sticks 3 Report post Posted September 3, 2016 (edited) Sideways GROUP 5 RULES. AXLE FRONT: 1. Original front axle. 2. Must be located in the original,unmodified front axle holders. 3. Side play may be adjusted by adding axle washers. 4.wheels must be inside the guards. AXLE REAR: 1.Original rear axle bushings only,NO ball bearings. 2. The offset axel holders can replace the standard that come in the car as these parts are with the car as spare options. 3. Side play may be adjusted by adding axle washers. 4.wheels must be inside the guards. BODY: 1.Only the original unmodified Group 5 angel winder chassis is allowed. 2.Rear wings must be mounted on the body in the original position before the start of the race.Rubber supports can be added to prevent wings from breaking off.Must be in original position. 3.If the rear wing comes detached during the race,it must be re attached before the next bracket. 4.The windows must remain original and in place at all times. 5.The body must not be altered in any way.Light scrape is aloud to stop body catching on chassis. 6. All the body screws must be in place.Any screws may be used. 7. Fantasy liveries are allowed making sure all the parts are used and numbers have to be in at least 3 places on the car. CHASSIS: 1.Only the original unmodified sideways group 5 anglewinder chassis is allowed. 2. Adding weight to any part of the chassis is allowed. 3. Reinforcing or gluing parts of the chassis such as axle bushings,motor mounting post is allowed. 4. NO MAGNETS. 5. Opening screw holes to stop screws from catching is aloud. 6. Light scrape is aloud of chassis to stop body catching GEARS: 1.Original Slot.It YELLOW 28T anglewinder gear. 2.Original Slot.It 11T pinion. GROUND CLEARANCE: 1. Day light must be seen. GUIDE: 1.Any Slot.It replacement guide. 2.Any lead wire. 3.Any braid. INTERIOR: 1.Original unmodified interiors must be in place at all times. MOTOR: 1.Original unmodified 20,500rpm slot.it motors only. They are Slot-it motors that are released in sideways cars. 2.The motor wrapper has to be in tact,otherwise it will be disqualified. 3. Note the first lot of Capri cars were released with a open can both sides .These motors a still rated with the same everthing to what comes in the sideways cars to date. Anyone wishing to replace a motor can use the 20,500rpm Slot-it motor part number MN0O9CH. Motor label must be on. WHEELS/TYRES FRONT:(NO SILICON TYRES.) 1.Only original slot.it tyres are permitted. 2.Sanding gluing and truing is allowed. 3.Tyres must touch on set up board when checked. 4.Original rims only. WHEELS/TYRES REAR:(NO SILICONS TYRES.) 1.FOAM TYRES ONLY. SLOT IT/NSR PART NUMBERS 9024 AND 9025/SCALEAUTO SC-2009P 2.Sanding gluing and truing is allowed. 3.TYRE TREATING, CONDITIONING OR SOFTENING IS NOT ALLOWED. Ford Capri Porsche 935/78 BMW M1 LANCIA BETA MONTECARLO Ferrari 512BB Group 5 SLOT IT GROUP C RULES. AXLE FRONT: 1. Original front axle. 2. Must be located in the original,unmodified front axle holders. 3. Side play may be adjusted by adding axle washers. 4.wheels must be inside the guards. AXLE REAR: 1.Original rear axle bushings only,NO ball bearings. 2. Must be located in original,unmodified rear axle holders. 3. Side play may be adjusted by adding axle washers. 4.wheels must be on the inside of the guards. BODY: 1.Only the original unmodified Slot.It group C in-line chassis is allowed. 2.Rear wings must be mounted on the body in the original position before the start of the race.Rubber supports can be added to prevent wings from breaking off.Must be in original position. 3.If the rear wing comes detached during the race,it must be re attached before the next bracket. 4.The windows must remain original and in place at all times. 5.The body must not be altered in any way. 6. All the body screws must be in place.Any screws may be used. 7. The rear spats can be removed on the XJ9 and XJ12 Jaguar. 8. Painted liveries are allowed making sure all the parts are used and numbers have to be in at least 3 places on the car. Legal bodies....... Mercedes Sauber C9 Mazda 787 B Lancia LC 2 jaguar XJ9 and XJ12 Porsche 956 KH Porsche 962 C Porsche 956 C Toyota 88 C Nissan R89C CHASSIS: 1.Only the original unmodified Slot.It group C chassis is allowed. 2. Adding weight to any part of the chassis is allowed. 3. Reinforcing or gluing parts of the chassis such as axle bushings,motor mounting post is allowed. 4. NO MAGNETS. 5. Opening screw holes to stop screws from catching is aloud. 6. Light scrape is aloud of chassis to stop body catching GEARS: 1.Original Slot.It YELLOW 28T crown in-line gear. 2.Original Slot.It 9T pinion. GROUND CLEARANCE: 1. Day light must be seen. GUIDE: 1.Any Slot.It replacement guide. 