Perth Hills Rally Track
69 replies to this topic
#1 silver rocket
  • 413 posts
Posted 15 November 2009 - 04:53 PM
My rally track is starting to take shape so I thought I'd post some pics up...
Track Info
Not sure how many feet it is in length as I haven't measured it yet & I have more track than pictured with heaps of layout options. It is setup on a ping pong table & I've only just started playing with layouts but this stage works pretty good, is quite technical with lots of stop start braking & cars that slide well do good, the super sliding curves are awesome & I plan to add more. A good lap in a non-mag car is about 17 seconds on this layout.
Surface: 75% SCX 25% Scaly Sport.
Hand Control: SCX Pro with either 20 or 45ohms, I mainly run 20ohms...
Scenery: So far I have made some guardrail advertising panels, one background & I have about 90 pine trees so far & I'll add more as I go. I will add grass, buildings & WA road signs etc as I can, a work in progress.
I'd will also paint the track surface to suit the rally style...
Problems
Power: I had was some power issues once I got over about a 12 second lap time but this was sorted with some soldered power taps and I will eventually finish the track with copper tape once I'm happy with the layout.
Timing: The SCX Rally Chrono pack is really good, I rate it highly & would recommend it to anyone. It is well priced, easy to use (only has two buttons) and it times to hundredths, tells you total time, fastest lap & average lap speed. Only problem was that it only times mag cars but this was easily solved by adding a small mag held onto the car with some blu tac about headlight height. Mounted either front or rear it trips the timing without adding traction to the car.
That's it so far so here are a few more pics, hope you enjoy & any constructive critisicm to help make it better is welcome...
#2 kalbfellp
  • 7186 posts
Posted 15 November 2009 - 05:33 PM
Looks good.
Is that the track for the WA round of the Ozrally proxy?
If so what are you going to do for timing the proxy cars?
Edited by kalbfellp, 15 November 2009 - 05:33 PM.
#3 Ember
    Diorama queen alert
  • 4155 posts
Posted 15 November 2009 - 05:36 PM
Whoo hooo! Just need to add some good ol' WA pea gravel and watch 'em fall. Looks like fun.
#4 Davnic74
    Trying to remember how to tune a car!!
  • 2652 posts
Posted 15 November 2009 - 05:38 PM
Looks good SR, great photo's, have you thought about changing your timing setup to avoid adding mag's to cars?
Aastes (forum member) could have a Startline system to suit a 1 lane rally setup.
Edited by Davnic74, 15 November 2009 - 05:39 PM.
Regard's
4 x Aus National Champion...
Premier Raceway Build
Gallery Raceway Build.
Heany Park Raceway Build
#5 silver rocket
  • 413 posts
Posted 15 November 2009 - 06:05 PM
Looks good.
Not 100% sure yet as it hasn't been confirmed but yeah I'm hoping to host a round on it...
Eventually I'll probably get another timing system but I just haven't had the time (two jobs, kids etc) & the SCX one is accurate & reliable so I'll use it for now...
Yeah when I paint that will be my colour scheme...
Yeah as above, will do when I can, the whole track is no where near what I want as a finished product this is just the start... ;)
#6 triggy
    Triggy
  • 1254 posts
Posted 15 November 2009 - 08:38 PM
Can you easily reach the middle area to marshall cars that may come off in the loop and curves?
Normal people worry me
#7 silver rocket
  • 413 posts
Posted 15 November 2009 - 08:44 PM
Yeah easy, the table is only 1.55m wide so I can nearly reach all the way across & u can walk all the way around anyway. I just blacked out the background casue I'm a painter & I have a messy shed atm ;)
#8 lenny broke
  • 1624 posts
Posted 15 November 2009 - 10:41 PM
View Postsilver rocket, on Nov 15 2009, 06:35 PM, said:
Looks good.
One of us has missed something here Ira
As far as I'm concerned you are round 3 of the series as listed here
ORPS 09/10 tracks
Regards Alan
home track club racer
#9 Obsidith
  • 595 posts
Posted 15 November 2009 - 10:49 PM
its abit worrying that this round is soon and no real timing system is running yet
but your track is looking good
#10 silver rocket
  • 413 posts
Posted 15 November 2009 - 11:52 PM
I'm not sure why people keep questioning the timing system? It measures down to hundreths, saves your best lap, total time, average lap time & you can run 1, 5, 10, 15 or 20 laps, what else does it need to do?
The mag problem only effects cars with sidewinder motors as the magnet from a normal motor is still enough to trip the timer, it doesnt need a strong mag to trip it....
Am I missing something?
#11 kalbfellp
  • 7186 posts
Posted 16 November 2009 - 12:21 AM
Yes,
the timing system needs to work with all the cars without having to add anything to the cars,so you really need either a dead strip,optical sensor,reed switch or similar to operate the timing system.
Edited by kalbfellp, 16 November 2009 - 12:21 AM.
#12 Syd
    Syd
  • 705 posts
Posted 16 November 2009 - 04:54 PM
If you have an old computer I could help you out with SlotRaceManager
web: www.wascrg.com
email: info@wascrg.com
#13 kalbfellp
  • 7186 posts
Posted 16 November 2009 - 06:48 PM
I think the SCX system is fine only needs some sort of better sensor added.
