Capri-corn7
Body Post - Plastic Rod
Hi All - Have run out off hollow plastic rod that I've been using for body posts, and the local hobby shop has none on hand + their supplier has none listed. :rolleyes:
It is shiny white hard plastic rod with approx a 2mm bore - perfect for body screws
Does anyone have a trusted seller or store - online or real - they can recommend?
Pat
They are only toys .... until you pull the trigger.
It's probably not what you want but if you want cheap & you have kids or like them yourself try the following.
Get a chuppa chump stick
cut to size
tape (or a drop of superglue) an m2 screw centrally inside gluing only the outer bit of stick.
from other end fill the stick full of hot glue, could probably use a filler if wanted but hot glue is OK. I haven't had one pull out yet and thread seems to hold OK.
Then when cooled untape (or break superglue) and unscrew m2.
Only a suggestion if you can't find what you are after.
Pat
I got some. Will bring it tonight.
Podiums are for short people.
Thanks for the ideas guys. Mac has sorted me for the short term and I'll update this if/when I track down a new source... Cheers
