Ozrally Proxy Series 2009/10
4 replies to this topic
#1 lenny broke
  • 1624 posts
Posted 10 August 2009 - 06:21 PM
Hi Guys
I'm pleased to announce the running of Ozrally Proxy Series for 2009/10
Below you will find the Rule and Eligible Car List. These may be slightly updated or amended for a short period but will be "locked in" at a date to be confirmed
Please read and understand the rules. They are fairly free and open but what there is will be strictly enforced.
You may have noticed a change of name from last year. This was done to differentiate this series from the Down Under Proxy Race Series.
There are some things that are listed as TBA these are yet to be finalised but I thought I would post the main rules so you can have a heads up and make a start on an entry or decide to participate in the series.
The series is expected to begin in early November and round run on a fortnightly basis (or as close as possible to).
If you have any queries please contact me and I will endeavour to answer them.
Cheers Alan
home track club racer
#2 lenny broke
  • 1624 posts
Posted 10 August 2009 - 06:23 PM
OZRALLY PROXY SERIES 2009/10 RULES
This years Oz Rally Proxy Series will be open to cars that competed in the International Manufacturers Championship, World Rally Championship, Australian and European Rally Championship.1960 to1997. see list of eligible cars.
Entrant's cars shall comply with the following rules
The onus is on the entrant to ensure that their car complies with the rules.
There will be no allowances if you cannot make a particular model comply even if it is on the eligibility list.
Please think carefully about your choice before deciding on what to enter.
1. Body
A Body must be as original RTR. no additional material to be used to modify the body. added 11.49pm 11/08/2009
B. The body to be fitted with a 3 dimensional interior consisting of at least a driver and co/driver ( head and shoulders), steering wheel and 2 seats Vac form plastic is acceptable.
C. All cars must have all windows, as fitted to the original 1:1 scale prototype. The window material must be transparent. Vac form plastic is acceptable. Plastic pieces glued individually to the window frame is acceptable but must be fixed securely to the body shell.
D. No resin bodies allowed.
2. Wheels & Tyres
Wheels are open to any brand but must have a wheel insert or be a one piece wheel with sufficient detail to represent the style of the period of the model.
Tyres are open to any brand of rubber or urethane tyre. Example tyres include Ninco, SCX, FLY, Scalextric, Cartrix, Proslot, Slot.It P Series, Ortmanns, MJK NSR supergrip & ultragrip (This is not a complete list, if you know of a tyre that is rubber based let the organizers know.).
A. Silicone tyres are prohibited eg; PPR Super tyres, Slot.it S1's, Puma Paws, Indy Grips, etc.
B. Foam rubber tyres are prohibited eg; tuna type.
C. Wheels and /or Tyres shall not protrude beyond the outer edge of the wheel arch opening...
As there has been some controversy about this issue last year this rule will be strictly enforced.
3. Chassis
A. The original RTR chassis as fitted to original body of the car must be retained.
B. Traction Magnets are prohibited.
C. No aftermarket or scratch built chassis allowed, plastic or otherwise.
D. Chassis may be braced as required with a non metal material.eg plastic or PCB sheet. Brass, aluminium, steel or any other ferrous metal and carbon fibre are not permitted.
E. No motor pod will be allowed this year unless it is an original fitting.
F. Guide flag mount may be replaced but pivot point must remain as original
G. Ground clearance- a starting clearance of 1.6mm under chassis with a minimum clearance of 1.2 mm under the chassis including the gear.
H. The entrant's name must be indelibly written on chassis. Either your forum name or real name.
4. Weight
No limit on weight. Ballast must be firmly attached. Ballast fixed under the chassis must be completely covered with tape
5. Motors
Open motor choice
6. Other Parts
Open choice of body mount screws axles, gears, guides and braids.
7. Technical Inspection
All cars will be inspected by the series director before the first round for compliance with the rules.
The onus is on the entrant to ensure that their car complies with the rules at the tech inspection.
Should a car not comply the entrant will have the option of having the problem fixed by the organiser, have it returned for the entrant to rectify or withdraw.
8. Modifications Repairs & Pre-event Checks To Cars During The Series
A. Once a car has passed a technical inspection its technical specification cannot be changed.
Specifically:
Gear ratio.
Motor spec,
Guide type,
Wheel / Tyre size and compound.
