How Many Amps Does A Super 16d Use.
9 replies to this topic
#1 aussieslotter
    Digital Dude
  • Sponsor
  • 2,087 posts
Posted 16 January 2008 - 09:32 PM
Hi Guys,
Just curious.....
How many amps does a Super 16D use.
Generally and on start up?
Thanks in advance
Rick
#2 racerx
  • 35 posts
Posted 17 January 2008 - 12:59 AM
Hi aussieslotter...
A china spec super 16-D motor (parma, proslot-speedfx,) pulls about 1.7-2.8amps@ 12.0V
it depends on how much timing the arm has!...... :nice:
KEEP ON RACING!!?
HAVE FUN....Keep it in the slot!!?
Posted Image Racer X
http://racerxcustoms@hotmail.com.au
@PeterDimmers
#3 munter
  • 4,033 posts
Posted 17 January 2008 - 06:03 AM
Hi
When I yank on the throttle hard with my parma international chassis,sponge tyres, and super16D the amp meter needle flicks up to between 4 and 5 amps.
When I put goo on the track and things load up a bit more then I am sure a draw of 5 amps is a possibility.
#4 grego
  • 103 posts
Posted 17 January 2008 - 07:20 AM
View Postmunter, on Jan 17 2008, 09:03 AM, said:
Hi
..................and when he installs the "special magnets" and the proslot armature and pulls the trigger, the needle of
the ampmeter on the powersupply wraps itself around the endpost............................. :lol:
Power to the people
grego
#5 slotbaker
    Dan Gurney Fan
  • 2,645 posts
Posted 17 January 2008 - 12:51 PM
Yeah, I would have said 4 to 5 amps on full start up.
Certainly on our track set @ 13.8V.
:lol:
Steve K.
#6 slots
    Sanity is over-rated
  • 2,565 posts
Posted 17 January 2008 - 04:21 PM
Rick, my supers have been known to pull up to 4 amps continuously and spike at 6 amps on take-off at 12.5 volts. This is the extreme and the motor was NOT box stock. Timing around 45 degrees with a tall gear ratio. Gear ratio will affect the number of amps used as mechanical resistance increases the amount of work the motor must do to drive the vehicle.
Edited by slots, 17 January 2008 - 04:22 PM.
#7 Plucka
    Slot car Builder and Painter
  • 381 posts
Posted 24 February 2008 - 09:09 PM
I know this is an oldie but i only found it.
Having a Slot Car Dyno a bog stock Super 16D Speed FX motor will pull 26 amps at 3700rmp (start up RPM).
The better supers will pull up to 35 amps at 5500 RPm.
I know power supplies will read less, this is what my Dyno is telling me lol.
Hope this helps.
Plucka
#8 slotbaker
    Dan Gurney Fan
  • 2,645 posts
Posted 24 February 2008 - 09:43 PM
:D
That seems like a big number.
Our little 6 laner is powered by a modest 40amp power supply, and it can easily handle 6 x S16Ds (Parma 499) from standing, full trigger, start.
So that would suggest something less than 7amps each at start.
Steve K.
#9 slots
  • 2,565 posts
Posted 25 February 2008 - 06:37 AM
Hope this helps.
Plucka
I'd check your equipment, Plucka. We ran 20 amp circuit breakers on a commercial track and even the opens wouldn't pop them. :D
#10 Plucka
  • 381 posts
Posted 25 February 2008 - 06:31 PM
I am pretty sure the equipment is fine.
The high amps are as soon as the dyno kicks in which is why it reads at such a low rpm.
the figures any racer needs to worry about is the amps at 3-7 seconds and thats been around 10-13 amps loaded (the motors run an aluminium flywheel).
At that range yes the 20 amp fuses will work but any kind of short and those 20 amp fuses will blow in a second, we run 30 amps on ours as you do get some cars that load up or are meshed wrong and that could pop a fuse as they will go up and over the 20 amp fuse very quickly.
When i have seen scaletrix cars run over 3 amps on the small track its not hard to imagine 10 from a 100 gram foam tyre super 16D.
Just for ha haaaas that same motor maxed out at 55,000 rpm and made 35 watts of power.
Plucka
P.S i forgot to mention, if you are running opens on 20 amp breakers then you are very lucky, good opens will pull around 100 amps per car, per lane.
Edited by Plucka, 25 February 2008 - 06:33 PM.
