Shuddering Under Brakes
Posted 04 March 2010 - 07:57 AM
BtW, I have replaced the SCX pinion for a Slot.it one.
Posted 04 March 2010 - 08:02 AM
I had mesh issues with slot.it pinion and scx pro gear. I would try a slot.it running gear. not 100% if there is a difference in pitch or not.
Posted 04 March 2010 - 08:13 AM
Posted 04 March 2010 - 09:06 AM
Posted 04 March 2010 - 09:41 AM
munter, on Mar 4 2010, 09:13 AM, said:
Good call, I run a fair bit of brake with all my Nascars and they will tend to shutter alot more then when the brake is wound down, I just like it with more brake so I stick it out. One of those horses for courses kinda things.
Harry Hogge (Days of Thunder)
Posted 04 March 2010 - 11:37 AM
Posted 04 March 2010 - 11:47 AM
rick1776, on Mar 4 2010, 12:37 PM, said:
Problem is gearing has to remain the same in our class of racing.
Yeah I have the weight well set on the car and it is smooth out of corners and on straights just the little shudder approaching a corner. Will back of brakes a little but might have to put up with it as like lu05ke, I like full breaks on the SCX cars as they are good at it!
Posted 04 March 2010 - 11:49 AM
Rob
#10
Posted 04 March 2010 - 11:55 AM
Posted 04 March 2010 - 12:10 PM
Most of my South City raceway fleet are SCX with RX42B . I prefer to run no brakes on our tracks so wind the brake pot right off.
also if yoo are using slot it crown wheels I find that the standard 9T scx pinion meshed up quite nicely to the slot it crown wheels.
Cheers Alan
#12
Posted 04 March 2010 - 12:21 PM
rick1776, on Mar 4 2010, 12:55 PM, said:
I have a SLot.it controller Rick so do have adjustable brakes. Thanks Lenny, Have not tried changing the crown, but have changed the pinion. Might change to the Slot.it crown and see what difference that makes!
Posted 04 March 2010 - 12:42 PM
Lots I think you'll find.
Replace the whole rear end. I've replaced the gimble bearings too, for the SCX pro examples. 2 pair for about 5 bucks from memory. they have less float than the standrd ones when using slot it axles. I'd recommend a starter kit but slot it only do the 27 t crown wheel with plastic wheels for some reason.
Alan
Edited by lenny broke, 04 March 2010 - 12:50 PM.