2.Any lead wire. 3.Any braid. INTERIOR: 1.Original unmodified interiors must be in place at all times. MOTOR: 1.Original unmodified 21,500rpm slot.it group C motors only. 2.The motor tabs holding the end bell must not be tampered with in any way,otherwise it will be disqualified. 3.Cars that came with the 25,000rpm motor can change them to a 21,500rpm motor. WHEELS/TYRES FRONT:(NO SILICON TYRES.) 1.Only original slot.it group C tyres are permitted. 2.Sanding gluing and truing is allowed. 3.Tyres must touch on set up board when checked. 4.Original rims only. WHEELS/TYRES REAR:(NO SILICONS TYRES.) 1.FOAM TYRES ONLY. SLOT IT foam to suit slot it wheels part number WH1211-AL OR WH1190-AL/NSR PART NUMBERS 9024 AND 9025/SCALEAUTO SC-2009P 2.Sanding gluing and truing is allowed. 3.TYRE TREATING, CONDITIONING OR SOFTENING IS NOT ALLOWED . Edited September 3, 2016 by sticks Quote Share this post Link to post Share on other sites
sticks 3 Report post Posted September 3, 2016 (edited) Edited September 3, 2016 by sticks Quote Share this post Link to post Share on other sites
sticks 3 Report post Posted September 3, 2016 (edited) 2016 REGULATIONS 1/24 FORMULA LeMANS 1.0 BODY 1.1. Only 1/24 ACE #24009 Oreca FLM09 Body Kit is allowed to be used. 1.2. Minimum rear wing height is 42.0mm (measured at rear of car ground to top). 1.3. Fantasy liveries in the spirit of 1:1 FLM, LMP Racing are permitted. 1.4. Light set ZMachine 165Q is required 1.4. Minimum body weight including body mounts is 18.0 g. 2.0 CHASSIS 2.1. Only Plafit 1800SLPJ Chassis and its kit parts can be used. 2.2. Axle Bearing Holders 1709 (B,C,D) can be used. 2.3. 1708G and 2808J Motor Brackets can be used. 2.4. 1711G and 2811J Motor Stays can be used. 2.5. Aftermarket Carbon replacement parts are allowed as long as they are commercially available. 2.6. Chassis has to be adjusted according to the body and its dimensions making sure that all wheels are covered by the body when viewed from above. 2.7. All original mounting points and basic configuration must be retained. 2.8. No chassis modifications other then within its design limits. 2.9. No soldering permitted to hold motor into position. Only motor screws are to be used. 2.10. No traction magnets. 2.11. Body tape or plastic strip may be used to hold lead wires in place. 2.12. Additional weight may be placed into the centre openings of the main chassis plate in accordance with the minimum ground clearance rule. 3.0 GROUND CLEARANCE 3.3. 1.0mm under the entire chassis including gear. 4.0 FRONT AXLE 4.1. Any 3mm non. Independent front axles allowed. 4.2. Any 3mm axle oilites or axle ball bearings allowed. 5.0 FRONT WHEELS 5.1. Any Aluminum front wheels with a minimum diameter of 21mm can be used. 5.2. Sakatsu Brake Discs (2100) are to be used with all Sakatsu wheels. 5.3. 3D Wheel Inserts in modern LMP/GT design have to be used. 5.4. Any Hard Sponge Tires sealed or non-sealed can be used. 5.6. Minimum tire and rim width is 6mm. 5.7. Minimum tire diameter is 26.0mm. 5.8. Maximum front spur width is 86.0mm but never wider then the body. 6.0 REAR WHEELS 6.1. Any Aluminum rear wheels with a minimum diameter of 21mm can be used. 6.2. Sakatsu Brake Discs (2100) are to be used with all Sakatsu wheels. 6.3. 3D Wheel Inserts in modern LMP/GT design have to be used. 6.4. Maximum tire and rim width is 16mm. 6.5. Minimum tire diameter is 26mm. 6.6. Maximum rear spur width is 86.0mm but never wider then the body. 6.7. Plafit Black Magic Rear Tires (8441BM or 8442BM) and Scaleauto ProComp3 Tires are allowed only. 6.8. Use of Goo and/or any other tire softener, liquids etc. is not allowed. Cleaning with Tape or Shellite only is permitted. 7.0 REAR AXLE 7.1. Any 3mm. 7.2. Any 3mm axle oilite bushings or axle ball bearings can be used. 8.0 GEARS 8.1. Any plastic 50 pitch spur gears for 3mm axles. 9.0 PINION 9.1. Any 50 pitch. 10.0 MOTOR 10.1. 13D Cheater IV Motor only. 10.2. Original lettering on the motor can has to be visible. 10.3. Sealed Motors are not to be opened or modified in any way. 10.4. Any lead wire. 10.5. Different motors will be nominated at certain race events. 11.0 WEIGHT 11.1. Minimum total car weight is 155g. 12.0 REPAIRS 12.1. The following repairs must be carried out immediately under Green Light (race condition): (a) replacing or refitting the rear wing* ( replacing or refitting the driver figure including the driver head* *can be done with tape 12.2. All repairs must be carried out under green unless specifically approved by the Race Direction. 0 Edited September 29, 2016 by sticks Quote Share this post Link to post Share on other sites
