How To Measure Rims?
Posted 29 April 2010 - 08:36 AM
Also wondering if MJK's work on the NSR air system or is it a bad idea?
So many factors, worried I will get the wrong set. Anything else I need to take into account?
Posted 29 April 2010 - 12:04 PM
17X10 refers to 17=total dia X 10= width
Slot it rims are measured form the outside edge of the rim to the inside edge not including the boss for width. For Diameter it is the overall diameter including the raised section.
I don't know about the NSR/ MJK combo, never used that set up.
Cheers Alan
Edited by lenny broke, 29 April 2010 - 12:07 PM.
Posted 29 April 2010 - 03:14 PM
Posted 29 April 2010 - 03:38 PM
slot it wheel dimensions
Also Have a look at the wheels and inserts section over at armchair racer. it will give you a good idea of whats around to suit. they also do starter kits with bearings axles, gear sets. wheels and inserts. NSR do similar kits too but I don't use them as much so not sure of range.
Alan
Edited by lenny broke, 29 April 2010 - 04:14 PM.
Posted 29 April 2010 - 04:28 PM
Be careful as not all manufactures measure their wheels that was, some refer to the outside diameter of the rim not the centre section! Some even refer to the scale diameter. ie 15" !
SlotNZ has a spreadsheet with lots of this info on it!
Edited by kalbfellp, 29 April 2010 - 04:29 PM.
Posted 29 April 2010 - 04:53 PM
Ok. Rant over. Crawling back under blankey now.
gzminiz, on Apr 29 2010, 08:36 AM, said:
Any tyre will work on the NSR wheels if the correct size are used.My opinion the air system wheels
work the best by far.Just make sure you put the right MJK tyre to suit the 17''x10''.
regards shane a
team thunderbird
Posted 29 April 2010 - 05:03 PM
regards shane a
team thunderbird
I agree with ember. I feel lost and fear buying stuff that won't work. Like the looks of slotting plus America wheels but fear they won't work and the nsr is a whole kit so bonus.
#9
Posted 29 April 2010 - 07:25 PM
regards shane a
team thunderbird
Part number 4012 will suit your fly,but it dose not come with a pinion.
All are 17'' wheels but not sure on MJK tryes to suit.
regards shane a
team thunderbird
Edited by jazzbell, 29 April 2010 - 07:36 PM.
#10
Posted 29 April 2010 - 07:53 PM
If you have a look at Armchair Racers site and click on the Tyres section you can scroll down to the MJK tyres part and there is some info regarding tyre dimensions that you may find helpful in matching them up to the NSR rims.
I should add that I am not endorsing one retailer over another here but I thought that this info would be of use to GZminiZ and others.
Alan
#11
Posted 29 April 2010 - 09:29 PM
As to using MJK tyres on aero rims, not a problem. I run a couple of cars in this set up.
Chris at Thunder Birds can help if asked to match tyres and rims.
The club we run at is restricted to MJK tyres as a rule.
Good luck
Paul
#12
Posted 29 April 2010 - 09:36 PM
Again, I know... My fault for not being a fan of big beefy racers.
#13
Posted 29 April 2010 - 10:10 PM
Hi Ember
I think you will find MJK do offer narrow tyres, for ninco classic scalex classic, as I suggested to GZ have a look at the MJK tire section on the Armchair site they are all shown fairly clearly with dimensions,
Alan
ps I think it's time you put some numbers on your cars.
#14
Posted 29 April 2010 - 10:26 PM
And they've all got numbers on them... 3 of them... and 3 letters as well.
#15
Posted 30 April 2010 - 12:13 AM
I also think Graeme does as well.
Edited by kalbfellp, 30 April 2010 - 12:13 AM.
