Sports Racer 28 Report post Posted Tuesday at 03:13 AM The 2021 Touring Car Proxy is open for entry. The only changes from last year are instead of 12 rounds there will be 10 and it’s limited to 21 entries. Entry fee will still be whatever the cost is to ship your car back + a couple of dollars. We'll start racing in August with all cars to be posted to me by Monday 19 July 2021. At the end of the proxy the top 5 cars will be taken apart to show their insides and pictures taken so everyone can see what makes them tick. Here are the rules (same as last year). Rule Number One: Any modification not specifically detailed below needs to be discussed. Bribes of cash, cake or chocolate are encouraged. 1. Body 1.1: Any Injection moulded or resin bodied car from the approved list that is marketed as a 1/32 scale Ready-to-Run (RTR) slot car. No vacuum formed or blow moulded bodies. Max width 63mm. Cars must be from 1990 or later, no cars from the 80's or earlier. Approved List, let me know if I've left a car out. Any BTCC car Any DTM car Alfa 156 GTA Alfa 155 Audi A4 DTM Audi A5 DTM Audi TT DTM BMW 1, 3 or 4 Series Fiat Punto Ford Focus Ford Falcon Holden Commodore Honda Accord Honda Civic Type-R Hyundai Accent Mercedes C-class DTM Mercedes CLK DTM Mitsubishi Lancer Evolution Opel Astra Opel Vectra Opel V8 DTM Coupe Opel Calibra Peugeot 406 Coupe (not Silhouette) Renault Clio Renault Megane SEAT Leon Subaru Imprezza WRX Volvo S60R VW Passat 1.2: Chassis - No restrictions. Body screws should be taped or covered in bluetak to prevent loss. External body parts - mirrors, wipers, wings - though desirable are not required. 1.3: Guide may not project beyond the body as viewed from directly above. Tracks will all be routed wood with 8 mm deep slots. 1.4: Cars must have sufficient ground clearance to permit free running without contacting the track. Cars which drag on the track may be excluded at the track owners’ discretion. 1.5: Clear window material must be used where the real car has clear material. 1.6: Racing numbers must be visible in three places on body. Racing numbers must match. Bodies may be painted in fantasy or realistic liveries. Non-decorated cars (for example plain white kits) are not allowed. Duplicate numbers are allowed but if everyone enters the red #7 Slot.it Alfa 155 I’m going to be reaching for the spray can. 1.7: Headlights and taillights are required but do not have to illuminate. 1.8: Interior must include, at minimum, dashboard top, driver, steering wheel and shelf under the rear window. If vacuum formed, must be of reasonable detail and proportion. Champion style and paper drivers are not permitted. 1.9: No weight limit. 1.10: Bodies may be lightened provided there are no external changes and wheel arch openings remain standard. 2. Wheels and Tires 2.1: Tires may not project beyond the body when the car is at rest on a level track, as viewed from directly above. 2.2: Reasonable scale appearing inserts are required in all wheels unless the wheels have scale appearance and detail. Blank disc wheels must be covered with inserts. 2.3: Wheels must look like they were used on the 1:1 car. No F1 rims or 12 mm (dia) wheels unless the original car raced with small wheels. 2.4: Front tire diameter must be within 2mm of rear tire diameter. 2.5: Minimum front tire width is 8mm. Front tires may be profiled so that a narrower area contacts the track but must otherwise be full width. 2.6: Tires must be urethane or rubber. Silicon and foam tires are forbidden. Tires must appear to be black. Clear finish may be applied to front tire tread area. No chemical treatment (such as oil soaking) is permitted. 3. Motors 3.1: Any commercially available sealed-can FC-130 slot car motor that produces less than 23.5K rpm at 12 Volts is allowed. FK-180 are allowed but limited to 21.5K rpm. No rewinds or "mod motors" allowed. 3.2: Magnetic down force from motor may not exceed 30 grams as checked with a Magnet Marshal, exclusive of car weight. 3.3: Motor can be glued/taped/screwed in place. Pods can be taped or glued to restrict movement. 4. Modifications 4.1: Any part of the car may be replaced by any manufacturer’s parts. All wheel drive may be used only if the actual car used it. 4.2: Weight/ballast can be added but must be contained on the inside of the car. 4.3: Spring and magnetic suspension packages are allowed. 4.4: No traction magnets allowed. 4.5: Bushings and motor can be glued into place. 5. Vehicle Identification 5.1: Entrant’s name and body screw adjustment information should be affixed to the underside of the chassis in a readable manner. 6. Penalties 6.1: non-compliant mechanical and car set up issues including wheels/tyres at scrutineering - 5 points 6.2: repair of mechanical failure deemed not to be caused primarily by accident damage - 5 points. A grub screw coming loose is not a mechanical failure and won't be penalised. 6.3: car not run due to hosts discretion because of clearance issues - no points will be awarded for that round. Car owner has the option to replace tyres or park the car. 6.4: For all other non-specified events requiring vehicle work the penalty, if any, will be based on a principle of reasonable fairness to all entrants at sole discretion and decision of the organizers Cars to be posted by Monday 19 July 2021 I think that covers everything. Let me know if I've missed anything. Cheers Paul Quote May the downforce be with you. Share this post Link to post Share on other sites