sticks 3 Report post Posted September 3, 2016 CAR CATEGORY REGULATIONS 2016 MINI-Z GT CARS 1.0 BODY 1.1. Only Mini-Z Hard Plastic GT Bodies which are listed on the official body list are allowed to be used. No street cars, race cars only which have to feature at least two race numbers and some typical modern GT Car race sponsor logo decals. 1.2. White unpainted body kits can be used however all kit parts have to be included during assembly. Body has to be painted and decaled. 1.3. All body detail parts like mirrors, windscreen wipers, wings etc. have to be retained on the body at all times. 1.4. Rear wings can be rubber mounted. Aftermarket mirrors are allowed. 1.5. Ford GT has to have rear wing (AR-086 or AR-090) fitted. 1.6. The body holders (both sides and front) for the Kyosho display chassis can be removed and sanded. No other part of the body can be sanded, lightened or modified in any way. 1.7. All wheel arches are not allowed to be sanded and/or widened. 1.8. A two piece driver interior (vacuum formed with separate drivers head) is to be used. The interior has to cover all windows and open cockpits. No chassis parts are allowed to be visible. Half sized interiors are allowed and rear window plus both rear side windows can be painted black from the inside. 2.0 CHASSIS 2.1. Only Plafit Super24 #1700 (no #1700G and SLP versions) and Plafit4 #1900 (not #1900S) can be used. 2.2. All Plafit #1700 and #1900 chassis system parts can be used except #1700G and SLP parts. Plafit #3309, B and C in combination with #1705G/S/K can be used. 2.3. No chassis parts mixing between #1700 and #1900 chassis systems except for #1707B - F. Body Mount Plates #1906S, #1906SN and #1906SO can be used for flat body mounting. 2.4. Chassis has to be adjusted according to the body and its dimensions, making sure that all wheels are covered by the body when viewed from above. 2.5. Chassis set-up has to be done only within its design limits and only with the original accessories i.e. changing spring tension or the amount of chassis/body movement etc. 2.6. All original mounting points and basic configuration must be retained. 2.7. No chassis modifications other then within its design limits. 2.8. No soldering allowed to hold motor into position. Only motor screws are to be used. 2.9. Body tape or plastic strip may be used to hold lead wires in place. 2.10. Additional weight may be added as long as it is placed on top of the chassis. 2.11. Chassis springs, spacers and/or additional screws and nuts may be substituted, added or removed. 2.12. Plafit flat body mounts can be used on both chassis in their intended position either as additional weight or for body mounting. 2.13. No mount plates protruding into wheel arches however minor re-shaping of the flat body mount plates for proper body fitment is allowed. 2.14. No Traction Magnets. 2.15. Chassis blue-printing is allowed. No excessive sanding for weight reduction ! 3.0 GROUND CLEARANCE 3.1. Minimum 1.0mm under the entire chassis including gear for non-magnet racing. 4.0 FRONT AXLE 4.1. Solid 3mm one piece non-independent only. 4.2. Any 3 x 6mm oilite axle bushings or 3 x 6mm axle ball bearings. 5.0 FRONT WHEELS 5.1. Any 3mm axle diameter Aluminum Wheels. Minimum diameter including tire is 21mm. 5.2. Minimum wheel/tire width is 7mm. No independent front wheels allowed. 5.3. Any black tires, sponge or rubber. 5.4. To retain true-to-scale appearance the wheel diameter is determined by the individual wheel arch size of the body used. 6.0 REAR WHEELS 6.1. Any 3mm axle diameter Aluminum Wheels. Minimum diameter including tire is 22mm. 6.2. Plafit Black Magic Sponge Tires, Plafit Rubber Tires (labelled) as well as Scaleauto ProComp3 Sponge Tires are allowed to be used. 6.3. Use of Goo and/or any other tire softener, liquids etc. is not allowed. Cleaning with Tape or Shellite only is permitted. 6.4. To retain true-to-scale appearance the wheel diameter is determined by the individual wheel arch size of the body used. 7.0 WHEEL INSERTS 7.1 3D Wheel inserts have to be used at all times. 8.0 REAR AXLE 8.1. Solid 3mm metal axle only. 8.2. Any 3 x 6mm oilite axle bushings or 3 x 6mm axle ball bearings. 9.0 GEARS 9.1. Any plastic 50 pitch spur gears for 3mm axles. 10.0 PINION 10.1. Any 50 pitch. 11.0 MOTOR 11.1. Only 13D Plafit 8635 IV Motor 11.2. Original lettering has to be visible. 11.3. Sealed Motors are not to be opened or modified in any way. 11.4. Any lead wire. 12.0 WEIGHT 12.1. Minimum total car weight is 160g. Mini-Z Body Sets GT Class List 2016 02/01/2016 MZP212 Aston Martin DBR9 MZP419 Audi R8 LMS MZX25 Chevrolet Corvette C5-R MZP129R Ferrari F355 Challenge MZX310 Ferrari 360GTC MZX321 Ferrari F40 MZP224 Ferrari F70 (LaFerrari) MZX311 Ferrari 575GTC MZP201 Ferrari Enzo MZP220 Ferrari Enzo GT Concept MZP216 Ferrari 599XX MZP221 Ferrari 458GT2 MXP328 Ferrari F430GT MZX211 Ferrari FXX MZX209 Ford GT * MZP301 Honda NSX 2003 MZX315 Honda NSX 2005 MZP/MSX324 Honda NSX 2007 MZP218 Honda HSV-010 MZP228 Honda NSX Concept MZG202 Lamborghini Diablo VT MZP215 Lamborghini Murcielago GT1 MZX319 Lexus SC430 (2006) MZP223 Lexus SC430 (2012) MZP415KM Mazda RX-7 FC MZX203 McLaren F1 GTR LM MZP213 McLaren F1 GTR LT MZP226 McLaren MP4-12 GT3 ZK-008 McLaren MP4-12 GT3 MZG305 Nissan 350Z 2004 MZX317 Nissan 350Z 2005 MZP/MSX325 Nissan 350Z 2007 MZG306 Nissan 350Z Hasemi Endless MZP411 Nissan GT-R MZP214 Nissan GT-R R35 R246 Nissan R390 GT1 MZP330 Porsche 911 GT1 MZP126 Porsche 911 GT3 RSR MZX303 Toyota Supra 2003 MZP334 Toyota GT-One * Must have Rear Wing AR-086 or AR90 Quote Share this post Link to post Share on other sites
