Sam Cook
Doughnut Rubber Block
Heard of it, try cutting up some jandals or what are they called there? flipflops?
We used to do this years ago,but not worth the effort these days will ready cut donuts readily available.
You can buy donuts with any grip level required.
I have also tried various industrial foams, but found the grip not as good as regular Parma cheap donuts.
Edited by kalbfellp
Sam, Ace hobbies have Plafit donuts in the size you quoted & are only $4.60 a pair.A few years ago I bought a sheet of foam rubber from Clarke rubber for a set of 32mm dia rims for a 1/18th scale slot car I had built,It was fairly expensive & I used a hole saw to shape & cut before truing,Foam was very similar to the Plafit donuts that are my normal race tyre.The Plafit donuts come in many different sizes & are very cheap & work well on any surface track.Cheers Jimmy :D
To finsh first,first you gotta finish
