Just thought some of you may enjoy some photos...from time to time....im not in any rush just enjoying the time in the shed!!!
So far ive built a table in 2x2m sections ,so it can be transported easier if the need arises?? used 75x35 & 20x35 pine for this,screwed and glued,then screwed and glued 6mm mdf to the top....the two section are bolted togehter with 100xm10 bolts and washers....temperary legs have been fitted as i am still deciding exactly how to rig the table so it all folds against the wall for storage...
Most of the lay out is there just have to redo one corner a little bit of straight...bla,bla,bla......hopefully i will get this done soon??
The lenght of the track will be approx 14m....non mag copper braid...variable voltage power supply....100mm lane spacing around 120-130 gutters..
Once i get the rest of the track cut and screwed i can then finish routing the slots...then the braid recess etc.....
You all know how it goes..hope to post some more pictures soon.....