sticks 3 Report post Posted September 3, 2016 2016 REGULATIONS 1/24 HISTORIC’S 1.0 BODY 1.1. Only 1:24 true-to-scale vacuum formed Lexan Bodies representing historic Can-Am Cars as well as historic Sports Cars and Sports Prototype Cars listed on the 2012 Official Body Homologation List. No other bodies are allowed. 1.2. Minimum body material thickness is .010”. 1.3. Cut out and mounting of body has to reflect the actual 1:1 car. 1.4. The presentation of the body (paint design, decals and additional detail parts) has to be as realistic as possible to a 1:1 car of this time. 1.5. A minimum two piece driver interior (vacuum formed with separate drivers head) to be used. Interior has to cover all windows and open cockpits. No chassis parts are allowed to be visible. 2.0 CHASSIS 2.1. Plafit Excel 1300 or 1300U as well as Plafit Super24 1700C. 2.2. Chassis has to be adjusted according to the body and its dimensions used making sure that all wheels and the guide are covered by the body when viewed from above. 2.3. Maximum polar length (distance back side of rear axle to centre of guide pivot point) is 114mm. 2.4. Chassis set-up has to be done only within its design limits and only with the original accessories i.e. changing spring tension or the amount of chassis/body movement. 2.5. Nuts, screws, springs and washers are free to choose. 2.6. All original mounting points and basic configuration must be retained. 2.7. No further chassis modifications other then within its design limits. 2.8. No soldering allowed to hold motor into position. Only motor screws are to be used. 2.9. Body tape or plastic strip may be used to hold lead wires in place. 2.10. Additional weight may be added as long as it is placed on top of the Chassis and is not protruding outside the chassis edges. 2.11. Chassis blue-printing is allowed. No excessive sanding for weight reduction ! 2.12. The Front Chassis Plate Excel 1304C can be shortened only above the two long holes which fit the Front Axle Bracket in order to fit low-front bodies. However both long holes must be retained entirely. 2.13. All 1300 Excel Chassis system parts can be used except 1307C, -CB, -CC, -CD (Flat Body Mount system) and 1314B (front Chassis Weight Plate). 2.14. Only the 1700C Super24 Chassis RTR standard parts can be used which are : 1701J Main Chassis Plate, silver 1703B Guide Holder, long 3309C Bearing Holder +1.0mm, front 1705G T-Plate, blue 1706 Body Mount Plates 1707 Body Slide Mounts 1708 Motor Bracket 1709B Bearing Holder +0.5mm, rear 1710 Subframe 1711 Motor Stay 2.15. Only these additional 1700 Super24 Chassis system parts can be used : 1701 Main Chassis Plate 1703 Guide Holder 1709 Bearing Holder, rear 1709C Bearing Holder +1.0mm 1709D Bearing Holder +1.5mm 1710B Subframe +6mm 1710C Subframe +12mm 1710J Subframe, blue 1710T Subframe with Adjuster 1710BT Subframe +6mm with Adjuster 1710CT Subframe +12mm with Adjuster 1717A Chassis Stabilizer Set Type A 2.16. Flat Body Mounts cannot be used. 3.0 GROUND CLEARANCE 3.1. 1.0mm under the entire chassis including gear. 4.0 FRONT AXLE 4.1. Solid one piece 3mm diameter axles only. 4.2. Any 3mm oilite bushings or ball bearings. 4.3. Maximum front spur width is 79.0mm but never wider then the body used. 5.0 FRONT WHEELS / TIRES 5.1. Any Plafit 17mm diameter Alu Wheels. Minimum tire diameter is 22mm. 5.2. Any Hard Sponge Tires non-sealed. 5.3. Minimum tire width is 7mm. No independent front wheels allowed. 6.0 REAR WHEELS / TIRES 6.1. Any Plafit 17mm diameter Alu Wheels. Minimum tire diameter is 24mm. 6.2. Plafit BM Sponge Tires only, maximum tire width is 16mm. 6.3. Use of Goo and/or any other tire softener, liquids etc. is not allowed. Cleaning with Tape or Shellite only is permitted. 7.0 WHEEL INSERTS 7.1. 3D Wheel Inserts have to be used on all wheels at all times. 8.0 REAR AXLE 8.1. Solid metal 3mm axles only. 8.2. Any 3mm oilite bushings or ball bearings. 8.3. Maximum rear spur width is 79.0mm but never wider then the body used. 9.0 GEARS 9.1. Any plastic 50 pitch spur gears for 3mm axles. 10.0 PINION 10.1. Any 50 pitch 10 T only. 11.0 MOTOR 11.1. Only 13D Plafit Fox IV Motor. 11.2. Original lettering has to be visible. 