The Making Of 'igual Track 3'
7 replies to this topic
#1 Jaak
    Slotalot
  • 446 posts
Posted 05 August 2008 - 04:56 AM
Hi all,
It is finally time to begin my 3d permanent track after Handytrack 1 and Handytrack 2 i decided it needed a different name,
since the lanes 1 and 2 are exact equal to each other i chose a Portuguese style name for it hence the name Igual Track 3,
Igual is Portuguese for equal, this one will be a slow progress version.
First of all the layout and room.............(some pictures have been shown in a other thread)
This track will probably be modified later, i just need to source 8 pieces of Straight to lengthen the middle piece so that the inners corners come to the corner
on the outside giving longer straights.
I also need two 6car Digital Power Adapters 4 R2 corners to take out the change overs and i need 2 border barriers extra ,
anybody that has any of this for a good price PM me.
The track now has 41,5 pieces of straight and 26 R2 corners.
The pictures show the style of layout,it Will be a combo Digital Analog track.
Because it is also analog i wanted it to be equal on both lanes i will convert both power bases later on in such a way that i can keep them both in the track,
this will also mean i need to convert my lane changers etc, all that later on.
Here is a picture of my other Slotcar room where my collection is and where i do my tinkering and building
Work place..............
And my collection............(some cars missing due to missing parts )
More will follow....
cheers,
Jaak
Posted ImagePosted Image
THINGIEPHILE REBEL EXTRAORDINAIRE
#2 slots
    Looking for sanity
  • 2465 posts
Posted 05 August 2008 - 07:04 AM
Hey Jaak, looks good. Done right I can see some serious elevations there
#3 Jaak
    Slotalot
  • 446 posts
Posted 05 August 2008 - 08:38 PM
Hey Stu,
Thanks :P i am not sure on the elevations though...
First of all, i am Dutch we have no elevations in the Netherlands.
Second of all, i had elevations on my First track which sometimes caused problems with LMP cars Thingies etc,
I want this track to also be 1:32 Thingie proof so it has to be a quick track :bday:
#4 Jaak
    Slotalot
  • 446 posts
Posted 05 August 2008 - 08:50 PM
Hi all
I got the necasary track parts but do still need the two Digital 6 car powerbase adapters/powersources
Here are some more pictures of the progress:
First i made a proper table to build it all on...:
That little dot is a new ray 1:32 motorbike to show the size of the table.
This is actually the same wood from my old track but then turned upside down so it has a scenic bottom.
And i made it a bit bigger then last one.
Then i made a first layout with the track pieces i had..
More where on the way from my good mate Mike®
The green bits are also pieces of my old track which probably will not be used.
I will post some more progress pictures late.
Jaak
#5 Jaak
    Slotalot
  • 446 posts
Posted 07 August 2008 - 03:10 AM
Got some more pictures :o
Lane change Thingies have been removed,
and the track has been extended and it got more borders.
I also changed the radius curves on the bridge to R3 curves.
All i need now is some barriers to go wit my borders and make the Digital powerbase loose from the track with a switch,
and convert the lane changers with magnets etc, and also detach the Sport powerbase from the track with a switch,
and my Digital /Analog all in one track will be done :rofl: (excluding scenery)
The basic shape of the track will stay the same this is my final layout...intill the next but that one will be routed.
Here are some pictures...:
I hope you like it..
Jaak
#6 slots
    Looking for sanity
  • 2465 posts
Posted 07 August 2008 - 07:17 AM
Still looking good Jaak, but I would have gone for the largest radius curves I could get for the bridge for a fast transition. Will the routed track be this big?
#7 Jaak
    Slotalot
  • 446 posts
Posted 07 August 2008 - 09:15 AM
Thanks Stu,
I could not use the R4 because the track would not come together as proper as it did now.
I hope the routed will be at least as big as this one,
but that is for a few years from now, and depends on the room in the new house that i will have available for the track.
Time will tell.
#8 Jaak
    Slotalot
  • 446 posts
Posted 24 September 2008 - 09:27 AM
Finally also made some small progress on the track!
I managed to figure out what goes where etc, i made the outlines for the pits and park footpaths roads and greenery.
I also fixed my bridge proper cut the wood to a proper size, last thing before painting and scenery is to figure out what i am going to use to make the walls on the ramp of the bridge B)
any ideas always welcome!