An allowance will be made before the series begins to correct a technical spec that is in breach of the rules
B. In the event of a mechanical failure, components can be replaced but must be of the same spec as originally entered..
C. Body screws will be checked, bearings lubed, tyres and braids cleaned and set before each leg of the series by the track host. Tyres will be cleaned by spinning the wheels up on a wet sponge, no solvents or oils are to be used to clean tyres.
10 Series Point Scores
The points will be awarded as follows:
1st 36 pts 7th 26 pts 13th 18 pts 19th 12 pts 25th 6 pts
2nd 33 pts 8th 25 pts 14th 17 pts 20th 11 pts 26th 5 pts
3rd 31 pts 9th 22 pts 15th 16 pts 21st 10 pts 27th 4 pts
4th 29 pts 10th 21 pts 16th 15pts 22nd 9 pts 28th 3 pts
5th 28 pts 11th 20 pts 17th 14 pts 23rd 8 pts 29th 2pts
6th 27 pts 12th 19 pts 18th 13 pts 24th 7 pts 30th 1pt
11. Conditions of Entry
A. There is an entry fee, which is $15.00 AUD for Australian entries (excl. Sth Aust entries), $11.00 AUD for Sth Aust & International entries (incl NZ entries). Australian entry fee includes return postage. Overseas entries return postage to be added to entry fee and paid when event is finished. The sole purpose of the fee is to cover postage costs of cars from one state to the next. If any money is left over at the conclusion of the series, it will be donated to a charity nominated by the organizer.
B. Entries will close on 16th Oct. (4 weeks before the first round). Entry fees will need to be paid by 16th Oct (4 weeks before start of first round) This is to ensure that people do not enter and then fail to send in a car, so denying others an entry spot. Entry fees are not refundable. Consideration may be given in exceptional circumstances and would be at the discression of the organiser
C. Cars will need to be with the series director by 30th of October for Tech inspection and allow sufficient time to rectify any issues with entrants cars
postal address will be supplied by email with payment details
D. Contact Lenny Broke via Auslot PM or email (lbroke@msn.com) for the postal address and bank details. Pay Pal is available to overseas entrants.
E. Entries will be limited to 30 cars One entry per person.
F. Entrants will be invited to enter in the following order to prevent a first come first served scenario and people missing out because they weren't online at the right time.
1. Those that entered last year and supported the event will have first option to enter again. Expressions of interest close 12.00am friday 22 August
2. Australian and NZ members of Auslot who did not enter last year will be invited to enter next.
3. New International entries are welcome after that.
4. A reserve list will be used to fill vacant spots if required.
12. Misc. notes
A. When sending car please do not use a plastic "crystal case to hold you car. A small cardboard box with the car well wrapped in bubble wrap will suffice.
B. Please do not send any spare parts with car as in the past they have had a tendency to go missing.
C. All cars will receive numbers (Label paper, stickers will be attached to each car at round 1. Cars from last year will be allocated a number from last years finishing order). Entrants new to the proxy rally will be allocated numbers in sequential order upon receipt of entry.
13. Tracks and Hosting a Round
A. Tracks are to be purpose built single or dual lane rally tracks. Multi lane race tracks with rally circuits ok, provided the track is considered 'tight and twisty' and no long straights.
B. Tracks are to have smooth surfaces. Elevations encouraged but extreme rough track surfaces that disadvantage some brands of car are not welcome. We are looking for a wide variety of makes and models and not a field dominated by one model only.
C. The intention is to run the rounds at 2 week intervals Your round should be run by the next week end after the cars have arrived at your track. Posting on of the box of cars should be in time to arrive at the next round in plenty of time to run the round.
D. Each days driving should be reported back to the forum when completed.
E. An official score sheet should be completed and forwarded via e-mail to the director at the conclusion of your round. A template will be forward to you by the director before the commencement of your round.
F. The postal addresses of next round host and reimbursement for postage costs will be forwarded to hosts by the series director, Lenny Broke at the conclusion of your round if required.
G. Track owners to run cars against the clock for a minimum of 8 minutes per round. You can break this up into as many stages as you like, for example, stage 1 on a Friday night, stages 2 and 3 on Saturday night and stage 4 on Sunday afternoon. An additional driver (co driver) may be used to assist in driving at least one stage but must complete a full cycle of cars through that stage. Stages can vary in length and direction, just as long as the total time for the fastest cars is approximately 8 mins.