11.3. Sealed Motors are not to be opened or modified in any way. 11.4. Any lead wire. BODY HOMOLOGATION LIST 1/24 HISTORIC’S 27. February 2016 SUNSET RACING SHELLS (AUS) (Lexan) - 1967 Chaparral 2F * - 1967 Chaparral 2G * - 1966 Elfin T400 - 1966 Ford GT40 MKII - 1967 Ford GT40 MKIII - 1969 Ford GT40 Mirage - 1968 Ford 3L P68 - 1962 Honker II - 1964 King Cobra - 1965 Lotus 40 - 1968 Marcos Mantis - 1966 McLaren MKII - 1967 McLaren M6A - 1968 McLaren M8A ACE BODIES (AUS) (Lexan) - 24300 1969 Porsche 917LT - 24301 1970 Porsche 917K - 243011 1970 Porsche 917K (old) - 24330 1966 Porsche Carrera 6 - 24400 1966 Elfin T400 - 24817 1968 Marcos Mantis - 24810 1967 Matich SR3 - 24811 1969 Ferrari 312P Spyder - 24812 1970 Ferrari 512M - 24813 1971 Ferrari 312PB - 24814 1970 Ferrari 712P - 24815 1970 Chevron B19 - 24807 1969 Lola T163 - 24408 1971 Lola T260 - 24817 1967 Lola T162 - 24816 1966 Lola T70 Spyder - 24820 1971 Porsche 908/3 - 24821 1969 Matra MS650 - 24822 1967 Ferrari 350P4 CanAm - 24409 1968 McLaren M8A - 24412 1970 Chaparral 2J - 24818 1968 Ford 3L P68 - 24823 1968 Ford GT40 Mirage LANCER BODIES (USA) (Lexan) - 146 1966 Ford J - 156 1967 Ford GT40 MK4 - 153 1968 Lola T-70 MKIII GT - 157 1969 Ford GT40 Mirage - 163 1967 Ferrari 350P4 CanAm VINTAGE BODIES (USA) (Lexan) - 24-47 1966 Lola T-70 Roadster - 24-51 1966 Ford GT40 - 24-61 1968 Lola T-70 MKIII GT * These bodies can only be used with a high-set wing as they have never raced without. 0 Quote Share this post Link to post Share on other sites
sticks 3 Report post Posted September 3, 2016 (edited) 1/24th Scale Auto Regulations 2016 (as used in Australia) - Please take note, if it is not specifically mentioned in these regulations - THEN IT IS NOT LEGAL. All the changes made to the 2015 regulations are shown in RED. 1.1.0. GENERAL DESCRIPTION (a) The only cars permitted to enter are: (i) The Scale Auto Porsche 911 GT3 RSR(997). (Not the GT3 Rally or GT3 Cup versions). (ii) The Scale Auto BMW M3 GT2. (iii) The Scale Auto Jaguar XKR-RSR GT2. (iv) The Scale Auto Mercedes Benz SLS GT3. (v) The Scale Auto Audi R8 LMS GT3. (vi) The Scale Auto BMW Z4 GT3 (vii) The Scale Auto Viper SRT GTS-R (b ) It is the responsibility of the racer to ensure that the purchased Scale Auto cars are accurate, complete and without missing parts. (Including small plastic and photo edged parts.) Please check all RTR prepainted cars before you buy it for this racing as some of these RTR prepainted cars have been known to be without small parts. © An original example of homologated Scale Auto cars as described by Art.1.1.0 (a) will be at Technical Control as reference for the Technical Director and Scrutineers. In the case of all disputes, the judgement of the Technical Director(or race jury) will be final and binding. (d) All of the chassis and body parts that come with the Scale Auto cars as described in Art. 1.1.0.(a) must be used. See Rules-Pictures for additional clarification. If a part is shown in these pictures it must be on the car according to the manufacturer's intended mounting and location. The only exceptions are as follows: Art. 1.1.3. (b ). 1.1.1 ALLOWED MODIFICATIONS AND BLUEPRINTING: a - All chassis parts may be flattened and sanded for optimum fit without lightening or deliberately changing the shape of such part (exceptions to follow). b - The guide tongue shoulders may be cut to a 45 degree angle from the standard 90 degrees to better suit certain guides types other than the Scale Auto guides. c - The guide tongue may be bent where it protrudes forward of the T plate to facilitate guide angle and height adjustment. d - Washers may be used between the T plate and main chassis plate to facilitate height and angle adjustment of the front axle and/or guide. e - The plastic mounting posts inside the body may be trimmed and/or washers may be added between the posts and metal body mount plate to facilitate body height adjustment and alignment. f - The motor mount may have the slot in it changed to help with gear mesh and motor line up. g - The motor mounting bolt may also be replaced with a countersunk bolt fitted from the bottom of the main chassis plate. This will require the hole to be drilled out and countersunk to make sure the bolt head does not affect the ride height measurement. h - The forward face on the rear axle carriers may be shaped to allow the motor to be move closer to the rear axle. This is intended to get a more sidewinder fit especially when using the 10T pinion where required. i - Parts of free make are restricted to: (i) nuts, bolts, spacers and washers, (ii) the guide, guide nut and washers, (ii) braid, braid clips & lead wires, (iv) axles (v) axle bearings, (vi) ballast lead weights, (vii)3 –dimensional wheel inserts, (viii) M50 spur gear, (ix) M50 pinion gear (check on correct size for the proposed hand out motor). j - Scale Auto tuning parts including the carbon H-plates, spring plates, guides holders, different height axle holders, carbon rear wings (excluding the wing supports) etc. are NOT permitted. 