Redlands Raceway
15 replies to this topic
#1 B.P.
  • 16 posts
Posted 24 January 2010 - 07:10 AM
Hey guys/gals
This is my SCXD track which has been in construction for about 4 years. Its 4.5 X 2.4 metres and cars run between low 6's to 8's.
The table is on casters to roll in and out, and is accessible on all four sides.
The pit lane is fully functional and just about completed.
The scenery is very basic at this stage and is a work in progress.
Enjoy!!! I know I do :strain:
Also a quick note to say thanks to Adrian at RedRacer for sourcing all the parts. Cheers mate.
#2 Ember
    Diorama queen alert
  • 4155 posts
Posted 24 January 2010 - 01:04 PM
Sweet lookin' track. Are all those SCX lights still running on batteries or have you got them wired in?
#3 charlesx
  • 517 posts
Posted 24 January 2010 - 01:15 PM
Looks pretty extensive for a digital track. Appear to be umpteen cross overs. How do you get on for power. Seems to be a problem with digital tracks.
Chas Le Breton, NZ
#4 Obsidith
  • 595 posts
Posted 24 January 2010 - 01:17 PM
Nice looking track good work
#5 redvanth
  • 5 posts
Posted 24 January 2010 - 01:46 PM
Hey Chas
The SCXD system runs mehanical cross overs. The great thing is no power needed for lane changing.
I have had my track running with 3 power supplys which plug straight into the pitbox control unit run about 85ft of track 6 cars lap tower and a chronometer
with no troubles. SCXD is a very good out the box product. In the eraly years it was a bit crappy but the past couple of years it has become a great product and pretty much the best after sales service from all over the globe.
SCXD is great!!!
redvanth
#6 manic35
  • 2867 posts
Posted 24 January 2010 - 02:38 PM
Love you track layout, HUGE size!
Your pit lane looks great, I'm currently purchasing various Carrera pit lane buildings to complete mine.
Visit my slot site at: http://manicslots.blogspot.com/
#7 B.P.
  • 16 posts
Posted 24 January 2010 - 08:47 PM
Hey guys and gal,
Thanks for all the comments , I really appreciate them.
@ Ember, the lights are only battery operated at the moment, but are a crowd pleaser when dark.
@ chas , as Red says the SCXD system is unique in its lane changing mechanism. The cars change lanes not the track. You can put as many LC's as you want on the track with no ill effects to the cars power. Also it has a "powerline" which powers the other features (lap counter, chrono, fuel) independently.
Its quite a brilliant system am I'm surprised it hasn't taken off here in Oz.
#8 Ember
    Diorama queen alert
  • 4155 posts
Posted 24 January 2010 - 08:58 PM
Ok... Now that's making me way more curious about SCXD. Seem to hear an inordinate amount of whinging about the others.
#9 B.P.
  • 16 posts
Posted 24 January 2010 - 09:46 PM
Hey Ember,
SCXD is not a perfect system, it has its faults, but most of them are easily solved.
BTW. Anyone wanting to come and test it just PM me.
#10 charlesx
  • 517 posts
Posted 25 January 2010 - 10:38 AM
Ta for information Red and BP.
I have never heard of system. I had wrongly assummed it was digital with acronymn of SCXD (D for digital).
When you say changes not from track I assume they have separate power supply for lane changing. Sounds a bit like model trains.
How do you change lanes then and how does this impact on other cars apart from the one you are driving. Do changeover points return to straight each time or what?
Will try to find explanation on web but if you want to fill me in further that is fine.
Chas Le Breton
#11 redvanth
  • 5 posts
Posted 26 January 2010 - 11:33 PM
Hi Charles
You are right it is digital.
I am a huge SCX digital fan. I am so happy that i chose this system. As BP stated its not 100% perfet but i feel its pretty close.
Ill try my best to explain how the system works.
You can run up to 6 cars at any one time on 2 or more lanes. Each car has a digital chip. On top of this digital chip is a small arm know as the LC ARM ( lane change arm).The LC arm moves up and down by pressing a button on your controller. The guide pin in the car has a small dropper/plunger. When you press the Lane change button on your controller the LC arm goes down which in turns presses the dropper/plunger down.
Now in the cross over peices on the track they have a small lever in the slot. When your cars LC arm presses down the plunger this then hits the lever in the crossover peice and makes the guide pin in the car change lanes. So once your guide is through,the lane returns back straight. No car can follow you unless they also press there lane change button. Also these lane changes can go anywhere, and you can have as many as you like. even if your sliding you can still activate a lane change.
So the lane change requires no power at all. It is totally mehanical. The entire system relise on the digital chip. If you need a replacement chip the cost is only about $25. or if your handy,i just replace a small part on the chip for $1.85. Occassionally after lots of crashes the cars get damaged. No matter which system you get you have this problem.
The entire system runs on 1 2 or 3 power supplys. 2amps 18v each.
Unlike other systems if you added accessories like lap towers lighted bridge chronometers these do not take away from the cars power, SCXD has whats know
as the powerline. This is an independant line of power running seperate to the track power.This power line is built into the track peices. To the naked eye it not really noticeable. This power line controls the accessories. This is how they can get the system to work with no power loss to the cars.
Out of the box this is by far the best system available. The standard pit box set up will allow you to program braking on the cars, set the fuel tank limits per car
and individual car speed programming. The individual speed programming is great when i race my kids, I can race in full speed and they can be in precision(kids) mode.
Some of the great features are the qualifying options. This is good to pre deterime the starting grid. Another good feature is the when a car begins to run out of fuel it begins to spatter. The car will actually run really jerky and hobble back to the pits. if you dont make it back then your out of the race. Also the car will drive differently with a full tank of petrol. Once you start to burn fuel the car will become faster hence less fuel means its lighter.
SCX have really worked hard to perfect this system. At first it was a bit crappy but they have worked really hard to make better cars and better digital accessories. The Scxworldwide.com website is great place to get info. the tech support on this site from the mangement from SCX is fantastic.
Australia has a new distributor and he is really good and helpful so I look forward to a good future in Australia for SCX
Hopefully my info has helped.
Redvanth
#12 charlesx
  • 517 posts
Posted 27 January 2010 - 06:57 AM
Not sure whether it is my scene but sounds interesting. Have also been readfing about Scorpious system which can have a lot more cars still.
What sort of delay is there in digital response so you can change lanes? Will have a look at the website you mention.
Chas Le Breton
#13 redvanth
  • 5 posts
Posted 27 January 2010 - 08:07 AM
Hi
to me it seems to be pretty much instant. I have noticed no delay.
thanks
red
#14 charlesx
  • 517 posts
Posted 27 January 2010 - 08:11 AM
Ta Red. Thought there might be delay like servo. Seems there are a lot of moving parts to go wrong but I suppose that is the nature of the beast. From what you say still very reliable.
Chas Le Breton
#15 B.P.
  • 16 posts
Posted 02 February 2010 - 05:32 PM
View Postredvanth, on Jan 26 2010, 11:33 PM, said:
Hi Charles
Redvanth
Yep, I think you got it all. Couldn't have said it any better.
#16 kjd
  • 2 posts
Posted 19 October 2010 - 11:13 PM
hello my name kevin im new to scx digital great track,im also starting to build my track slowly wher did you buy the track scenery from cheers kevin
