Hi Guys
I've just done a test run of all the cars for approximately one minute each to get a feel for them before the start of competition and give some comments on each of them. no times taken as the timing system isn't running yet.
1 Hoffy SA - Nice and Smooth, easy to drive. good power
2 Ben M NSW- Nice car but a bit down on power
3 Devious Dave NSW - Smooth but hard to keep up momnetum maybe heavy weight is cause
4 Old Slot NSW - A bit overpowered and top heavy, hit the scenery a few times
5 OTFS NSW - reasonably smooth but slight hop in corners under power NC1 might be a bit underpowered here
6 Teamredracer NSW - good pace but shudders in corners
7 The Stig Tas - lots of power from NC2 but struggled for grip on chalk board paint surface
8 Munter NZ- motor felts a bit light switch like. a bit sudden tended to tip often.
9 Ronan Ire - Reasonably quick but need to be gentle with throttle hops if given some "welly"
10 Lenny Broke SA- - Fantastic car can't understand why it's not further up the points order
11 ESPSIX Vic - Smooth , easy to drive
12 Silver Rocket WA - Bounces everywhere, probably due to wonky back wheel that has be glue on to axle several times
13 Gazza NSW - Very fast , may be too fast
14 Obsidith Vic - Quick bur Hi Cof G may hurt performance in official runs
15 Triggy SA - Nice car to drive but a bit tailymening its catching the rear corners on scenery and costing some time
16 Smallnails Tas _ Fast and Smooth but lost LHR wheel in hair pin 3 times. split hub the cause. will attempt a repair tonight.
18 FCC SA - Car lived up to owners forum name fast in straight line but tends to hurl itself at scenery at first sight of corner
19 Mexico NSW - not fastest car in field and a bit slidy but didn't deslot, could finish well this round
20 Phil K Tas - quick, has good grip from tyres.
21 Davenic74 Vic - Quick car but snags rear corners on scenery in bends
22 John Schoen NL- Seems abit short on brakes and lacks grip
23 Anthony NSW - Hard to get this car moving out of slower corners ,High Cof G and narrow track not helping handling
24 Yngwie NSW - Fitted replacement CW runs smoothly but car wants to bounce a bit in corners and fall over
25 Tazracer Tas - not real fast but feel it could run consistently to gain reasonable result
26 Tom and Cam SA - also not the fastest but stays in slot, should go well
27 BRK 12345 SA - Smooth and consistent here this car surprised me after seeing how it went in early rounds here
28 356speedster NO - quick car does not deslot easy but wants to whip sideways and snag in slot
29 Suttle SA - fast but not easy to drive smoothly, a bit jerky.
30 Blue 95 NSW - drives fairly consistently but rear tires are letting it down
34 Mannimal Vic - Quick but a bit inconsistent to drive.
Something that did stand out for me was the narrow tracked car with NC2 motors fitted. I reckon that the weight of the long can motors didn't help with the "tippyness" of these cars where as the wider cars like the 911 porshes were not affected.
Hopefully the timing will be up and running tomorrow night and ready for the prologue on Friday night.
If any of the local entries want to come over for a look over the weekend please let me know and I'll pm the address. I'll warn you that it's way out in the Wild West here so you good ole' Southern Boys might need the packed lunch and compass thing to get here.
Cheers Alan
ps I'm getting a bit weary right now, so I will do some pics tomorrow.
if you want a look at the track here' s a link to the construction thread I started a while back to give you an idea what the track looks like
norton hill
Edited by lenny broke, 07 April 2010 - 11:23 PM.