1.1.2. WEIGHT, DIMENSIONS & GROUND CLEARANCE (a) The minimum weight for a complete Scale Auto car is 190.0g. (b )The minimum weight for the body with the body mounts and fixing screws attached is 55.0g. (c) - The ground clearance (of the chassis only) will be measured with the guide out of play so that all four wheels sit flat on the tech block. (d) - The chassis ground clearance at the start of every race is never less than 1.8mm. (e) - The ground clearance during or at the end of any race is never less than 1.40mm (if found to be in breach during the race, it must be rectified under green - if after the end of the race; it will result in the loss of the total laps scored in the best race bracket during the race). (f) - The ground clearance for the body will be measured with the body attached to the chassis as it will be raced. (g) - The body ground clearance at the start of every race is never less than 1.4mm. (h) - Additional weighting of the body can be applied anywhere on the inside of the body or on top of the metal body mounts. (i) - The distance from the top of the H plate to the bottom of the chassis plate is never more than 4.0mm. (j) - Additional weighting of the chassis may only be on top of the chassis, NOT visible when viewed from below. 1.1.3. CHASSIS (only non-drop arm version). (a) The chassis must be assembled with screws and/or nuts and bolts using the original mounting holes. (b ) The chassis must be assembled in the exact manner and orientation of the production RTR car. In this instance it is noted that some RTR cars are shipped with the guide holder mounted below and other above the T-plate. It is therefore up to the racer to decide which position he prefers for the guide holder on his car. The latest chassis may have a magnet box fitted just in front of the motor. Please remove this box and magnet completely. The remaining opening in the chassis may be filled in if the driver chooses to do so. This filling may consist of any non-magnetic material. (c) The chassis plates may be flat sanded to remove burrs, sharp edges and swelling. (d) The original mounting holes can be re-countersunk to properly seat the screws. (e) The original MSC/Scale Auto logo on the bottom face of the main chassis plate must remain visible to the Technical Control. On chassis plates with painted logo's it must be preserved by using transparent tape over it. (f) The original chassis plates, parts and metal body holders cannot be repainted or refinished in any way. (g) The length of the guide blade cannot exceed 27, 0 mm and this guide blade is the only part of the chassis that may enter the track's slot. (h) No part of the chassis may be visible when viewing the car from above. (i) The alternative aluminium H-plate (photo below) is legal as sometimes the chassis are shipped with them and other times with a steel version. 1.1.4. MOTOR, GEAR AND PINION (a) The motor will be decided by the event organiser, but will be limited to the following: Scale Auto SC-26 Endurance or the NSR 25000 Evo. we will be using the NSR 25000 EVO for NSW Titles (b ) Soldering may only be used to attached the lead wires to the motor terminals. (c )Motor coolers or heat dissipating products of any kind are not permitted. (d) Only M50 pitch pinion and M50 spur gears are permitted. (e) The ratio is fixed at 12:44 for the SC-26 Endurance motor and 10:44 for the NSR 25000 Evo motor. 1.1.5. AXLES, BEARINGS & WHEELS (a) Only solid steel 3 mm diameter axle's front and rear are permitted. No independent front axle configurations of any kind are permitted. (b ) Ball bearings for 3mm axles are permitted. (c) Front wheels must be either the standard hard rubber wheels with rims as supplied with the RTR cars or a minimum diameter of 26.3mm (at the start of all races) when using the RTR Scale Auto racing wheels. The Scale Auto parts SC-2715P or SC-2709P may be used to achieve the 26.3mm minimum starting diameter. (d) Each front wheel must make minimum 7.5mm of contact with the tech block with the guide out of play. Front tires may be hardened and polished. (e) Rear wheels are RTR Scale Auto SC-2421P ProComp 3 wheels with 27,5mm OD, 13.0mm wide. Only the Scale Auto wheels are allowed and may not be substituted with other brands. At events where handout wheels and tyres are supplied, the handout wheels and tyre diameters maybe altered if specifically allowed by the event director. At all events when the rear wheel diameter has been altered, and this Scale Auto part as quoted, is used, most of the orange sidewall markings must still be visible. To tell if the correct Scale Auto wheel rims are being used - the actual screw hub on the rim must be square with two set screw positions in each hub. Furthermore check that each rim also has an extended axle section into the rim section itself. Altering the rear wheel diameter will not void the minimum starting ride height as per rule 1.1.2.