Slot.it Spur Gear On Scalextric Axle
3 replies to this topic
#1 Yngwie
  • 1617 posts
Posted 09 February 2010 - 03:24 PM
Is this possible? If so, which size, 18mm or 19mm is the correct one?
#2 chenglaw
    Retro Racing Nut
  • 636 posts
Posted 09 February 2010 - 03:51 PM
I wouldn't install a Slot.it spur on a Scalex axle - the serrations on the axle which hold the wheels on will destroy the concentricity of the gear hole. Better to use a Slot.it axle and their 19mm spur which should be a good size match for the discarded Scalex spur.
Lim
I do not lose races
It's just that they are won by someone else
Malaysia Slotracing Group
Law's Slotcar Home
#3 MOPARDEVIL
    Mopar or No Car
  • 1036 posts
Posted 09 February 2010 - 04:10 PM
Thats what Ive done. Ive also done a few cars with a slotit gear & piano wire for the axle. I was out of axles at the time & ended up leaving it.
Greg
#4 SlotsNZ
  • 3231 posts
Posted 09 February 2010 - 06:40 PM
Slot.it make a couple of kits for this purpose.
SIKK02 has the small hubs, with the 19mm spur, and SIKK04 has the large hubs also with the 19mm spur gear.
With the smaller hubs, the gear clearance to track with Slot.it tyres is pretty small, but for you ozzies, you'll probably throw an MJK with decent high profile on it anyway
