Basic Car Lights - Is It This Simple
30 replies to this topic
#1 Yngwie
  • 1617 posts
Posted 11 April 2010 - 02:49 PM
Hey all. I have a few host cars that I let the kids use when they come over and was thinking of giving them some lighting. I dont want anything fancy such as lights staying on etc. Just lighting.
So, if I have 4 leds that draw 3 volts each and my track is running at 12 volts, then I can attach them together without the need for a resistor! So
12V ------- +Led- ---- +Led- ------ +Led- ---- +Led- -------?
It is this easy to get 2 front lights and 2 rears working in a basic form?
#2 chenglaw
    Retro Racing Nut
  • 636 posts
Posted 11 April 2010 - 03:09 PM
I don't think wiring the lights in series would be a good idea. If one blows or there's a loose connection somewhere, everything will go black. I also took a simplistic approach when I wired up my Ford GT40 for a 3-hour enduro race but I wired up the lights in parallel, using just 1 resistor (hooked up to the common negative). This worked very well and I had no lighting problems throughout the race.
Lim
I do not lose races
It's just that they are won by someone else
Malaysia Slotracing Group
Law's Slotcar Home
#3 aussieslotter
  • 1606 posts
Posted 11 April 2010 - 04:28 PM
yup if you wire in series the last light gets more power. Parallel is better.
#4 Ember
    Diorama queen alert
  • 4155 posts
Posted 11 April 2010 - 04:46 PM
I'd also consider wiring a diode in so as not to blow the lights if car is put on track backwards.
#5 neophytte
  • 445 posts
Posted 11 April 2010 - 06:09 PM
This should work ...
Richard
#6 kalbfellp
  • 7186 posts
Posted 11 April 2010 - 07:46 PM
I seem to remember seeing THAT circuit some where before! :huh:
#7 Yngwie
  • 1617 posts
Posted 11 April 2010 - 07:51 PM
Diagram is just what I need. Just to clarify, is that 0.047 or 0.47? These dont seem to come cheap from my research!
#8 aussieslotter
  • 1606 posts
Posted 11 April 2010 - 07:58 PM
Are the red diodes brake lights? I guess not, not wired to motor.
Edited by aussieslotter, 11 April 2010 - 08:01 PM.
#9 aussieslotter
  • 1606 posts
Posted 11 April 2010 - 08:14 PM
Heres a brake light circuit.
Lots more on Slotforum.....
Edited by aussieslotter, 11 April 2010 - 08:14 PM.
#10 neophytte
  • 445 posts
Posted 11 April 2010 - 08:52 PM
View Postkalbfellp, on Apr 11 2010, 05:46 PM, said:
I seem to remember seeing THAT circuit some where before! :)
I think it was one of Ricks(?) circuits he posted ...
The capacitor will keep the power to the lights after a de-slot: http://www.jaycar.com.au/productResults.as...&SUBMIT.y=0
You could probably remove this from the circuit if you only want lights when you're on the track (or never de-slot!)
Richard
[edit] here is another URL: http://slotcars.carlsoncomputers.com/artic...otcarlights.asp
Edited by neophytte, 11 April 2010 - 09:29 PM.
#11 rick1776
  • 2605 posts
Posted 11 April 2010 - 11:14 PM
Richard
Theyre hard to find but I would get two 0.1F caps and connect them in series (this reduces the value to 0.05F but then you get 11V rating). That way you can get rid of the 5.5V zener and 150 ohm resistor. Put the two white LEDs in series and use a 560 ohm resistor. That will give you about 10mA current flow. Series up the two red LEDs and use a 1.2K resistor. This will give yoy about 7mA through the LEDS
That combo should give you about 10 seconds of lights if you deslot or power off.
#12 Bulsara
    2 hr Enduro Champion x 1
  • 1276 posts
Posted 11 April 2010 - 11:33 PM
I love the concept of "power off" stop lights. Plucka has a car wired this way and it is fascinating.
Gort, Klaatu barada nikto.
My poor Krell!
#13 kalbfellp
  • 7186 posts
Posted 12 April 2010 - 12:52 AM
The circuit above gives over 30 seconds of light when the car deslots. Althought the taillights tend to go out sooner.
#14 aussieslotter
  • 1606 posts
Posted 12 April 2010 - 08:38 AM
Yup brake lights are so cool, especially in the dark........
Edited by aussieslotter, 12 April 2010 - 08:39 AM.
#15 rick1776
  • 2605 posts
Posted 12 April 2010 - 08:44 AM
Have you actually built that circuit? That circuit draws about 60mA and has a RC time constant of only about 4 seconds. I coulnt get it to work effectively. It works dont get me wrong but it just died too quickly.
I suppose if you dont deslot its not a problem. :)
#16 Yngwie
  • 1617 posts
Posted 12 April 2010 - 08:57 AM
Rick, I found these and they are not too far from me.
0.1F Super Capacitor
Fairly pricey for only a handful but once you buy 10+ it is pretty reasonable. ANyone else want some so that we can get the price down somewhat?
#17 kalbfellp
  • 7186 posts
Rick: Most of my rally cars use that circuit,I think it came from a german site originally. I just translated it and sorted local components. Some where I also have one with working tailights.
#18 rick1776
  • 2605 posts
Posted 12 April 2010 - 10:31 AM
No probs Phil. Ive got a cct that I did where the tail lights go brighter when you hit the brakes on the controller. It works on my bread board but it really needs to run on 12V. The time constant is just too short with 0.1F and it doesnt work at 5.5V. I bought some 1F caps from Jaycar and the cct works a treat but the caps are 25mm in diameter, just too big. But John's find at Farnel is great.
John,
I think a better bet would be this one. Just mount it on its side, its .33F. You'll need 2 of them in series and this will give you .17F. At 11V this will work well. Only $2.38. If it helps you out put me down for 6. I'll even give you my cct for free.
http://au.farnell.com/panasonic/eecs0hd224...f-5v/dp/9692690
#19 Yngwie
  • 1617 posts
Posted 12 April 2010 - 10:40 AM
John,
Have you linked to the right ones Rick? Seems the one you have linked to are 0.22f and $4.21? Just checking before I get some! And would love a copy of your circuit!!!!!!!!!!!!!!
Edited by Yngwie, 12 April 2010 - 10:41 AM.
#20 kalbfellp
  • 7186 posts
Posted 12 April 2010 - 11:40 AM
Maybe we need a resources section where all these cct's can be found by anyone, we could include track wiring, sensor wiring etc.
Vinno, Bo etc what do you guys think?
