To Much Oil
6 replies to this topic
#1 tsmsoccer
  • 1,168 posts
Posted 28 January 2006 - 07:11 AM
I got a new SCX car the other day and I think I put to much oil on the communicator as the motor is only running at half speed.
Does anyone know the best way to clean the SCX motor up?
Charlie
#2 oldslot
  • 2,126 posts
Posted 28 January 2006 - 07:48 AM
wash the whole thing in metho and let it dry out before relubing.should do the trick
#3 tsmsoccer
  • 1,168 posts
Posted 28 January 2006 - 12:40 PM
Thanks will do
Charlie
#4 RePete
  • 846 posts
Posted 28 January 2006 - 05:01 PM
Hey Charlie
You could also try running the motor in a cup of metho and water about 50/50 mix
It worked for me with some artin motors I over oiled once
Keep it in the groove
Pete
#5 Vinno
  • 4,484 posts
Posted 28 January 2006 - 08:33 PM
100 per cent metho is what I have used. You have to be careful though as it can soften the brushes. Don't do it too long. You will see heaps of black crud come out.
#6 kalbfellp
  • 10,783 posts
Posted 28 January 2006 - 11:16 PM
Metho works but does tend to leave a residue,shellite will dot leave a residue but I do not recommend running the motor in either best to clean the motor and allow it to dry,then run it in water if you want to run the brushes in. I have seen several motors and hands alight!
#7 falcon
  • 72 posts
Posted 30 January 2006 - 09:01 PM
Hello Guys
When you say to run an engine in water for the brushes,
What time would you have them running for ? 2 minutes ?
Edited by falcon, 02 February 2006 - 06:28 PM.
