SlotsNZ
ff050 sidewinder pod for Slot.it chassis mount
Interesting contributions from all of you on this subject, and I'm looking forward to getting my hands on some of Paul's pods for projects that are lapping around in my mind.
What has become apparent from Chris's comments is the existence of slot car gear that many of us 'Down Under' have been unaware of e.g. MR motor pods for 050 motors, different gear and pinion diameters etc.
Like Mark and Wobble I marvel at the technical skills shown by Paul and others.
Watching the various editions of the Worldwide Slot Car Chat has also been a real eye-opener to the skills and knowledge that abound in our hobby-sport.
After nearly 60 years of being involved with slot cars I am regularly amazed by how much I don't know.
Den
I am also doing a setup block. One side the sliding ride height disc gives a height of 0.5mm, the opposite side gives 0.8mm.tRJ69ZA.jpgEAHpSO2.jpg
7 hours ago, Bingo said:
FF030 & 050 pods all done & ready to go if anyone is interested
Well done......It would appear from the picture that you have set the vertical  centerline of the bushing placement above the motor shaft centerline ???..........what is the "offset" measurement ??,.....and, did you incorporate holes in the bulkhead for motor screws !!
Chris Walker
That's the problem with FF050 and FK130 sidewinder, the tags cause a lot of grief for the pod designer, it's not easy to 3D print a pod stiff enough and still have access for wiring.  I made a FF050 adaptor for a C-can pod, it's just a hollow sleeve that makes a slimline the same size as a C-can...but those pesky tags are still a bind.
Print It, Build It, Race It, Improve It, Repeat...B)
Chris Walker
Chris the motor shaft centreline is 1.3mm below the axle centreline. Motor screws - no holes for those because the motor slides down a slot; the idea was to hot glue in although the base does sit flat on the pod, i.e flat section of motor on a flat surface. the motor would have to lift in the mounts quite a way before it turned.
My versions of ff50 and fk130 motor pods
FF50 AW fitted under a Ferrari 612 Dart body
FF50 in line fitted under an Alfa Romeo monopsto Ocar body
FK 130 in line fitted under a Lancia Fulvia SCX
FK130 AW fitted under a Rover PreWing body
11 hours ago, alexis in greece said:
That AW pod has printed nicely
Love the Fulvia HF
Do I spy a 3D printed spur gear?
