In this picture I have the pieces of circuit board cut out and ready for epoxying into the chassis for bracing. This was tip I picked up from another member on here, I can't remember who, but it works very well on our routed MDF tracks when racing Ninco Cars. I have had quite a bit of success in our group running with this set up.
I prep the chassis by removing the magnet mount and giving the chassis a sand to get good adhesion of the 5 Minute Aryldite I use.
I tape over the holes so that when I clamp the chassis down it doesn't stick to the surface.
As you can see I don't remove the copper coating on the PCB anymore as it is more work and doesn't cause any issues. This is a before Epoxy shot.
After seeing the Sloting Plus single piece axle bushing kit I thought I might try adding an extra piece of Circuit Board across the bushing mount to stiffen mthat area too. I fitted the Ninco 3/32 bushes first along with the axle to make sure all was aligned. Everything is Glued in place including the bushes, As the bushes have holes around the circumference you need to be careful when glueing. I now use a magnifying set of goggles to help as the old eyes seem to have lost their way a bit once I hit the 40's. The motor will also be glued once I have set up the gear mesh correctly.
I will put up some more pictures as I move along with the build. It was good to be able to do a bit of this on Australia day as it was too hot to do much else today, over 40 degrees again here.
