fosinator 0 Report post Posted December 1, 2016 Hi all, wondering if anyone has any ideas on this problem. I got my pit lanes registering but not the lap sensors. 2 lane track with pits zd1950 sensors with matching tx the laps count with a normal switch and when touching wires together just not the sensors. all of the ir tx trigger the pit sensor, so they all work im using a db25 with pins 10,11,12,13 resistors are on the negative leg of the sensor, would not seem work the other way I will try tonight swapping sensors to see if theyre buggered, but I doubt it, theyre new.Seems strange that 2 would be buggered both on the lap count lanes. Quote routed + digital + analogue...just what i always wanted Share this post Link to post Share on other sites
kalbfellp 69 Report post Posted December 1, 2016 Are you using an interface board or direct thru the Printer port, what Progrsm are you using? Remove the resistors on the sensors and check that the collector ( short leg) is connected to the low numbers. Only the transmitters need resistors for current limiting. 1 Quote Phil Hobart Miniature Car Club Tassie Resins Email Share this post Link to post Share on other sites
fosinator 0 Report post Posted December 1, 2016 Hi thanks for the reply, using Race Coordinator and laptimer2000.Ok will try what you suggested tonite.I thought the long leg went to number 10,11,12,13.Thats what seems strange, the pit sensors work wired that way.Ill double check tonite before too many beers.Thanks Quote routed + digital + analogue...just what i always wanted Share this post Link to post Share on other sites
kalbfellp 69 Report post Posted December 1, 2016 I am not using Jaycar sensors as they 6mm Most guys use 3mm sensors with 6mm transmitters. I use Darlington sensors so they usually will work without a light gantry. Quote Phil Hobart Miniature Car Club Tassie Resins Email Share this post Link to post Share on other sites
fosinator 0 Report post Posted December 1, 2016 thanks Phil, turned them around and did the trick.I always thought the long leg(+) would receive from lower number pins so there you go. Quote routed + digital + analogue...just what i always wanted Share this post Link to post Share on other sites