(d). (f) Rear tires may not under any circumstances be treated with any kind of tyre dressing, or compound or traction product. (g) Removing dirt, dust and loose rubber particles from the tyres may only be performed with a tape roll or Shellite provided by the Race Direction. (h) All four wheels must be fitted with three-dimensional wheel inserts (with or without brake discs and callipers) correct to the car. (No photo etched or vinyl cut reproductions will be allowed). (i) The wheels may not protrude outside of the body when viewed from above. (j) No car can have a front spur greater than 80mm or rear spur greater than 83mm, measured at the widest point of the front and rear axles. (This includes any protruding wheel inserts that may be fitted). 1.1.6. BODY & INTERIOR (a) All bodies and interiors must be painted. (Interiors with at least three different colours and bodies with at least a coat of clear paint covering the complete outside of the body shell). (b ) Fantasy liveries in the spirit of 1:1 motor sport are permitted. (c )Three number shields typical of 1:1 motor sport are required. (d) The stock rear wing uprights only may be replaced or reinforced with rubber parts of equal or like shape. The Scale Auto Carbon Rear wing may not be used, but the rubber wing mounts supplied with these wings may be used.(Should a wing go missing or get broken beyond repair a replacement part may be purchased as long as it is the original part as sold by Scale Auto. For example the BMW part number is SC-7612 and the Mercedes is SC-7614 etc). (e) All the cars are permitted to use the full Scale Auto Lexan window and interior kits. Only the roll cage from the original hard plastic interior must be refitted to the lexan interior. (f) Mirrors and wipers on some cars are very fragile and cars will be allowed to race without them when it is obvious that the mirror(s) has broken off. Drivers are encouraged to present cars with mirrors and wipers at the start of all races (h) No modifications of the body are permitted other than those described by Art. 1.1.6(a-e) 1.1.7. ADDITIONAL NOTES & CLARIFICATION TO RACERS. (a) Metal body mounting brackets SC-8117 can be used in place of the plastic part as first shipped on the Porsche 911 RSR GT3 cars in early 2010. (b ) Only Scale Auto lexan interior and window kits may be used where allowed. (The air vent - photo below - that comes with the Audi lexan window and interior kit is not allowed). (c ) The gas filler caps in the Mercedes that are molded into the lexan windows should be trimmed away so that the original plastic filler caps are used. This principal will also apply whenever a lexan part may be moulded with corresponding external body parts restricting the fitment of the lexan window. The Viper lexan interior has a vent moulded under the rear window. This vent is to tall and will need to be cut down for the interior to fit properly. (d) When fitting the lexan interior the legs of the roll cage may be shortened to be able to fit it into the space between the lexan interior floor and the roof of the car. Currently this is only the case on the Mercedes SLS. (e) The BMW Z4 white kits are supplied with four small front winglets, these may be used at the discretion of the builder. The body kit is also supplied with two different rear wing mounts. Either of these may be used. However, if the mounting legs are replaced with a flexible material, the secondary wing between the mounting legs must be retained. or (f) The Viper RTR white kits are supplied with two front grills. If using the open one, then the relevant photo edged part must be used. The RTR white kits are also supplied with two wings, the rubber wing mounts supplied may be used with the relevant wing. (g) Racers are warned that cars with missing parts will not be allowed to enter. (Even if it was lost during practice or on the way to scrutineering). (h) During lane changes no work on the cars at all will be allowed - work on the car may only be done under green. (i) Event organizers must provide all actual scrutineering tools for the event at the start of official practice. These tools must include a scale measuring to at least 1/10th of a gram, specific calipers or gauges for measurement of the front and rear spur and specific calipers or gauges to measure the minimum front wheel diameter and width. Specific gauges to measure ride height before, during and after the