Scx/scalextric Motors
Posted 11 June 2010 - 06:32 PM
Im am thinking if i use a standard Scalextric motor i will need spacers but was wondering if i use a Scalextric F1 or Bike motor as they are longer then i wont need spacers?
Do you need the conversion kit to fit any different motor into SCX cars ?
Does anyone know or have any tips on this
Posted 12 June 2010 - 12:55 AM
Why? SCX offer some higher performance motors, OR the SCX motor can easily be tuned to perform better.
Posted 12 June 2010 - 08:51 AM
oh by the way thanx for the drill the other day car is flying
toast
Posted 12 June 2010 - 09:19 AM
Ive never been a fan of SCX Motors
How can you tune a SCX motor to perform better other than running it in ?
Posted 12 June 2010 - 11:33 AM
Posted 12 June 2010 - 01:38 PM
Posted 12 June 2010 - 01:57 PM
first corner crash, on Jun 12 2010, 02:38 PM, said:
Do you know what Scaley Motor it was eg F1 or not a Long Can motor ?
Guess he used the Slot It adaptor ?
#9
Posted 12 June 2010 - 06:00 PM
#10
Posted 12 June 2010 - 06:23 PM
#11
Posted 12 June 2010 - 06:25 PM
#12
Posted 15 June 2010 - 02:12 AM
The problem everyone has is finding an equivalent to scaley. If you don't race then slot.it green would be close?
Another idea would be FF shaft should be OK but performance would be better. Have a good look at new SCX offerings there is probably something there.
Want to go really quick on a budget? Little Ripper but you'll need a big track.
Now I just came back from the pub and Google has Google goggles which i could probably pass but SF does not.
Edited by FLY in the wall, 15 June 2010 - 02:12 AM.
#13
Posted 15 June 2010 - 09:28 AM
oswald900, on Jun 12 2010, 06:30 PM, said:
Edited by first corner crash, 15 June 2010 - 09:30 AM.
#14
Posted 15 June 2010 - 12:49 PM
#15
Posted 26 June 2010 - 01:26 AM
SCX RX-4 16,400 RPM/12v; tested 13,367 RPM/12v
SCX RX-41 16,400 RPM/12v; tested 14,378 RPM/12v
SCX F1 16,400 RPM/12v; tested 13,500-15,390 RPM/12v, tested 77 gcm/12v, 2.8W/12v
SCX RX-42 16,400 RPM/12v; tested 14,971-15,400 RPM/12v
SCX RX6B (was RX6) 18,000 RPM/12v
SCX RX-81B 18,000 RPM/12v; tested 17,184 RPM/12v
SCX RX-42B 18,000 RPM/12v; tested 17,927-18,900 RPM/12v tested 130 gcm/12v, tested 5.8W/12v
SCX RX-41B 18,000 RPM/12v; tested 18,256 RPM/12v
SCX Pro Turbo 18,000 RPM/12v; tested 20,100 RPM/12v
SCX Pro Turbo Plus 19,000 RPM/12v; tested 20,340 RPM/12v
SCX RX-62C 19,000 RPM/12v; tested 18,540-20,622 RPM/12v
SCX RX-91; tested 20,533 RPM/12v
SCX Pro Speed Double Rally 19,100 RPM/12v 135 gcm/12v, 6.4W/12v
SCX Pro Speed 19,600 RPM/12v; tested 18,800-20,717 RPM/12v 140 gcm/12v; tested 123 gcm/12v, tested 6.4W/12v
SCX Pro RX-4H 25,000 RPM/12v; tested 27,282 RPM/12v
SCX RX-42E Club Porsche tested 20,750 RPM/12v. Same armature as Pro Speed.
SCX Compact 1/43 (FF-030) 22,000 RPM/12v 33 gcm/12v, 1.8W/12v
RX-4H runs at 27000 RPM so why would you want to put in a Scalex motor?
SCX build quality is very poor with 1 in 20 motors being much quicker than the specs above indicate. Fastest motor I have is a Turbo armature in a RX-42 can. It revs much harder than a Turbo Plus and the torque is so great it spins the wheels as soon as it accelerates. Easily as fast as an orange endbell Slot.it. The only reason I swapped arms is because in the turbo can it ran as slow as a RX-42 so I did some experimenting.
An easy way to get a quick SCX motor is to fit a Parma deathstar 16D armiture. They go straight in and run really hard with lots of power. Or you could fit a Group 20 arm and really have fun. Won't be drivable through corners but down the straight nothing will touch it.
Paul
Edited by Sports Racer, 26 June 2010 - 01:42 AM.
#16
Posted 14 July 2010 - 03:19 PM
Thanks for removing the spam post.
Edited by kalbfellp, 15 July 2010 - 01:57 AM.
#17
Posted 14 July 2010 - 11:26 PM
I put one in my Red Bull Aston Martin certainly is a lot quicker - feels more like the Pro Porsche (same motor) but doesn't have very good brakes
any suggestions for how to improve the braking?
#18
Posted 15 July 2010 - 06:55 AM
