Ben_M
Removing Fuel?
For some reason, i've suddenly got fuel usage running on all of my events. I've obviously done something without knowing but I have no idea on how to remove it? It has attached itself to existing events and new ones that I have created.
Any help? Its rather annoying!!
In expert race setup, select the fuel 'tab', and uncheck "Use Fuel".
Unfortunately, you will need to do this for each race that you don't want fuel usage for.
Not sure how it auto added to your races though. That's just weird.
Unless, you are just using the fuel race layout, and it's not actually using fuel...
Bugger, I checked all those and they are unticked. It is using the fuel and it is very annoying as some cars will make the 10 laps for testing while others will only do 9, so then I can't get a comparison time.
After you uncheck the use fuel tab.
You must click on the "Update" in the middle on the screen to make the changes take effect.
try that champ...
Yeah it was already unchecked. But you did just give me an idea which just worked. I ticked it, updated, removed the tick and updated and its sorted. Thanks all.
El bizaro.
Glad it's sorted.
Sounds like the database was corrupted.
P.s. You didn't do something silly like downgrade your rd version?
