choc-ice 2 Report post Posted August 30, 2016 This was a much bigger task than I first imagined. Here's the idea: build the Harrington Legionnaire coach from the 1969 Italian Job film, sounds straightforward? What this actually translated into was: 1. Design the coach with its opening rear doors, floor to let the Minis drive inside, steering and everything else to make such a huge vehicle work on a regular Scalextric track. 2. Agonise over how to manufacture a few copies. Slush cast? Pressure cast? 3D print? A mixture of a 3D printed front, slush cast roof and fabricated floor? Revisit this several times over the course of its development. 3. Source some Mini Coopers and almost fall over in horror as I realise they are far too rare and expensive to mess about with. 4. Make a resin Mini bodyshell. 5. Come up with a completely new chassis to fit under the Mini with its tiny overhang, the main problem being a rear axle contrate gear that's smaller diameter than the tiny wheels and tyres. Yeah, yeah, stop the moaning and get on with the pictures, will you? As usual, the coach started with a 3D model Make sure the Minis will fit inside, design a steering system which is a modification of my normal system being wider and linked together. The torque to move all of this comes from the same 2 stage gear reduction system used on the truck I built last year. Not especially speedy but plenty of go to deal with all the weight. Hinged doors and ramp came next. And they were printed. it's 340mm long, 13½ inches! Paint, graphics and we're done! For the Minis I made a resin bodyshell based on a mixture of Scalextric and Airfix parts The chassis uses motor and rear axle from the Carrera Go cars. It doesn't need suspension like my other slot cars as Minis don't lean in corners, but it does need steering so I used the front end from my PCS32 steering. Get the graphics done and build it up. And this is how they look together. When I've got a little more time I'll do a video for these, but the Minis seem to work well on the track. And so does the coach. Don't be a wimp with the power, kick the tail out and get it sliding so the inside rear wheel doesn't drop off the inside curve. Quote 3D modelling a slot car - Dodge Monaco Share this post Link to post Share on other sites
ZeGas 65 Report post Posted August 30, 2016 Bloody Nora, that's brilliant. Will you use lead weight or gold bullion for ballast. From historical evidence I would suggest not to put too much at the rear. Did you use solidworks for the modelling? I would love a set of those, if you ever decided to sell (some hope huh). Quote Cheers Grant ....................................................... Home Track..........Corvette C1 Build..........McLaren M1A Build..........Maserati 300S Build..........Allard J2 Build..........50's Diner..........Iso Griffo A3C 3D Printed Adjustable Chassis..........3D Print Projects If life gives you lemons, take them, free s#!t is cool. Share this post Link to post Share on other sites
shadow_rusty 41 Report post Posted August 30, 2016 Yep, that is AWESOME. Once again, well done. Quote Stolen from SlotsNZ Team ABC Team Leader (Ambitious, But Crap) Home Track Threads - Shadow's Semi-Permanent Layout & Another Rug Racer & Proud of It & Gymkhana Test Track Car Collection Thread - My Car Collection Charts / Diagrams - MJK Tyre Selector / Slot.it 4wd Gearing / PoliCar Rollout / Rollout Chart Generator / SCX 4wd Rollout / Track Wiring with Brake on Track Call Share this post Link to post Share on other sites
Pioneer 5 Report post Posted August 30, 2016 Crikey! Choc-icetastic. Gareth, if you ever decide you can work for the minimum wage + a lucky dip into the broken parts bin every Saturday morning, please call me. Jules 1 Quote Share this post Link to post Share on other sites
mattcrackers 71 Report post Posted August 31, 2016 Awesome work on the bus and minis. Well done. Matt Quote Share this post Link to post Share on other sites
QRphil 0 Report post Posted August 31, 2016 Wow! A great movie and fantastic tribute in slot car models! Quote Share this post Link to post Share on other sites
I Am The Walrus 8 Report post Posted August 31, 2016 Epic. Just epic. Quote A wise man once said... "Its not the mistakes you make , its how you respond to them that matters." (It wasn't me) Share this post Link to post Share on other sites
choc-ice 2 Report post Posted August 31, 2016 Will you use lead weight or gold bullion for ballast. From historical evidence I would suggest not to put too much at the rear. Good point, well made. Did you use solidworks for the modelling? I would love a set of those, if you ever decided to sell (some hope huh). I use PTC Creo for the modelling as it's what I use for my day job. I'll make a limited number of kits, but you'll need to sit down before checking the price of the coach. AUS$515 is not cheap, but it makes the Mini look good value at AUS$43 Quote 3D modelling a slot car - Dodge Monaco Share this post Link to post Share on other sites
ZeGas 65 Report post Posted August 31, 2016 Damn you, you should have said sit down right at the top and in BIG BOLD LETTERS now I got a nasty bump on my head. That price is certainly way out of my wife's league, and she is the key you know. Quote Cheers Grant ....................................................... Home Track..........Corvette C1 Build..........McLaren M1A Build..........Maserati 300S Build..........Allard J2 Build..........50's Diner..........Iso Griffo A3C 3D Printed Adjustable Chassis..........3D Print Projects If life gives you lemons, take them, free s#!t is cool. Share this post Link to post Share on other sites
