Re-tapping Wheel Holes
Posted 05 April 2010 - 08:32 AM
Is there any trick to this?
Kind Regards
Posted 05 April 2010 - 08:39 AM
1-72 UNF (1.854mm)
2-56 UNC (2.184mm
3-48 UNC (2.515mm)
4-40 UNC (2.845mm)
M2x0.40 (2mm)
M2.5x0.45 (2.5mm)
Posted 05 April 2010 - 08:48 AM
Posted 05 April 2010 - 09:52 AM
only thing is to get them in that small of a size.
Not sure if you can get just the tap, or you need to buy the tap +die set.
Kai
Posted 05 April 2010 - 10:16 AM
Is something like this all I need? (3rd one down - Suits taps 2.5 - 5.00 for M2.5)
Posted 05 April 2010 - 10:52 AM
You can just buy the tap, and don't need tap and die set. The die is for threading external threads.
Taps come in 3 grinds for engineering. Taper, Intermediate, and Plug.
I would suggest just getting the Intermediate.
They are also usually available as a "Gun" tap used in tapping machines. You could also get the Gun tap, as it can be used by hand.
Unless you're going to do a lot of tapping, you don't need the tap wrench either. You can just a small shifter, although the wrench does make it easier.
The only other thing you may consider, are drills to suit the thread.
You can find this on Google buy looking for 'drill tapping chart' or similar.
Here are a couple, Here and here.
You should be able to get the drills from the same place as the taps.
Chances are that you may not need the drills, as you would be tapping out very little material, the tap should be OK.
Sunset Racing Shells
1/24 Scale Racing - Hornsby
SSME Slotcar Section
Sydney Society of Model Engineers - Luddenham
ASCRA - Slot Car Central, Australia
Aussie Retro.
Posted 05 April 2010 - 11:12 AM
Many engineering suppliers do not carry such small taps. Look at model engineering/train suppliers.
This guy is a good source of screws.
Kens suppies.
I could not find anyone with all the taps recently so ordered from the US.
Posted 05 April 2010 - 12:19 PM
This tap is what I have used, supplied from this website.
Gill is a top guy and you should have no worries in dealing with him.....
....he just won the Aussie 1/24 open title too.
ps I use a small T handle which I have had for years.
It helps keep the tap in position/vertical as I am turning the tap ino the hole.
#9
Posted 05 April 2010 - 12:27 PM
1) hold the rim firmly ...maybe in a softjaw vice
2) turn the tap forward 1/2 a turn and back 1/4 turn....I sometimes crank it in a couple of turns at the start before I do this backing off.
This 1/4 turn back clears the crap you have cut out of the thread.
3) some fluid can help...kero or light oil,crc maybe
4) keep it slow but straight
There are bound to be more so anyone feel free to add to this.
#10
Posted 05 April 2010 - 04:43 PM
#11
Posted 05 April 2010 - 06:11 PM
#12
Posted 05 April 2010 - 08:17 PM
Vinno, on Apr 5 2010, 06:11 PM, said:
I was about to say the same!
My Track- Early Construction
My Track- Almost There
My Track- Finishing Touches (Current Thread)
#13
Posted 05 April 2010 - 08:58 PM
#14
Posted 06 April 2010 - 02:11 AM
Running a tap into something as small as a wheel is tricky: very easy to get it crooked. I found it made it easier to turn the wheel on the tap, rather than turn the tap in the wheel. If that makes sense... I found that you can "feel" the wheel centering on the tap much better that way & I was less inclined to move/misalign the tap. Remember to twist the wheel backwards & forwards as per Munter's suggestion.
On the other hand, it might be that the only reason why I did it this way is that I come from the Southern hemisphere and I now live in the Northern hemisphere, so I tend to do everything bass ackwards.
#15
Posted 08 April 2010 - 11:12 PM
I put the rim in a smooth faced vice and drop an undersized drill bit into the existing tapped hole just so can make sure the hole is vertical and square.
I drill the hole to the right tapping size if necessary then I put the tap into the chuck, remove the drive belt and just rotate the chuck by hand as I gently feed the tap into the hole....reversing as necessary to clear the swarth.
The hole comes out "dead nuts".....
#16
Posted 09 April 2010 - 10:38 AM
sounds nice and precise.........just what you want .
#17
Posted 09 April 2010 - 08:33 PM
You only need one tap, a plug tap. Which is the middle one if you see three in a picture.
Technique do what Munter says.
For wheels despite what one may think if the holes is not completely perpendicular it won't matter that much so do not worry too much about perfection. If buying a tap wrench get a T handle as they are better for small taps but you can always unscrew the chuck from your DIY hand drill and use it. It is a bit bulky but free if you already have one. I had to make my own.
If you can't find any grub screw locally, www.modelfixings.co.uk will have them.
If you have never done anything like this before maybe look at this
I always knew that apprenticeship would come in handy for something.
Edited by FLY in the wall, 09 April 2010 - 08:36 PM.
#18
Posted 09 April 2010 - 08:55 PM
I only ever use a plug tap if im trying to get max depth in a blind hole.
Rob
