Anybody had a spur gear spinning on the axle? I have a Ford GT which was moving really well and then slowly the lap times were slowing down. Upon inspection, the spur gear is spinning on the axle. Is there some type of glue I can use to hold it in place permanently or do I just go and change over to an aluminium gear?
Ninco Aw Spinning Spur Gear
Started by Yngwie, Apr 16 2010 07:20 AM
5 replies to this topic
Posted 16 April 2010 - 07:20 AM
Posted 16 April 2010 - 11:29 AM
web: www.wascrg.com
email: info@wascrg.com
web: www.wascrg.com
Posted 16 April 2010 - 01:06 PM
If $$ is tight, a small amount of super glue may hold it. don't get on the bearings... but the ninco alum gears will go straight onto the original axles. if $$ aren't a problems go NSR or Slot.it rear axle setup. You'll have to change everything from wheel to wheel because Ninco use a 2.48mm axle which is larger than the others
Posted 16 April 2010 - 01:16 PM
listen to Syd!!!!
Posted 16 April 2010 - 01:19 PM
Thanks Syd, Imugford and manimal. I know I should but the car was running so sweet!!!!!!!
Anyway, changes have been made. Car now has aluminium gear and is running fast but is a little noisy!
Posted 16 April 2010 - 02:44 PM
Im reliably told that you can get rid of the noise by changing the car over for a slotit.
