kalbfellp, on Mar 14 2010, 11:39 PM, said:
The LOTS racing club all use Trakmate!
I have been thinking about this and you could add a light operated from the track call button,so that is Green and one yellow that could be done. But still need to rely on Video display and Audio for the start sequence.
Yes, like Phil says, two colour is easy if you use a relay for track power. What you do is add another light-weight 12V DC relay which (like most) has terminals that are live on one of two outputs - basically a DPDT (double pole double throw switch), so that when track power is "off", the relay switching the LEDs will power some red or yellow LEDs, but when the timing software livens up the track, that same power source will trip the second relay which switches off power from the red or yellow LEDs, and gives power to a bank of green LEDs.
Dead easy - says the guy who hasn't even gotten around to hooking up the track power relay to his own track after 2 years
(my excuse is that the entire underside of my track is full of slotty stuff, jammed solid)
And as Rick says, the only way you'll get 3 LED colours in sequence, is if the timing software can drive some board/relays to do that for you in sequence.
