Caddo 43 Report post Posted June 8 Started a new build to get back the garage for parking another car in, funnily enough. 3 x tables are 2400x1200 each Losing elevation changes and an overpass the last track had, hinges are quite close to the walls, but a happy compromise to still have a track. Routing done, pretty simple lay out but hopefully allow for some decent car speeds even in corners. Starting to paint, going for a smooth gloss enamel finish for best grip and least tyre wear: 3 Quote Share this post Link to post Share on other sites
bov 17 Report post Posted June 8 Hi Caddo - that's nice work ! So, for us old dudes, that's 12' down the side and 16' across the back? Where do think you'd place the drivers and marshals? If I may be so bold, I might suggest seating a marshal on a lower version of that wooden stool where that one is - next to the vacuum cleaner. And then run a oci-strap / bungy cord type of rope from one corner of the track to the other ( behind that marshal ) - and then the drivers have to stand behind the rope. So no driver is in anyone's line of sight whilst racing - but you could 'stretch the cord' to place / remove your car from the track... Just a thought... 1 Quote Cheers, Tony. There's only two questions: 1. What direction do you go 2. What's the Lap Record? Share this post Link to post Share on other sites
Caddo 43 Report post Posted June 9 Sounds good Tony, hadn't thought of that Hoping the track is simple enough that only the inner corner you mention will need marshalling, and the 2 hairpin ends. Always the call button as a last resort. Thanks for the tip Quote Share this post Link to post Share on other sites
Caddo 43 Report post Posted August 2 Mostly finished painting and braid on 2 lanes. Couple of quick vids on ghost mode 2 Quote Share this post Link to post Share on other sites