race must also be provided at this time. These tools will be the only tools that will be used by the scrutineer(s) during the event. END. Hi guys, THESE REGULATIONS ARE NOW LOCKED FOR 2016. THE ONLY CHANGES FROM NOW ON WILL BE WHEN NEWLY RELEASED CARS HAVE BEEN PARITY TESTED FOR INCLUSION IN THESE REGULATIONS OR WHEN ANY SPECIFIC PART IS REPLACED BY SCALE AUTO WITHOUT NOTICE. THESE AMENDMENTS (if required) WILL ONLY TAKE PLACE AT THE END OF MARCH, JUNE AND SEPTEMBER 2016. THESE TYPES OF CHANGES WILL ALWAYS BE SUBJECT TO AVAILABILITY OF CARS AND PARTS TO EVERYONE RACING IN AUSTRALIA - AVAILABILITY ON THE WWW WILL BE CONSIDERED ACCEPTABLE. Please keep an eye on the discussion section of this forum for any developments that may impact on possible regulation changes. Thank you for participating in the formation of these regulations making this the great class it is! Edited September 14, 2016 by sticks Quote Share this post Link to post Share on other sites
Tony.A 8 Report post Posted September 15, 2016 Hi Sticks,what are the rules for the 1/32 Slotworx V8 Supercars please as i have built one to show the rest of the guys here at Mobile Raceways what they are like.We have just started racing the 1/24 Slotworx V8 Supercars Quote Share this post Link to post Share on other sites
Camber 19 Report post Posted September 15, 2016 Hi Tony, There are links to 1/32 rules on my website. Cheers, - Cam Quote Hoo Roo Share this post Link to post Share on other sites
Tony.A 8 Report post Posted September 15, 2016 Thanks Cam,we have 6 to 8 1/24 Slotworx cars racing on the Wednesday night now. Quote Share this post Link to post Share on other sites
sticks 3 Report post Posted September 15, 2016 2016 Slotworx V8 1/32 REGULATIONS FRONT AXLE: 1. Any solid metal 3/32 front axle. No independent front axles. 2. Must be located in the original, un-modified front axle holders. 3. Side play may be adjusted by adding axle washers. 4. Wheels must be inside the guards. 5. Maximum front spur 61.5mm. REAR AXLE: 1. Any solid metal 3/32 rear axle. 2. Original rear axle bushings only, NO ball bearings. 3. Must be located in original, un-modified rear axle holders. 4. Side play may be adjusted by adding axle washers. 5. Wheels must be on the inside of the guards. 6. Maximum rear spur 62.5mm BODY: 1. Only the original unmodified Slotworx 1/32 V8 body is allowed. 2. Rear wings must be mounted on the body in the original position before the start of the race. Rubber supports can be added to prevent wings from breaking off. Must be in original position. 4. The body must not be altered in any way. 5. Painted liveries should reflect actual cars or fantasy liveries and numbers have to be in at least 3 places on the car. 4. The body must not be altered in any way. 5. Painted liveries should reflect actual cars or fantasy liveries and numbers have to be in at least 3 places on the car. CHASSIS: 1. Only the original unmodified Slot.it Ready to Run sidewinder chassis CH31B/C is allowed. No grinding allowed. 2. Only components included in the Slot.it Ready to Run sidewinder chassis CH31B/C and the Slotworx 1:32 SCALE KIT SX132-H/F - Australian V8 are allowed. 3. The Slotworx 1:32 SCALE KIT SX132-H/F - Australian V8 must be assembled in accordance with the instructions provided on the Slotworx website. Nuts, bolts and spacers are of free make. 4. Adding weight to any part on top of the chassis inside the car is allowed. Weight cannot be viewed from below. 5. Reinforcing or gluing parts of the chassis such as axle bushings, motor mounting post is allowed. 6. NO MAGNETS are allowed except for those in the motor. GEARS: 1. Original Slot.It black 32T plastic or 34T light blue aluminium spur gear. 2. Any Slot.It 11T pinion. GROUND CLEARANCE: 1. 1.0mm ride height. Spacers are allowed between the pod/front axle and chassis. Only the 0.5mm offset pod can be used. GUIDE: 1. Any guide. 2. Any lead wire. 3. Any braid. INTERIOR: 1. Slotworx interiors must be in place at all times. MOTOR: 1.Original unmodified V12/3 21,500rpm Slot.it orange endbell motors only. 2.The motor tabs holding the endbell must not be tampered with in any way, otherwise it will be disqualified. WHEELS/TYRES FRONT: (NO SILICON TYRES.) 1. Any Slot.it rims are permitted. If changing the rear wheels these can be used on the front. 2. Sanding, gluing and truing is allowed. Hardening/sealing is allowed. 3. Tyres must touch on set up board when checked. WHEELS/TYRES REAR: (NO SILICONS TYRES.) 1. FOAM TYRES ONLY. SLOT IT foam to suit slot it wheels part number WH1211-AL OR WH1190-AL NSR PART NUMBERS 9024 AND 9025, SCALEAUTO SC-2009P. 2. Minimum tyre diameter 19mm. Sanding and truing is allowed. 3. TYRE TREATING, CONDITIONING OR SOFTENING IS NOT ALLOWED. Quote Share this post Link to post Share on other sites
