first corner crash, on May 13 2010, 11:34 PM, said:
Thanks for the update Terry. No real surprises in your shakedown. I am curious as to what tyres Newso is using as it was a good car last round but had poor grip and i think it went well on one other track (enamel?) might be a case of tyres that siuit that particular surface. I know Chris( mannimal ) and i are both running ortmans. I think they are even the same model. (Thanks for the tip Chris). I am not sure what the others are running.but as the race is now starting to take shape it would be interesting for all the builders to know what the other guys are running.
I'm running NSR(newso) ,when the car got here it was all over the shop,very taily and over a half second slower than when tested,the tyres were very very dry and powdery,I think with NSr(I know)they must have some sort of tyre treatment,not wd40 NO,NO,NO!But simply a wipe with water/dishwashing liquid solution is sufficent,straight away the car is down to its test lap times.
Most other cars have tyre issues.
I would say that 70% of the field have tyres with square edges,which means that the car will not run through the corner smoothly,it will tend to skip or possibly behave erratically.
I have put together a list of cars which,in my opinion,will benefit from a little rubbing on the edges with a emery board.
please advise if you would want me to do this for you,if you don 't thats not a problem.
The following cars :
Obsidith
Lenny Broke
Hoffy
Suttle
DanS as well as square tyres,your rear track has narrowed,but with plastic rims I'm not sure if you want me to try and fix,pls advise
Sports Racer
GZminiZ
Slittlehales
MarkD
Newso
XR8,don't know whats going on but I cannot get the body of the chassis,did you glue the body on?
I have plenty of time to get this done so don't worry about that factor,just let me know what you want me to do here.
Terry
Edited by terry, 14 May 2010 - 09:55 AM.
