Yngwie, on Jun 9 2010, 05:32 PM, said:
Shane, I too prefer the Anglewinder setup. Its just the the wheels need to narrower to accomodate. Not sure which wheels the 956 would need if I were to change to AW. Also, does this need the Ninco bracing method applied to it or has Slot.it thought about this sufficiently?
Gazza, will be interesting to see who wins that contest!
Buy the sound of it you are doing up a slot it porsche 956. I have just done some testing of my own with a slot it 956kh and a 962c.
956 set up....
sidewinder offset pod,
nsr shark25 motor
nsr 19x10 super grip tires
standard slot it rims
nsr 12t pinion, slot it 32t crown
962c set up...
Angle winder offset pod
slot it flat 6R motor 22000rpm
nsr supergrips 19x10 tires
New ninco prorace rim (air system)
nsr 13t pinion, slot it 32t crown.
I have done all my usual setup tricks such as gluing the motor or screws, making sure pod floats freely by filing the pod or chassis which ever is needed. shaved the chassis so body floats freely. setup a low front ride height (1mm). Glued and trued wheels etc etc.
after testing them at our club, thunderbirds! I found that the 956 with the sidewinder was by far the better car that suited my driving style (if i have one...lol). It is now equal to my fastest car in my collection (nsr mosler).
I found that i could push the sidewinder config really hard and it would not come unstuck! I could go deeper into corners and accelerate earlier out of them!
The angle winder is a very nice setup and drove really well but i could not push it as hard as the SW setup. It was just as quick in a straight line but it came unstuck alot easier in corners therefore i could not push it as hard. I tried swapping the wheels over to see if that was the difference but it was still the same.
So in my opinion for a
porsche i would use the sidewinder setup because it suits my style of driving alot better. That my not be so for other people!
Ps. for the AW setup you have to use a short hub rim to keep the wheels inside the body line! I have never use any bracing method for any of my slot it cars and they all run very smooth and quiet!
peter
