Wobble 106 Report post Posted May 7, 2019 I have a problem with a Scaley '87 Montecarlo Nascar that chatters quite noisily when slowing for corners etc. It doesn't appear to effect its braking but annoys the whatever out of me 'cos it kinda stuffs up my concentration. It's had BRM Nascar tyres added to it and acceleration is good with nil chatter so I figure the tyres aren't out of round and the motor has been hot glued in 'cos it was as loose as a really loose thing. It's running on wood no magnet so I'm sure some of you guys will have a way better idea of what's happening than I do. I'm open to suggestions so please feel free to add your thoughts so I can fix it. Quote Share this post Link to post Share on other sites
terry 36 Report post Posted May 7, 2019 Have you tried adjusting the brake setting on your controller? Quote Share this post Link to post Share on other sites
munter 153 Report post Posted May 7, 2019 I havent seen a plastic chassis that didnt flex....whats the motor/rear axle/pinion/spur rigidity like? Think bracing Quote John Warren Slotcars are my preferred reality Share this post Link to post Share on other sites
slotmadmac 127 Report post Posted May 8, 2019 Yeah. Brace the rear bushes to the motor. I use thin piano wire and JB Weld - which is easy to remove if you need to. Quote Podiums are for short people. Share this post Link to post Share on other sites
Wobble 106 Report post Posted May 8, 2019 Yeah bracing … had another look at the innards and they were worse than I first thought. Thanks guys. Quote Share this post Link to post Share on other sites
munter 153 Report post Posted May 8, 2019 I can see a weak spot from here and I am 750kms away....pretty sure you will fix it. Quote John Warren Slotcars are my preferred reality Share this post Link to post Share on other sites
Wobble 106 Report post Posted May 8, 2019 I recall now, I didn't remove the magnet just in case I busted the chassis in doing so. Quote Share this post Link to post Share on other sites
David Carter 84 Report post Posted May 8, 2019 Yep as Mac said, that chassis will be twisting to the max Quote Holdens rule the rest just drool slot cars are my drug, ATCC/Bathurst proxy host NZ Grp5 proxy host. Share this post Link to post Share on other sites
munter 153 Report post Posted May 8, 2019 Yep as Mac said, that chassis will be twisting to the max eh boi.....!!!! Quote John Warren Slotcars are my preferred reality Share this post Link to post Share on other sites
slotmadmac 127 Report post Posted May 8, 2019 If clearance under the interior allows, another trick to stop shudder / longitudinal flex is to fix lengths of plastic tube or square section plastic rod down the length of the chassis between the motor and the front wheels. You can also run guide wires through these tubes for a nice tidy set up. I am doing this more and more these days. 1 Quote Podiums are for short people. Share this post Link to post Share on other sites
difinity 27 Report post Posted May 8, 2019 I tend to run flat carbon fibre strap from the motor to the guide post with these chassis. Bracing the motor to the rear axle mount helps too. Quote Share this post Link to post Share on other sites
dangermouse 95 Report post Posted May 8, 2019 photos of all these mods would be appreciated thanks - where do you get carbon fibre strap from? 1 Quote Share this post Link to post Share on other sites
slotmadmac 127 Report post Posted May 9, 2019 Here is a motor braced to the rear bushes. Quote Podiums are for short people. Share this post Link to post Share on other sites
slotmadmac 127 Report post Posted May 9, 2019 and here is an old pic of the square section tubing in place These days I use plastic section and tend to respray / repaint the whole chassis when the tube is in place so it looks nice and tidy. Quote Podiums are for short people. Share this post Link to post Share on other sites
Wobble 106 Report post Posted May 9, 2019 Thanks for your input guys. I'm going to try a bit of that Mac. Still struggling to understand why it's smooth on acceleration and chatters on deceleration. Terry I wondered about the brakes but I had knaff all brake wound on and it still did it. Quote Share this post Link to post Share on other sites
Slotspeed 14 Report post Posted May 21, 2019 Maybe not the same thing but I had very bad chatter with one of my Carrera cars. The standard clearance from axle to bush was way too loose, most noticeable as a horrible chatter on deceleration, so much so I was getting tyre squeal under braking. Perhaps this is what you have? Apart from that I also braced the rear bushes as has already been suggested. What was quite funny is that I spent more than the value of the car replacing the drivetrain with slot.it axle and crown gear for better clearance and less friction. It became apparent however that the chatter was actually helping remarkedly with braking! I ended up putting the original crownwheel back in too! For other Carrera cars with the same problem I have just been using the superglue trick to tighten up the clearance and have only needed to revisit the process once in one year on my most used car, as I keep it well lubricated so to speak hahaha. Quote Share this post Link to post Share on other sites
difinity 27 Report post Posted May 21, 2019 photos of all these mods would be appreciated thanks - where do you get carbon fibre strap from? The same hobby shop I get metal rod from (in Canberra). Should be available anywhere plastic/metal hobby pieces are. Maybe try your local RC/plane store? Quote Share this post Link to post Share on other sites
gordo 0 Report post Posted June 29, 2020 gear lash may be the issue. a tad too loose perhaps Quote Share this post Link to post Share on other sites
