Tools??
Posted 14 May 2010 - 12:17 PM
I'd like to get a tool similar to a dremell, without paying the big bucks up front.
Is there another tool out there that is similar, but not as fancy?
I'm just looking for something basic. I'm only a beginner getting into some very very basic scratch building.
cheers!
tim
Posted 14 May 2010 - 01:19 PM
I bought one about 18months ago, as a back up and for doing rough stuff. While it's got a bit more vibration than a Dremel, it does the job.
Mine was only about $35, but don't know what they cost now, if they still have them.
Sunset Racing Shells
1/24 Scale Racing - Hornsby
SSME Slotcar Section
Sydney Society of Model Engineers - Luddenham
ASCRA - Slot Car Central, Australia
Aussie Retro.
Posted 14 May 2010 - 05:37 PM
Posted 14 May 2010 - 06:14 PM
Picked up a $10 set of 35-40 attachments sandinf discs, cutting wheels etc. at a mitre 10 sale- all bits fit fine.
Supercheap also used to have some, but haven`t been in there for awhile.
Posted 14 May 2010 - 06:28 PM
Personally, I recommend buying the best you can afford as it will last you well. And once you have it you'll find more and more uses for it.
Posted 14 May 2010 - 08:05 PM
Save up if you have to, but don't skimp on something, for a couple of dollars, that may well last you a lifetime of enjoyment and destruction.
cheers,
Posted 14 May 2010 - 10:28 PM
Posted 14 May 2010 - 10:44 PM
#9
Posted 15 May 2010 - 09:04 AM
If you are in Sydney for the timber and woodworking show (next month?) there are usually some great deals to be had on the machine and consumables.
Posted 17 May 2010 - 11:51 AM
I found a couple of cheap knock offs on evilbay, but i don't think i trust them too well
going to bite the bullet and fork out the dough i think, but not straight away!!
#11
Posted 17 May 2010 - 12:51 PM
I was doubtful at first but I needn't have worried.
The collet works fine.
My old dremel was a "handmedown" that had been used for lapidary work ( jade)
The thing still works but is noisey and not that accurate.
The replacement has a great slow speed control and a flexi drive which is great because the handpiece is a better size than actually holding the whole dremel body.
#12
Posted 17 May 2010 - 01:23 PM
I've got a bunch of 1 1/2 shank dental drill diamond burrs that I use a lot. I used to work a lot with a flexidrive dental drill for glass engraving, so I thought I'd use the flexi drive on the dremel more than I do. But unless I'm working on something really fine and accurate I don't bother with the flexi. Still use it occasionally for glass engraving, but the next model up would've been better for that, I only bought the base model cos it was on special and I'm a tightwad.
#13
Posted 17 May 2010 - 08:03 PM
#14
Posted 17 May 2010 - 08:54 PM
Some supermarkets and cheapy shops like Go Lo,etc also have them. Check out the craft or party section.
#15
Posted 20 May 2010 - 03:14 PM
kalbfellp,
Yellow? This is also good for putting under Ninco front axles.
#16
Posted 20 May 2010 - 04:24 PM
The one near me (Hoxton Park, NSW) is having a clearance on Dremel stuff.
Aussie Retro.
#17
Posted 26 May 2010 - 11:33 AM
It's actually a great piece of kit for the price!!
