Sim 999
Rally Chassis
I have no idea what it is ,But would say that its a 4 w.d. set-up looks like the rear wheel drives to the centre idler which in turn runs 2 belts to the front axle if you can make any sense out of that :o
I agree... Looks like a three-belt system. Due to motor placement you can't run a dual belt set up like that typically found in NINCO cars.
Also appears that the gearing really pushes the rear-most axle pulley very far out making it not in-line with the pulley on the front axle. The center mounted pulley is driven on the outer edge by the rear belt then drives the front axle via two belts inside each of the front wheels.
I'm not really convinced of what performance gain you would expect from adding additional friction to the drive-line like that. Interesting to say the least.
Edited by SJSlots
Shawn
Thanks Guys it all seems to make sense now, I wasn't really thinking of that doh
Hey Sj slots
What Ninco car has that sweet looking chassis?
Cheers :lol:
Sim
CANYON COUNTY RACEWAY
