Boston Slots Posted February 6, 2007 Report Share Posted February 6, 2007 I just opened up and set up my SSD Lane Change Challenge set. I wanted to reposition the magnet to the front of the car so I popped out the rear axle. Now that it is back in, the car makes a grinding noise. Did I use the proper technique for moving the magnet? Do I now have to replace the gears? Quote Link to comment Share on other sites More sharing options...
mr magoo Posted February 6, 2007 Report Share Posted February 6, 2007 boston sounds to me like you just havent put the rear axle back in to mesh the pinion gear and spur gear properley. take it out again and make sur all the teeth line up.hope this helps Quote ENTRANT IN THE 2007 DOWN UNDER PROXY SERIES LOLA T70 MK3 B Link to comment Share on other sites More sharing options...
Boston Slots Posted February 6, 2007 Author Report Share Posted February 6, 2007 Mr. Magoo, Tried that repeatedly. Also, looked at gears under magnifying glass and they look fine to me. Still making noise though. Quote Link to comment Share on other sites More sharing options...
mr magoo Posted February 6, 2007 Report Share Posted February 6, 2007 sounds very unusual, try replacing the magnet and see if that changes anything. If the car was running fine before you moved the magnet then it must be something that you changed. Give it a little oil !!!!! if you however didnt run the car so are not sure if it was noisy to begin with then i would take it to your closest slot shop.what area are you in? Quote ENTRANT IN THE 2007 DOWN UNDER PROXY SERIES LOLA T70 MK3 B Link to comment Share on other sites More sharing options...
mr magoo Posted February 10, 2007 Report Share Posted February 10, 2007 hey boston slots did you get this little problem sorted Quote ENTRANT IN THE 2007 DOWN UNDER PROXY SERIES LOLA T70 MK3 B Link to comment Share on other sites More sharing options...
Boston Slots Posted February 26, 2007 Author Report Share Posted February 26, 2007 Yes, I did get it sorted..kind of. I returned the car to my local dealer, paid extra and upgraded to a analogue Camero which I plan to chip to SSD digital. Just looking for any chipping information on this car before I do. Quote Link to comment Share on other sites More sharing options...
