Chrisguyw
Slot-It 962 Proxy Car
Hi Folks, Too much time spent at home these days for my liking.........I can only cut the grass so often , and my golf club is closed, so, spending a lot of time on slot projects, which is not all bad . :)
I have entered a Slot-it Porsche proxy (only the body has to be a Slot-it Porsche 956/962), so while I have still to figure out what to do about a chassis, I have painted the body........which I always find the most nerve wracking part.
Stay Safe
Chris Walker
Detail is amazing, Chris.... love the exhausts - now, that is modeling - but, you turn out some amazing models...
Painting - can be stressful, I find applying decals more so than the actual laying down of paint...
Our golf clubs, fishing activities and some other recreational alternatives will be allowable as of midnight tonight.... I am expecting a huge shock to see how well the golf course has been during "recovery"...
Lovely work, I only lack two things to emulate this, skill and patience... I'd argue time, but people would see right through me at present.
Nice - I'm still pondering which way to go for a chassis for that proxy, too......
There's a lot of options to consider...
Either way, I'm sure it'll get hosed.......
Chris, I have marveled at your soldering skills for a while now - I believe you're using a torch rather than an iron? How do you get the joints so neat? Your presentations are exemplary..
Tony.
There's only two questions:
1. What direction do you go
2. What's the Lap Record?
Hello Tony, I use an iron (60 Watt Hakko) for all my 1/32 chassis builds...........the wire/brass I use for these is relatively thin, so there is no need whatsoever to use a torch. For that matter, virtually all my 1/24 stuff is built with the same iron, and I only really use a torch on really heavy duty brass plate, which I sometimes use for 1/24 Vintage frames.
No soldering secrets.................just stick to the following
1/ Try to make all the parts to be joined fit as closely as possible
2/ Clean, Clean, and Clean one more time.
3/ Use a minimum of a 45 Watt iron, with a 1/4" chisel tip
4/ Use liquid acid flux for all chassis construction.....must be cleaned up after.
5/Use less solder than you think is necessary, and take your time with each join.....acid flux and patience will turn the solder to water, and it will flow evenly.
6/ Practice never hurts !!
Stay Safe
Chris Walker
Hi Chris,
Your cars all sparkle, and have that new car smell. They just can't get any better than that! :D
Thank you very kindly for sharing your soldering skills. I'm quite certain my strange contraptions won't resemble your jewelry for a little while yet. More practice you say? Count me in.
