David Carter
2020 Atcc Proxy Cars And Car Builds Page
Hi guys,
To make it easier to keep track of everything I have started this page for posting pics of your cars and car building updates
Added some decals. It's a bit rough and ready but a reasonable resemblance to the real Mckoy.
Wow, Bram, you are way ahead of me.
Yeah but ….. yeah but I started this almost 2 years ago and I didn't have to fabricate the body ….. or the chassis.
If it is too much to hack it into line I have renewed the mould and could pump out a new shell for you.
I better make some windows and interior too.
I will be making some mods the the VK body to make it look like the earlier VC body so I will work with the one I have
I do need the interior + windows but no hurry yet
The Jag had it's first run today but still has some minor details to have it race ready. Overall runs well and a bit more poke than the Torana I ran in the last one. Found some issues with the Torana which explained it's odd handling so I have over compensated for epoxy to make sure nothing comes loose this time.
Not a lot else to do with the rain finally coming down in Sydney so I got the Fleischmann track out and ran it around for an hour or so to bed everything in a bit. Just finish off the window decals and glue the tyres and maybe another 5 grams of weight.
Looking good there Vince
would this Porsche be legal????
Yes I do believe so so long as livery and wheels fit the rules
Edited by David Carter
The SD1 build is moving forward....interior and decals to go. Chassis runs better than the Coon that I entered last time.
Edited by munter
Is it body style and livery or just body style? If it's just body style I'm in with a Sunoco livery car
Body style is the same as raced, livery just has to fit the time period that car raced
Very nicely done there munter ... but you might want to shave the bottom of the guide so that it's no deeper than 6.5mm. On Wazzas track I had a full depth guide and it ran along the bottom of the slot and because of the shape of it, picked up stuff in the bottom of the slot and directed it straight towards the rear tyres, a bit like a ships wake, and you can imagine the loss of grip that caused.
aaiiiiiiiiiieeeeee these people with shallow slots.
Thanks for the heads up. I will check the depth.
A question for DC............
Is this chassis too 'high tech'?
The motor and back 1/2 assembly is solid to the front of the chassis with no real flex as the main rails are brazing rod not piano wire.
The side pan arms pivot from the back and the pans flap a small amount but the body is mounted to the chassis through the holes you can see.
It is for a '69 Camaro.
Cheers for checking.
Edited by drw21
