Troubles With Slot-it Controller
Posted 09 April 2010 - 01:23 PM
just having a problem with my controller.on 1 track at my local shop the controller basicly wont work.the car stop,goes 3/4 of the way round the track but seems to work fine down the straight.does it no matter what car i use but works fine on every other track.borrow a controller & the cars work fine.red light does come on when its playing up.any helpful advice appreciated.
warrick
Posted 09 April 2010 - 03:02 PM
Posted 09 April 2010 - 06:12 PM
It may be that the supply is unregulated, and the voltage drops under load.
I would ask the track owner to tell you details of the power supply, compare that to th supplies on other tracks, and also whether the track has the same wiring as his other tracks.
Posted 09 April 2010 - 07:39 PM
with no real interest on his part.probably as it only affects a couple of us with the slot it controller.what i really am after is if
i can narrow it down to the controller or the track?is it a design fault in the controller or is it just the track?
thanks for the info
warrick
Posted 09 April 2010 - 07:47 PM
Edited by aussieslotter, 09 April 2010 - 07:48 PM.
Posted 09 April 2010 - 10:07 PM
If the other controller that worked is a slot.it then not sure what to tell you
Posted 09 April 2010 - 10:26 PM
The red light comes on on my SCP-1 also.
Edited by aussieslotter, 09 April 2010 - 10:30 PM.
Posted 09 April 2010 - 10:52 PM
I can't say I know a lot about electronics - only that I had a similar problem car would fly down the main straight and then stop go around through the esses and through the small back straight before the hairpin - it seemed to do this more when I was working the trigger than if I held the trigger constant down the straight. It was suggested I try a regulated power supply and when I switched from a unregulated to regulated the problem went away.
This was Mark's explanation
by way of SlotsNZ -
"That Triang supply is un-regulated, and it throws out anything from about 10 to 20 Volts DC depending upon the load from the car. And it's probably not pure DC, but rather a crudley chopped square wave made from the stepped down AC out of the actual transformer. I bet that old supply didn't have a full bridge rectification circuit......
That sort of voltage at peak would cook the Slot.it, except that it has a couple of protective layers of electronics that shut the door on the power - within a couple of milli-seconds before the supply can do it any damage.
Then it opens the door, the excess voltage starts to rush in again, so it shuts the door again. Open, Shut,open, shut,open, shut....The bit that leaks through gets the cars going....It probably happens more with long can motors, or higher powered cars too......."
In the SCP-1 manual it talks about the ways the controller protects itself against damage - " So, the Slot.it SCP-1 continuously monitors the current drain from the track and cuts power if the current is higher than 6A. The situation is checked every few tenths of a millisecond, and if the short circuit goes away, power is restored. The 'diagnostic' LED flashes with one flash every two seconds while this condition is detected."
Edited by dangermouse, 10 April 2010 - 11:00 AM.
#9
Posted 09 April 2010 - 10:56 PM
#10
Posted 10 April 2010 - 12:18 AM
(cleaning up my mess)
Edited by dangermouse, 10 April 2010 - 10:55 AM.
#11
Posted 10 April 2010 - 07:02 AM
#12
Posted 10 April 2010 - 10:20 AM
thanks everyone so far for your thoughts.
warrick
#13
Posted 10 April 2010 - 10:43 AM
now the truth comes out
be worth trying to get the owner to check the wiring and setup on that lane then...I wouldn't want to damage my SCP-1 on a faulty track.
Edited by dangermouse, 10 April 2010 - 10:54 AM.
#14
#15
Posted 10 April 2010 - 10:50 AM
aussieslotter, on Apr 9 2010, 10:56 PM, said:
Edit: Just found out the 30A cartridge not available anyway.