#14 Captain
    WASCRG
  • 308 posts
Posted 19 November 2009 - 10:12 PM
Lookin good Ira. It looks like you are putting some thought into the layout. I'm not overly familiar with rally tracks, but it looks like you can fit fairly lengthy tracks into a small space. Once you start painting it, and making things a little more permanent (if that is the plan) it will really look liek a rally stage. Nice job.
Kirk
Web: www.wascrg.com
Email: info@wascrg.com
Mob: Syd 0413 020 421 or Dave 0439 900 764
#15 silver rocket
  • 413 posts
Posted 22 November 2009 - 10:48 PM
Kirk
Thanks Kirk, yeah I've got some more track ordered & with some elevations added I reckon you could easily get a 25 second single lap just on a table tennis table. But yeah it will all be permanent once I get a layout down pat. I've experimented with various layouts & it's quite surprising just how you can change the feel of a stage by doing a few simple things. One really fun stage is the three drift curves back to back no straights & a loop on each end. sooooo flowy, after ten mins u can like go into a trance.... I've got more drift curves ordered they are awesome to drive, a real rally feel.
My overall theme will be the Perth hills where I live & the Rally Australia stages that were run on them for years. IE lots of sliding drifty curves (pea gravel), hairpins, flyovers & jumps... Only just started experimenting with jumps, step downs seem to be the best so far for keeping the car on...
Oh & I'm getting a reed switch fitted this week at Stanbridges so that the fun police don't cancel my ausproxy round....
It will be copper taped by then also so no power dramas either....
edit: forgot to say when it's done you guys will have to come round for a play & some rally fun....
Edited by silver rocket, 22 November 2009 - 10:51 PM.
#16 Bulsara
    2 hr Enduro Champion x 1
  • 1276 posts
Posted 23 November 2009 - 01:16 AM
The track looks fabulous, too bad I am on the other side of the continent. As for the 'fun police', some people are wired negative earth and the ones who enjoy life are wired positive earth. Stay positive my friend and ignore all the doomsday predictions. You have done a wonderful job and your round will be great.
Are you sure you are in Perth? Where are the sandgropers on the layout? LOL.
Gort, Klaatu barada nikto.
My poor Krell!
#17 GTR XU-1
  • 557 posts
Posted 01 December 2009 - 12:12 AM
Looking good Ira. A bit of scenery and that will be a mint complex little rally stage. Are you going to go with a dense forrest for the scenery like the Perth Hills? It may cost a bit. You could get around it by doing a more gravelly field. We have used a product that gives a really good gravel look if you want to go with something like that.
I have four rolls of copper left over by the way so when you are ready give me a yell if you want it.
Dave
web: www.wascrg.com
#18 GTR XU-1
  • 557 posts
Posted 05 December 2009 - 12:49 AM
Ira,
Would you ever consider doing a dirt affect like this...
I dont know the ins and outs of having the dust over the track but I think it looks mint. The gravel product would worok really well if you glue it to the track first and then have some 'loose marbles' as well. Alternatively, if the loose marbles arent your bag, then you could probably laquer the gravel over the track to give a gravel type surface anyway. You can check out Copper Mill Raceways gravel traps using the same product tomorrow night anyway.
Dave
web: www.wascrg.com
#19 356speedster
  • 340 posts
Posted 05 December 2009 - 02:34 AM
The "Spaniards" use Cocoa, Corn meal and flour on the "dirt tracks".
We are doing one round on "dirt" in the SCX Classic Rally Proxy series, but that is scheduled to the last event, because the cars need to be seriously cleaned both before and after the dirt stages.
#20 silver rocket
  • 413 posts
Posted 05 December 2009 - 12:10 PM
Thats a cool video hey Dave one of my favs, it's slightly slo mo but which means your eye sees more details than normal time but yeah it's still a cool vid. I'll def experiment & use something like that eventually or maybe just for one off events as I think you need to seal up the engines, Torre knows more about this & he may be able to shed some light on the subject..
To answer your previous post it won't be all trees but I want a tree section where you go into some dense trees & then come out again. It will have various scenery, lots of gravel (thanks for the offer of that gravel stuff will grab it tonight) some rocks, a few buildings, a workshop etc. Found these wheels yesterday on a car at a budjet shop for $12
Got the idea from your tractor tyres & kept a look out :P I'll sand back the wrangler text so it just says goodyear & painted white with rusty metal inserts instead of silver I reckon they will come up okay, $3 a pop can't go wrong & they are about the right size too...
Torre you posted some pics on SCX worldwide forums in one of the proxy threads showing a painted track sayin it was the track for the last round which would be a "dirt" rally, I looked but couldn't find them again if you would so kind to post one here or the link to one, Dave this track looks really nice & is what I'm aspiring to achieve.
Also Dave check this for a cool hill climb track
& another one of my favs
In terms of undulations my track will prolly look something like this http://www.youtube.com/watch?v=BseRaZn7mn8&feature=related with rasied up bits to fit more track in.
My table is currently 1.5m x 2.4m but I've got a sheet of mdf that is 2.4m x 4.2m so I'm thinkin I will put it on this board and just lay that on top of the table tennis table with some corner supports. By my rough calculations I reckon I could fit get a one minute lap in this space, but yeah thats the final plan....
See you tonight Dave! :D
Edited by silver rocket, 05 December 2009 - 12:13 PM.
