Jaak
Sloting Plus Motor Test
Hi all,
I have two of the Sloting plus motors.
The Rally (SLPL 2200) and the Speed (SLPL 2201)
And since there is not much known about them i thought i would do a test.
I also have a new rpm checker for a few months now but never used it :o
I thought this would be a good opportunity to test my new gadget and see what the motors do.
So i had made a device to fit on the engines to measure there rpm's with my rpm checker.
version #1
Simple but effective, i used and old pinion which i jammed into the back of this sanding disk.
placed a plastic piece of reflective tape and of we go...:)
one little thing :o
That disk flying around at more then 20.00rpm did not make me feel that comfortable :lol:
So version 2 came to life...
Simpler safer and easier to work with.
I used an old tooth wheel taken out of an old car CD player,
it fits perfect on the axle and allows also to have a little piece of reflective tape to be attached to it ^_^
OK so back to the testing....
Engine #1
The Sloting plus Rally (SLPL 2200)
18.000 rpm @ 12V
With 230g/cm torque
160ma
I tested it at two different heights of voltage..12V 1200ma & 16V 800ma*
*standard Scaley sport powerbase
At 12V i tested:
21530 rpm as highest rpm.
21330 rpm average rpm over 30 seconds.
At 16V* i tested:
27693 rpm as highest rpm.
27609 rpm as average rpm over 30 seconds.
Engine#2
The Sloting plus Speed (SLPL 2201)
21.000 rpm @ 12V
With 210 g/cm torque
190ma
I tested also tested this one at two different heights of voltage..12V 1200ma & 16V 800ma*
At 12V i tested:
27316 rpm as highest rpm.
27155 rpm average rpm over 30 seconds.
At 16V* i tested:
34707 rpm as highest rpm.
34693 rpm as average rpm over 30 seconds.
Overall appearance. they look very well made, i also like that the details 'burned' into the motors,
a good plus is the opening for air allowing plenty of cooling and easier cleaning.
I also had a look at there magnetic pull.
But i did that in a simple way as i do not have a Magnetic force meter yet (gauss / Tesla)
I compared them with a Ninco NC 5 on a Scalextric sport track piece and i found that they have significant more magnetic pull then a NC5.
So all in all i think these motors will be a good contribution-contender in the rally and roadrace scene.
Jaak
THINGIEPHILE REBEL EXTRAORDINAIRE
Hi all,
version #1
one little thing :o
Engine #1
18.000 rpm @ 12V
With 230g/cm torque
160ma
At 12V i tested:
At 16V* i tested:
Engine#2
21.000 rpm @ 12V
190ma
At 12V i tested:
At 16V* i tested:
Jaak
Hi, I was going to ask if you have a Slotting Plus Speed 2 motor to test, but I guess if you had you most likely would have shown it and the results along with these. I have just got hold of one of these motors and it would be nice to know what the performance is on paper and what your opinion is of the motor in general and compared the the other motors in your tests.
Could someone else copy all this again then we can go for the Guinness Book of Records longest thread of mindless drivel. Welcome back Jaaak, where you bin we've missed you. :lol: :lol: :lol:
Ashes to ashes funk to funky we all know Chris is a junkie.
Yes and the test results are way off target!
I recently tested the Rally motor for my Oz Rally car and it tested at 17,300 RPM at 12volts.
I also ran test on the 21,000 motor and that was also about 500 RPM over spec!
I suspect that the power supply he was using was not regulating very well.
Mark: If you use the large Reverse type REPLY link at the bottom of the page it will not copy all the previous thread and saves a lot of bandwith.
Hey hey,
Thanks Chris ^_^
Phil,
My test was acurate but using a Standerd scaley power suply as stated in my post,
which is rated at around 16V not 12V.
Edited by Jaak Beentjes
Jaak the Scalex power base don,t have any real regulation. You should run the tests again when you get your nice new regulated supply.
When testing motors I turn the supply on for about 10 minutes as the voltage will vary by about 0. 3 to 0.4 volts as the power supply temperature changes,so I wait for it to stabilize before running any tests.
