Where To Buy 10 Ohm/2w Potentiometers
Posted 25 July 2010 - 12:26 PM
Some of our HO members are building upgraded (transistor powered) controllers, and I've been thinking of doing the same for a long time.
Although they are building the ones based on this design, I want to build the later model based on this design.
However I'm having trouble locating 10 Ohm, 2W potentiometers in Australia - I've found some in NZ, but they come to around $10 each, does anyone know a local source??
Richard
Posted 25 July 2010 - 12:43 PM
I would guess, that RS components would have them.
Having Not read Both articles,..what are they For?
Dick Smith actually has Potentiometers suitable for Sensitivity and Brake pots.
Posted 25 July 2010 - 02:23 PM
Posted 25 July 2010 - 09:46 PM
The one in NZ, I have to make a $50 order (pre shipping) before they will send them out to Australia, which makes it uneconomical ....
@DM, yep, they have made them for under $20 - I think Dave posted a rough guide on the pricing, but you can get the transistors (MJ11015) for around $5 a pair on the Bay ... but these are a darlington pair, according to the later version I posted, there is a small voltage drop which is improved, as well as a few other features. However I'm stopped on these damn pots
Richard
Posted 26 July 2010 - 12:08 AM
Posted 26 July 2010 - 12:50 AM
Richard
Posted 26 July 2010 - 10:53 AM
Theres a place in sydney that may have them in stock, although it would cost around $15 by the time its posted to you. PM me if you want details.
I'm building the same controller as on the ABSlotsport site and while ive spent about $70 buying all the components, hardware and cable. If it works the way im expecting its much cheaper then buying a new adjustable electronic controller.
Posted 26 July 2010 - 02:05 PM
#9
Posted 26 July 2010 - 02:52 PM
Edited by FLY in the wall, 26 July 2010 - 02:53 PM.
#10
Posted 26 July 2010 - 09:56 PM
FLY in the wall, on Jul 26 2010, 12:52 PM, said:
It looks like a standard pot:
This particular one is 3watts and 10 Ohms, single turn:
Uses 9mm diameter panel mounting holes. All pots include brass nuts and washers.
Type: Single gang LINEAR taper 3W 500V DC
Resistance: 10 Ohms
From the DSE site ... http://www.dse.com.au/cgi-bin/dse.storefro...duct/View/R6903
Richard
#11
Posted 30 July 2010 - 04:09 PM
If you are REALLY stuck, I would have to take a 1/2 day trip to the main electronics shop. If I can persuade the wife to take my DeWalt battery pack to be repaired she can ask at that time.
#12
Posted 30 July 2010 - 06:07 PM
web: www.wascrg.com
email: info@wascrg.com
#13
Posted 30 July 2010 - 10:17 PM
Richard
I am in the middle of making a variation on the JayGee controller, and I am using an 11 position switch with 11 x 1 oHm resistors on it as a 10 oHm pot.
Switch is from Dick Smith - about $3.50.
Down side (or upside, whichever way you look at it) is that there is ONLY 11 positions.
Regards,
Dennis
#14
Posted 30 July 2010 - 10:43 PM
#15
Posted 30 July 2010 - 10:54 PM
Richard
#16
Posted 01 August 2010 - 12:34 AM
Cheers Bill
