the requirements of European clubs, which race mainly on plastic tracks; as well as a top quality option for home tracks.
The track has 90mm lane spacing - the same as Ninco track.
Ninco has been the most widely used club track, and the Policar track has a textured, but less abrasive surface perfectly suited
for grip when racing without traction magnets, and forgiving in dusty environments. The track is made from a rigid plastic which
will not warp, and the plastic slot liner inside the rails will not fold inwards or close up at the joints. There is an adapter track
between the two systems. Having seen prototypes when I visited Galileo Engineering (Slot.it) earlier in 2017, I can attest that
they have adopted the best aspects of other track systems, and improved joining methods, surface, and plastic composition.
- Textured surface scrubs dust from tyres to maintain better grip than smooth tracks in dusty conditions
- Note the rail liner, and flat racing surface - the rails are not "raised"
- Rigid plastic that will not warp or buckle with temperature change.
- Slot depth 8.5mm will take Slot.it wood guides
- 90mm lane spacing
- Robust electric connection, easy to use, secure clipping system, and lined slot which will not close up at the joints
The electrical connection is very good, and the steel rails are rust resistant stainless steel.
- 60mm wide border sections gives 105mm from slot centre to guard rail, great for non magnet racing
- Robust guard rails that clip above and below track
The joining system is easy to use for smaller hands, and very good, but these clips provide additional security for
locking sections together longitudinally in more permanent layouts
The clips pictured below in orange and red securely lock 4, 6 and 8 lane systems together laterally to eliminate gaps
They have designed the geometry, so that a layout can have the turns altered, while retaining the main structure,
as the geometry of the various curves simply requires the addition or subtraction of half straight pieces to restore
continuity.
See R1 at top, through to R4 at bottom.
Initial track will be 4 lane (R1 and R2), expanded to 8 lane at the end of the year.
This will be a real bonus for people who like to experiment with track alterations.
In 2019, digital track pieces will be added.
There is additional detail in the document at this link "WhyPolicar"