If you are unsure how many laps to run to total 8 minutes of driving?
Work out the best lap time you expect from a car in this field. Say 6.00 secs. How many laps will the fastest cars have to do be on track for 8 mins? 8 mins is 480 seconds so 80 laps total is a fair guess.
14. DISCALIMER
Entrants should understand that no responsibility is accepted by the organisers, hosts or participants of the OzRally Proxy Series 2009/10 for the loss and/or damage to your cars or parts/equipment supplied either before, during or after the series is conducted.
Edited by lenny broke, 25 August 2009 - 10:29 PM.
#3 lenny broke
  • 1624 posts
Posted 10 August 2009 - 06:25 PM
OzRally Proxy Series 2009/10 Eligibility List
1960 - 1997
Alfa Romeo GTV Fly
Alfa Romeo Alfetta GTV GOM
Alfa RomeoGiulia sprint GTA Team Slot (plastic)
Audi Quattro Fly SCX Team Slot (plastic) Revell
Austin Healey 3000- Hardtop Ninco
BMW 2002 Spirit
BMW M3 Fly SCX Scalex
Fiat 124 Spyder SCX
Fiat 131 Abarth SCX
Ford Cortina GT Scalex Revell
Ford Escort MK 1 Scalex
Ford Escort Mk2 SCX
Ford Escort RS Cosworth Scalex SCX
Ford RS 200 SCX
Ford Sierra RS Cosworth SCX
Lancia 037 Fly SCX
Lancia Delta S4 SCX Team Slot (plastic)
Lancia Stratos Team Slot (plastic) SCX
Mercedes 220 & 300 SE Revell
Morris Mini Cooper Scalex SCX
Opel Manta 400 Sloter
Peugeot 205 T16 Spirit
Peugeot306 Spirit Ninco
Porsche 911s Fly
Porsche 911sc Fly Ninco
Porsche 934 Ninco
Renault Alpine A110 SCX Teamslot (plastic)
Renault Megane (not cup car) Ninco SCX
Renault 5 turbo Fly SCX Spirit Team Slot (plastic)
Renault 8ts SCX
Renault Clio (not super version) Ninco
Subaru Impreza SCX model #83950
Talbot Sunbeam Lotus SCX
Toyota Celica GT4 Ninco Team Slot (plastic) SCX
Triumph TR-7/8 Scalex
VW Golf Spirit
Edited by lenny broke, 19 August 2009 - 10:42 AM.
Update list 19/08/2009
#4 lenny broke
  • 1624 posts
Posted 14 August 2009 - 02:21 PM
Hi All
Just an update on some details. see also the rules
The entry fee has been set at $15.00 AUD for Australian entries and $11.00 AUD for O/S entries (Kiwis count as O/S)
The First Round at Limestone Pass will be held on Friday the 13th of November. (who's superstitious :huh: )
Entries close on Friday 16th Oct. Entry Fee's should be paid by this time also.
Cars should be received by the organiser by close of business Friday 30th Oct.
Cheers Alan
#5 lenny broke
  • 1624 posts
Posted 15 August 2009 - 12:42 AM
Official Entry List as at 18/10/2009
1 Hoffy SA paid
2 Devious Dave NSW paid
3 Old Slot NSW paid
4 The Stig Tas paid
5 Teamredracer NSW paid
6 OTFS NSW paid
7 Lenny Broke SA paid
8 Ronan Ire paid
9 Phil K Tas paid
10 Davenic74 Vic paid
11 Smallnails Tas paid
12 Gazza NSW paid
13 Triggy SA paid
14 Tazracer Tas paid
15 Anthony NSW paid
16 Mexico NSW paid
17 Haystack Tas paid
18 Ben M NSW paid
19 Silver Rocket WA paid
20 Yngwie NSW paid
21 Munter NZ paid
22 FCC SA paid
23 BRK 12345 SA paid
24 Blue 95 NSW paid
25 espsix Vic paid
26 John Schoen NL paid
27 356speedster NO paid
28 Mannimal Vic paid
29 Suttle SA paid
30 Obsidith Vic paid
31 TomandCam SA paid
31 paid entries
Updated 29/10/2009
Edited by lenny broke, 29 October 2009 - 05:53 PM.
update list