32coupe 20 Report post Posted Tuesday at 03:35 AM Bring it on, and if you don't add penalties after the first round, it should be interesting Quote A man without a woman is like a neck without a pain. Share this post Link to post Share on other sites
charlesx 70 Report post Posted Tuesday at 04:02 AM Hi Sports Racer. Please put my 2006 Holden Commodoreon list. Regards Chas Le Breton (charlesx) Quote Share this post Link to post Share on other sites
curef99 4 Report post Posted Tuesday at 04:20 AM count me in, i will have an NSR clio (or a ninco megane)... i hope to see few of them to have a sort of second competition within the competition as very few club race a category for the clio here Quote Share this post Link to post Share on other sites
Peter Gunn 89 Report post Posted Tuesday at 06:26 AM Yep i,m in no idea of car yet Quote Share this post Link to post Share on other sites
BARacer 0 Report post Posted Tuesday at 07:04 AM (edited) Good morning Do you think there will be slots available for a new entrant or two from the UK? Then count me in please! Have been waiting for the announcement, car is half ready...Scalextric Honda Civic Type-R. UK build thread here... https://slotracer.online/community/showthread.php?tid=1992 Jeremy Edited Tuesday at 07:52 AM by BARacer Quote Share this post Link to post Share on other sites
Nonfractal 1 Report post Posted Tuesday at 07:07 AM Yes please! I would like to enter the Ninco Megane that recently raced the WHO winter rally and is currently on the start line of the UK "Brighton to John o' groats" UK road race proxy. The car is a Slot.IT HRS2 chassis with an inline ScaleAuto sc0025b 21.5krpm. long can. The body will be a new Megane lightning #4 with a wing but without a lighting kit. The wheels are stock ninco lightning, the tyres will be black NSR or Slot.IT g25. The black windows have been replaced with clear except for the rear which form part of the wing structure. The interior is painted ninco lightning factory fitted apart from the helmet which is one i found rolling around in the spares box. AlanWilkinson. UK. https://ibb.co/album/WWtWSL Quote Share this post Link to post Share on other sites
jimmyslots 1950 34 Report post Posted Tuesday at 12:35 PM Hi Paul hope you are feeling better. Please add me to the list for another series,Renault Megane but this time with my new chassis & new boots that hopefully last the 10 rounds. Cheers Jimmy Quote To finsh first,first you gotta finish Share this post Link to post Share on other sites
bov 12 Report post Posted Wednesday at 07:32 AM Hi Paul, I'll enter again - something DTM ish.... Quote Cheers, Tony. There's only two questions: 1. What direction do you go 2. What's the Lap Record? Share this post Link to post Share on other sites
Peter Gunn 89 Report post Posted Wednesday at 08:04 AM Just checking Paul along with my 111, Dixie 99 would like to enter a car as well. Quote Share this post Link to post Share on other sites
sticks 3 Report post Posted Wednesday at 08:05 AM Hi Paul Good to hear you are on the mend I'll would like to enter the green machine again Rodney Quote Share this post Link to post Share on other sites
Shaynus 40 Report post Posted Wednesday at 09:11 AM I would like to enter again to defend my wooden spoon crown! Quote Share this post Link to post Share on other sites
charlesx 70 Report post Posted Wednesday at 10:05 PM I will probably race you for that Crown Shaynus. Have entered my old 2006 Holden Commordore V8 again. This time have up-graded motor though from NSR Shark 20 to NSR Baby KIng. It is still very drivable but hopefully has a bit more grunt. Also going to try rubber tyres as event does not have so many rounds. Best of luck with your build. Good to see Sports Racer has been able to host again. Regards Chas Le Breton (charlesx) 1 Quote Share this post Link to post Share on other sites
lancelot 0 Report post Posted Thursday at 03:03 AM (edited) I'll have something for this. Maybe different than last year. Dale says he is in too. Edited Thursday at 03:47 AM by lancelot Quote Share this post Link to post Share on other sites
Brooksy 3 Report post Posted yesterday at 05:32 AM I would also like to enter in this year's Proxy please, if there is room still available. Brooksy. Quote Brooksy Share this post Link to post Share on other sites
bov 12 Report post Posted yesterday at 05:46 AM Don't let him in - we have standards, you know....... G'Day Jase - hope you've been doing well...... Quote Cheers, Tony. There's only two questions: 1. What direction do you go 2. What's the Lap Record? Share this post Link to post Share on other sites
Peter Gunn 89 Report post Posted yesterday at 06:18 AM Paul can you add Dixie car no 99 to the list Opal Calibra, contact through me cheers. Quote Share this post Link to post Share on other sites
Peter Gunn 89 Report post Posted 23 hours ago Dixie informs me her number is 90 oops can't upset the boss Quote Share this post Link to post Share on other sites
Peter Gunn 89 Report post Posted 19 hours ago Can a friend enter please his tag is JohhyE 515 and he would like to enter a Calibra , so i'll pay dues for 111, 90 and 515 when the time comes Paul. Quote Share this post Link to post Share on other sites
Brumos RSR 8 Report post Posted 8 hours ago Hopefully the Clio returns home soon as it will be the entry again this year with the #33 Quote Share this post Link to post Share on other sites
