Last night one of the racers had the dreaded threaded wheel when he has a good set of tyyres tuned in on the hub. He asked me how to re tap the hub. Being the least mechanical person in the solar system I have no idea other than try using the old supergle create your own thread trick like for body posts but i doubt it would work with a metal to metal bond? Does anyone know the correct size drill bit or tecxhnique to create a newly formed hole for an M2 grub screw?
Tapping An Aluminium Hub.
Started by first corner crash, Jun 23 2010 02:54 PM
4 replies to this topic
Posted 23 June 2010 - 02:54 PM
I used to Drink too much. I still do but i used to to.
Posted 23 June 2010 - 04:03 PM
There are a couple of threads here and here that may help.
Edited by slotbaker, 23 June 2010 - 04:09 PM.
Steve K.
Sunset Racing Shells
1/24 Scale Racing - Hornsby
SSME Slotcar Section
Sydney Society of Model Engineers - Luddenham
ASCRA - Slot Car Central, Australia
Aussie Retro.
Aussie Retro.
Posted 23 June 2010 - 09:59 PM
Tapping drill sizes for metric threads is very simple,just subtract the pitch measurement from the diameter for the drill. So for 2mm x 0.4 pitch the drill size is 1.6mm.
I us a 1.5mm drill.
I us a 1.5mm drill.
Edited by kalbfellp, 23 June 2010 - 10:00 PM.
Posted 26 June 2010 - 09:24 AM
Hi Trev, if its not clear.
You need to mark out and redrill and cut a new thread on the rim. (most rims have two grub screw holes ?)
If the rim has only one hole drill and tap 180 deg from original hole . If two holes originally you may be pushing it but turn and drill 90deg.
You should place rim in vice or clamp. You need to be fairly carefull, go slowly and use a lubricant on the drill and the tap.
The rims are soft and it will not take much to gall up the thread.
Good luck , see you Monday night at Waynes.
Paul
Paul
Try Harder, if you dont fail your not trying hard enough
Posted 26 June 2010 - 10:46 AM
Steve K.
Aussie Retro.
Aussie Retro.
