ZeGas
Track Filler
I am building (retrofitting) a railway crossing for my layout and need to grade up and then back down each side.
The grade will be gentle so a reasonable area will be filled.
What is the best / cheapest filler I can use, it must be strong and not brittle not flexible as I need to include the slot
Also something I can smooth out while malleable so I can minimise sanding
I have already considered auto bog but it is a bit expensive for the area I require.
Guessing the area is about 300-400mm each side of crossing and about 100-150mm wide.
Any suggestions would be greatly appreciated.
Edited by ZeGas
Maybe try using some 3mm MDF with the edge chamfered for the bulk, and bondo / bog / etc for the joins?
Another vote for 3mm mdf.
Easily worked & sanded.
A wise man once said... "Its not the mistakes you make , its how you respond to them that matters."
(It wasn't me)
Ordinarily I too would agree, but this is in my office with computers among other sensitive stuff, I'm hoping to get away from bulk sanding if at all possible.
I may create a model external to the track and then fit in on top or maybe layers of 600gsm card with a bog skim topping.
