
#2 BMR
    wheres the tape measure ?
  • 2186 posts
Posted 19 October 2007 - 12:13 AM
Its a bit early to be giving away secrets - you must be quite confident :) My secrets are pictured in the SCX catalogue under Subaru Liberty
Its stock with the front drive crown gear taken out and some lead over the flag.
I have replaced the 9 tooth pinion with an 8 tooth pinion gear (the 9 was worn out and I only had an 8 floating about in the parts bin)....Oops there goes my secrets. :lol:
#3 gazza
    2010 / 2011 SCX Classic Rally Proxy World Champion
  • 4374 posts
Posted 30 October 2007 - 04:33 PM
Went for the tried and tested setup ....... NC-1 and a little weight
Very boring i know ...... but it works
#4 Ontheflipside
  • 2282 posts
Posted 30 October 2007 - 09:07 PM
R U leaving the belt on?
AKA - Rodes
#5 manic35
  • 2867 posts
Posted 30 October 2007 - 11:20 PM
You'll get no 'top secrets' from me mate.
Ninco Evo with suspension, (blue - wonder how that will go :ph34r:) single belt 4WD, upgraded MJK rubber all around (making sure it doesn't stick out past the body of course), little weight similar to ontheflipside's setup.
I still need to upgrade the glide but may not get around to getting one, maybe hot glue in the motor too.
Hey hmcsat, what's that white sh!t all over the inside of your Rex? lol :ph34r:
Cheers Manic
Visit my slot site at: http://manicslots.blogspot.com/
#6 gazza
  • 4374 posts
Posted 16 September 2008 - 07:00 PM
Anyone building anything special this year?
#7 hmcsat
  • 299 posts
Posted 16 September 2008 - 07:35 PM
You bet Gazza, not so much a new car but a complete re build to the same one, keeping what works and ditching what did not. Throw in a few new trial mods, a new paint scheme and shes all apples!
#8 Ontheflipside
  • 2282 posts
Posted 28 September 2008 - 08:46 AM
Now here is a road surface finish I would like to have a go at on my new track rather than a "girlie gloss" finishes some use :D ;) .
Link
Used this surface in last years proxy and worked well but needed a few hours of driving on to get the rubber down. Voltage on the existing track 11 volts is best but not sure on the new one as there are some long straights and also heaps of 200mm + radius curves
Will see if I can get a close up shot of the "Dulux Tuscan" surface
Edited by Ontheflipside, 28 September 2008 - 08:49 AM.
AKA - Rodes
#9 kalbfellp
  • 7183 posts
Posted 04 October 2008 - 12:20 AM
Here is my Corolla body ready,running gear still needs some more work.
#10 phoeno29
  • 2175 posts
Posted 05 October 2008 - 09:56 PM
how difficult is it to add a second belt to a ninco car ? does it help ? or a tighter band, would that give more drive to the fronts ?
#11 Sports Racer
  • 1677 posts
Posted 06 October 2008 - 02:30 AM
The only way you can give more drive to the front is by changing the gearing if you're running a SCX motor. Or are you trying to get the same drive to the front that you get to the back?
May the Downforce be with you
#12 kalbfellp
  • 7183 posts
Posted 06 October 2008 - 09:58 AM
ninco car
Paul they are belt drive front wheels. Martin: The O rings can be replaced with a small diameter one no problems. But I don't know if it helps the car.
#13 phoeno29
  • 2175 posts
Posted 06 October 2008 - 10:02 AM
thanks phil. I didn't think the front wheels drove much on my ninco 4wd with the sloppy belt and wondered why they only had one when two would have to be better.
#14 Ontheflipside
  • 2282 posts
Posted 06 October 2008 - 10:54 AM
View Postkalbfellp, on Oct 6 2008, 10:58 AM, said:
ninco car
The jury is out on that with me as well.
AKA - Rodes
#15 gazza
  • 4374 posts
Posted 07 October 2008 - 02:26 PM
Just about finished with the Seat!
A few more tweaks and she'll be ready for the post
#16 The Stig
  • 159 posts
Posted 07 October 2008 - 03:10 PM
How about showing us all the secrets inside?
The Stig
#17 Sports Racer
  • 1677 posts
Posted 07 October 2008 - 07:39 PM
Secrets? Your talking about Gazza's cars, there's no secrets inside apart from a ton of lead slapped wherever it fits. That's why he likes building widebody Mustangs and Camaros - more room inside to fit the lead. :o
#18 gazza
  • 4374 posts
Posted 08 October 2008 - 06:33 PM
There you go ..... just a stock standard SCX :rolleyes:
#19 hmcsat
  • 299 posts
Posted 08 October 2008 - 08:39 PM
Cracker setup Gazza.
#20 phoeno29
  • 2175 posts
Posted 08 October 2008 - 09:23 PM
I am not sure how these high powered 4wd cars will go here, the longest straight is only 1 metre long.
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
