terry
M2 Tap
I'm not too sure on what to get(or what is the correct name) for me retapping out a screw hole for alloy wheels.
I did have one of these(??) but I'm running around in a lather trying to find the bloody thing and what am I thinking!
Try the forum!
Someone will know what and where to get it!
Thanks for any help
Terry
Sorry I should have said its a M2 hole
Edited by terry
Sorry to bother you,
can the mods please close this as I've found the little bugger
Terry
Terry, just in case you want to purchase a second one as spare....
I used the grub screws from the Slot-It wheels for my home made wheels.... I found that the thread for these is an "M2" fine thread.... 2.0 mm.
I don't believe (might be wrong) that M2 comes in any variation in thread.. I think they are all this one fine thread..... unlike other thread codes....
Metric, as I have read thus far - come in fine or coarse.... I am not aware of an M2 in coarse.
I use a pin vice for tapping these small threads... the tapping drill I used was 1.6 mm.... after first using a 1.0 mm drill - then reaming out that hole with the 1.6.
I took small bites with the tapping tool... 1 turn in... then back out... repeated many times. I have found this to be a good way of getting a very clean thread.....
I also use a cutting fluid called "Tefolex"... a tub of that stuff will see your grand-kids out... but don't use it in a powered drill... it can give off very nasty fumes if it gets hot....
Hope this helped...
Thanks Rosko,
I will take those very helpful tips,in the past I did, as you said , take it very slowly,but I wasn't aware of the Tefolex which I will get.
Thanks again
Terry
Hi Terry.
Probably too late now but I think SlotsNZ/Mark Burgess has M2 taps or he used to.
Edited by charlesx
M2 x 0.4 is what I used to do the very same job yesterday.
It's classed as a coarse thread in my Zeus book.
...and I used a drop of 3in1 oil for tapping the 1.6mm hole.
Edited by Kevan
Print It, Build It, Race It, Improve It, Repeat...B)
